F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Most miles on B58 engine
Studio RSR
      03-08-2022, 03:24 PM   #67
ErkanTR16
64-bit
ErkanTR16's Avatar
598
Drives: 2018 BMW 340i xDrive
2018 340i xDrive - 69K Miles….
Drop-in K&N Air Filter and Dual Resonator delete other than that it's completely stock.
      03-08-2022, 03:33 PM   #68
Randy Johnson
M340i
Randy Johnson's Avatar
408
Drives: BMW M340i
2021 BMW M340i  [10.00]
Originally Posted by NormanConquest View Post
62k
Low coolant alert twice but stop when the whole system was flush when I requested the stock rock guard to be installed
Two software updates
Drive seat rail needed replacement once.
Rear driver weather strip had to be adjusted once
Overhead computer module replace
Two fuel leak false alarm due to gas attendant not securing gas cap.
And I think that it transmission and engine has been solid.
You must live in a super rich area. I have not had someone pump gas for me for over 30 years! Aren’t they all self service now?
      03-08-2022, 03:54 PM   #69
aardate
aardate's Avatar
No_Country
194
Drives: X4MC
62k
In some states/Areas you are not allowed to self serve, there will always be an attendant to do that for you
      03-08-2022, 04:28 PM   #70
imperfectluck
imperfectluck's Avatar
434
Drives: 20' F87
[QUOTE=aardate;28666352]
I'd be hard pressed to try and have an attendant do my E mix for me
      03-08-2022, 06:41 PM   #71
oem.plus_440gc
oem.plus_440gc's Avatar
367
Drives: 2019 440i XDrive GC
Still attendants here in NJ. It is against the law to self pump here unfortunately. I think they're trying to get away from it though, which I'd prefer tbh.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
WolfGTI717.50
      03-10-2022, 11:50 AM   #72
brother.antone
brother.antone's Avatar
Drives: 2016 340ix
Got 64k miles on mine. No issues so far got a bm3 stage 2 tune on it drove it for a couple hundred miles and have no problems.
      03-13-2022, 05:54 PM   #73
FMArouet
Drives: 2016 BMW 340ix
2016 340ix. I should hit 125k miles this weekend. Bm3 stage 1 93 for the last 75k. No major issues yet.
Appreciate 3
SRB440IGC100.50
G.Newt810.00
      03-18-2022, 08:35 AM   #74
cooper rumfelt
Drives: Bmw 340i (2016), Bmw M3 (1995)
got 90,000
got about 90,000 right now, got it at about 40,000 and had it stage 2 with meth, stage 2 hpfp, etc. turbo went out at around 80,000 and then got the stage 4 big boost and the only problem I've had was to replace the pcv diafram and that's it.
Appreciate 3
B58577.50
Skyhigh1926.50
abbike18717.50
      03-18-2022, 08:27 PM   #75
Mr. 340
68
Originally Posted by B58 View Post
2018 340i
28k miles with scored up cylinder walls from injectors. Mods at the time: Pure S1, Meth, MHD BEF, dp, intake, and e30 mix.
Recently installed a brand new engine and currently bone stock at the moment.
2016 340i, I am nearing 28k miles at the moment. Don't know if I should be thinking about replacing injectors already. These injectors stories are getting in my head.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger
PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust
PJ ACN91 + Meth tune| XHP Stage 3
      03-18-2022, 09:41 PM   #76
B58
B58's Avatar
578
Drives: BMW
If you have cold start enabled you'll notice the rpm surging when you start it up. If you disable cold start it will just sound like its choking on a start up and that's when you know they're leaking or at least those were the symptoms I had including rich mixture oxygen sensor fault.
