03-18-2022, 07:41 PM | #67 |
10539
Rep 41,181
Drives: 2018 Alpina B6 650ix GC
What ECU? NBT?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
03-20-2022, 01:08 AM | #68 |
Rep 9
Blank screen
Hi
I have a blank screen after doing some basic coding where I successfully changed the radio band from japan to NZ. I then tried to change the country in the navigation form japan to NZ by changing some coding in the SALAPA.element and this seemed to work. I then changed some of the country settings in the navigation options in the HU_NBT2 CAFD file and the screen blanked after one of these changes. I could get the screen to work after undoing the changes and I tried different NAVI_VARIANTE settings until I could not reverse the screen blanking which is now permanent. I think this was when I chose the 'keine-navi' setting but Im not 100% sure. After some fumbling around I now seem to have some corruption in the HU_NBT2 ECU because I get errors when I try and code FDL or code the CAFD or the HU_NBT2. I have tried to insert the CAFD file but when I do so e-sys 3.30.1 returns an error when I try and do the last step which is the coding of the HU_NBT2 (see attachment) I try and read the coding data of the HU_NBT2 and the description next to the ECU name returns some strange control characters. I saw a similar fault description and solution in this thread that involved WriteDataByIdentifierVIN but when I click start then I am asked for diagnostic addresses etc. --> WriteDataByIdentifierVIN <-- Error: Please enter a Diagnostic Address and a Base Variant first. [G098] My aim is to try and restore the screen to its original working condition. It looks to me like something has been corrupted in the HU_NBT2 settings. Any assistance is appreciated. |
03-20-2022, 01:13 AM | #69 | |
10539
Rep 41,181
03-20-2022, 09:36 AM | #71 |
10539
Rep 41,181
04-01-2022, 01:49 PM | #72 | |
14
Rep 4
I tried to change the region and now have a black screen and a missing CAFD file of the HU_NBT2. Can anyone help me to fix this problem, please? Last edited by SnapSuzun; 04-01-2022 at 03:39 PM.. |
04-01-2022, 03:45 PM | #73 |
10539
Rep 41,181
PM sent.
06-13-2022, 01:46 PM | #74 | |
22
Rep 140
Thanks, Tich.
07-14-2022, 09:49 PM | #75 | |
10539
Rep 41,181
Does NBT2 have CAFD?
07-14-2022, 10:19 PM | #76 |
10539
Rep 41,181
Why are you flashing it? Inject CAFD and VO Code it.
07-14-2022, 10:56 PM | #77 |
10539
Rep 41,181
What do you mean "restore my HU_NBT2 id4 hw 2.3 with NBTevo_E16202A (or higher but only id4)"? Was this previously flashed from ID4 to ID5/6?
07-15-2022, 10:01 AM | #78 | |||
10539
Rep 41,181
You pressed the Code Default Values button. This is a factory default condition without regard to your car's actual FA. Often after using, ECU is not recoverable. The button should be named "Screw Me" instead. It should be recoverable by Injecting CAFD and VO Coding ECU, and if that fails, then by flashing it. Both require original, unmodified FA. Is the FA you are using original?
07-15-2022, 12:15 PM | #79 | ||
10539
Rep 41,181
FA is just used when VO Coding.
07-15-2022, 01:06 PM | #80 | |
10539
Rep 41,181
Not sure what Component Protection has to do with this. It should not be triggered unless you chnaged VIN in NBT2.
07-15-2022, 02:21 PM | #81 | |
10539
Rep 41,181
07-15-2022, 05:39 PM | #82 |
10539
Rep 41,181
07-19-2022, 04:41 PM | #83 | |
10539
Rep 41,181
VO Changes are not limited. If it locks again, just rerun FI with same Code.
07-19-2022, 05:04 PM | #84 | |
10539
Rep 41,181
10-22-2022, 08:16 PM | #85 |
Rep 8
Hello,
I am a French and I have a problem with my f20 LCI (2016). My NBT was stolen and I have bought a second hand NBT EVO HU. In first I installed the NBT in my car and the system worked well. And in second, my screen become black but my radio / music work well. I don’t understand, the NBT is locked because is not the same VIN with my car ? I have buy a new display with the same bmw part no but I have always this black screen. Someone would have any idea ? I have e-sys 3.3x Thank you for your help, |
10-22-2022, 08:31 PM | #86 | |
10539
Rep 41,181
10-22-2022, 08:42 PM | #88 |
10539
Rep 41,181
