01-25-2018, 03:51 PM | #67 |
10539
Rep 41,181
Drives: 2018 Alpina B6 650ix GC
03-02-2018, 05:24 PM | #69 |
Rep 3
coding error
Hi Shawn,
I am using v.63.3_PSdZData_Lite - ISTA+ Version data files and get the below error when trying to modify the ACSM2 module: CAFD_000011AB_007_002_004 Fehler: File for "cafd_000011ab_007_002_004 not found! [C012] CAFD_000011AC_007_000_041 Fehler: File for "cafd_000011ac-007_000_041 not found! [C012] Can you please pm the files? Thanks |
03-02-2018, 05:26 PM | #70 | |
10539
Rep 41,181
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
03-07-2018, 10:35 PM | #71 |
Rep 1
Hi Shawn,I am using v.63.3_Psdzdata-lite and get the below error when trying to modify the flem (43-44)module: Failed to get Cafs for SWE”swfl 000030ba_004_050_000” .Can you please pm the files?Thanks
03-07-2018, 11:03 PM | #72 |
10539
Rep 41,181
PM sent.
03-15-2018, 10:05 PM | #74 |
10539
Rep 41,181
PM sent.
03-20-2018, 10:50 AM | #75 |
Rep 2
I'm having the same problem as all the others, and I guess my PSdZdata is too old too. I've been using ver. 63.4 and got the 'CAFD not found' on almost every CAFD. Tried changing to ver. 63.3 in the data folder in case first one was corrupted but nothing changed. Do I have to get a more recent version and is that even possible? Car is a brand new 320d F31. Picked it up yesterday and already hate that the stop/go system is activated by default every time. Thanx in advance!
/Ian, Copenhagen. |
03-20-2018, 10:53 AM | #76 | |
10539
Rep 41,181
03-21-2018, 07:46 AM | #77 |
Rep 2
Can you please also send me the link. My car is F32 430d M Sport.
I got my car back from the dealership, looks like they completely reset my car to factory (all coding gone) and updated bunch of software (also my navigation seems very slow now??)... so my current E-Sys setup is resulting in the aforementioned errors for FEM_BODY and REM. Coding for HU_NBT worked fine though (opened and coded OK). Is that OK or should I re-code HU_NBT with the new PSdZData? Many thanks. |
03-21-2018, 09:41 AM | #78 | |
10539
Rep 41,181
03-30-2018, 10:15 AM | #79 |
Rep 25
Hi shawn could you please send me the last PSdZdata?
i had code friend car and after his car update from dealer cant code anymore ( fembody and some others ) thanks in advance!!!! P.S if you ll send PSdZdata , i will only want to replace the PSdZdata on C? |
03-30-2018, 10:19 AM | #80 |
10539
Rep 41,181
PM sent.
03-31-2018, 01:33 PM | #81 |
Rep 25
thanks shawnsheridan all works fine BUT i did the mistake i send you PM but i write it also here shawn thanks for files ONE QUESTION PLEASEEEEEEEEEE i read all ecu's and thanks for that. BUT i tried to fdl code FEM BODY and the first time i success it but i press code and not fdl code ( also car shut down when coding maybe this makes that issue) as usuall by my mistake and now i read all ecu's except FEM BODY i had many months to do and did it the mistake with code. can i read again the FEM BODY???????? i tried to delete and paste again PSDZdata but same Isuue...... FEM BODY red error THANKS IN ADVANCE P.s must do this steps as i show in other post ????? Last edited by xasomerh; 03-31-2018 at 02:00 PM.. |
03-31-2018, 03:34 PM | #82 | |
10539
Rep 41,181
If FEM_BODY has missing or corrupted CAFD you must try and inject CAFD into ECU and VO Code it. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE.
03-31-2018, 04:10 PM | #83 | |
Rep 25
No the car engine was off BUT when code is on sending the car switch off lights and must hit again ones the start button. so for some how the code doesnt work and the second attemp the febmody was red error. thats why i sent you the photo from other post. ANYWAY i try your solution as always |
04-03-2018, 12:14 PM | #84 | |
Rep 25
Shawn thanks for the solution you are always here. its nice for us . P.S i code all that my friend want but only one strange was that the blinker does not change to 5 times ( werte +04 ) i tried it twice and nothing.up to werte was UNKNOWN you believe that must change it ? ) ANYWAY THANKS A LOT !!!!!!!!!!!!!!!!!! |
04-03-2018, 12:17 PM | #85 | |
10539
Rep 41,181
Number of blinks can no longer be coded in new firmware.
04-03-2018, 07:36 PM | #86 |
105
Rep 327
Can I get a link to latest PSDZDATA files please?
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
04-03-2018, 08:57 PM | #87 |
10539
Rep 41,181
04-04-2018, 05:42 AM | #88 |
Rep 25
Shawn as you said the new firmware have somethings codes that dosn't coding anymore as the blinker on f series.
1. is any other knowing codes that some as blinker dosn't work anymore? 2. the new firmware have any visual changes on engine or electronics accessorize on car? |