      05-11-2022, 08:11 PM   #77
colin2211
44
Drives: 2016 BMW 340 xdrive , 2008 M3
just hit 210000 miles lol
Appreciate 6
      05-11-2022, 11:37 PM   #78
G.Newt
810
Drives: CT4-V Blackwing 6MT
Mine chokes a bit for the first second or two with cold start disabled. But it's been that way for awhile, plus I'm on an E40 mix. I have brand new injectors at 51k miles and I'm at 54k miles now.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      05-12-2022, 12:11 AM   #79
B58
B58's Avatar
578
Drives: BMW
Just be careful. Not saying it's not possible, but maybe you have a bad injector out the box. You don't really get a choking start on E40 with my experience, it's only when you're running full E85 like my 335is and the weather drops below 60F then it sounds like it's cammed.
G.Newt810.00
      05-12-2022, 12:15 AM   #80
G.Newt
810
I haven't had any of the typical misfire issues that a leaky injector would cause. I drive her out of town on the weekends (1+ hour each way) and she runs fine. It's only on the first cold start of the day and I guess "choke" is a bit of an exaggeration. To me, it's just a normal cold start. Kinda been that way ever since I disabled it 30k miles ago lol. I do appreciate your concern. Thanks for looking out for ya boy.
      05-12-2022, 02:34 AM   #81
blacksapphire440i
Novice
blacksapphire440i's Avatar
316
Drives: 2018 440i Gran Coupe
please show a picture so BMW haters will shut up about the modern bmw inline 6 being unreliable
      06-07-2022, 01:39 PM   #82
chinniciF32
Noob
chinniciF32's Avatar
70
Drives: f32 n55
wow thats alot man, I thought I had a lot with my old school 2015 N55 at 129K. Show a pic of the Speedometer
FBO, MHD Stage 2+ E20, Xhp Stage 3
      06-07-2022, 04:47 PM   #83
JezB58
16
Drives: F31 340i
Love this, that is commitment to the cause
I've just hit 95k miles in my 2016 340i.
BM3 stage2 + 93 OTS, TU pump, VRSF sports cat, XHP stage 2 for the last 10k or so.
All good so far, changed the plugs at 85k and doing regular oil changes but debating on the right time for a transmission service.
      06-07-2022, 09:31 PM   #84
G.Newt
810
Auto tranny at 60k. Manual tranny every 30k. I also do my diffs and transfercase every 40k.
abbike18717.50
      09-22-2022, 12:16 PM   #85
colin2211
44
just hit 222,222 miles !!
Appreciate 4
Aldor2788.00
Skyhigh1926.50
Prak903198.00
      09-23-2022, 10:41 PM   #86
MaximusJ
MaximusJ's Avatar
305
Drives: 340Xi MG 2017
Mineral Grey '17 F30 340XI
[Garage] // [Build Journal]
Jet Black '06 E90 325I
[Garage]
Appreciate 2
      09-24-2022, 02:48 AM   #87
Frozen Fractals
163
Drives: 2018 540i xDrive
I just rolled over 100k on my 2018 540i xDrive. Bought it 3 years ago with 40k miles. Zero issues with drivetrain. *Knock on wood*
Tuned with BM3 since 50k miles. Stage 1 ACN91 from 50-60k miles. Stage 2 E30 from 60k-75k miles. Stage 2+ E30/E50 since 75k miles.
Oil changes with BMW LL01 FE 0W-30 and OEM filter every 7.5k-10k miles. Transmission, transfer case and front/rear differential services at 50k and 80k miles.
2018 G30 540i xDrive M Sport | Carbon Black Metallic | KW V3 Coilovers | F90 Suspension | F90 Brakes | 20" HRE FF10 Liquid Black Wheels | Michelin Pilot Sport 4S Tires | Ivory White Dakota Leather | Carbon Fiber Trim | Executive Package | Bowers & Wilkins Diamond Surround Sound System | JL Audio 12W6v3 and XD600/1v2 | Ceramic Controls | BM3 Stage 2+ E50 ECU Tune | xHP Stage 3 TCU Tune | Dorch Stage 2 HPFP | MST Cold Air Intake | FTP Chargepipe | AA Catted Downpipe | Remus Catback Exhaust
      09-24-2022, 11:17 AM   #88
colin2211
44
Appreciate 8
f30post
