06-04-2013, 02:21 AM | #67 |
650
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
06-14-2013, 08:31 PM | #68 |
Supreme Allied Commander
3890
Rep 54,589
Drives: F80 M3
7" spring would move the perches further up, but depends on wheel and tire combo, you may still need a 3mm or thicker spacers.
06-16-2013, 06:21 AM | #70 | |
650
Rep 2,601
06-17-2013, 03:34 PM | #71 |
3890
Rep 54,589
Drives: F80 M3
06-17-2013, 08:36 PM | #72 |
650
Rep 2,601
06-17-2013, 09:26 PM | #73 |
12
Rep 158
Drives: 2011 135i Coupe
What minimum spring rate do you recommend to run a 6" w/o binding?
2011 135i m-sport dct | cobb ap | berk street axle back | tc kline sa coilovers, swift springs | dinan camber plates | lci blacklines | lux angel eyes | scopione cf front lip and rear diffuser | bmwp cf rear spoiler and side skirts, apex ec-7 18x8.5 et45; 18x9.5 et58 | hankook v12 245/35/18f, 265/35/18r w/5 mm spacers | apex stud conversion kit
coming soon: m3 control arms; er charge pipe; cobb fmic |
09-19-2013, 12:12 AM | #74 | |
3890
Rep 54,589
Drives: F80 M3
At 6", you will need at least 450 lb/in or so to keep it from bind. 400 lb/in is too close to call and I know 336 lb/in Swift will bind. |
01-20-2020, 11:04 AM | #75 |
3890
Rep 54,589
Drives: F80 M3
New Ohlins R&T BMS MI01
The new front spring rate of 70 N/mm is also 1" shorter for more wheel/tire clearance. Improved valving to handle the spring rates. > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year limited warranty > Springs ordered separately FRONT FEATURES > McPherson strut > Single bleed adjuster > Height adjustable (approx. 10 mm lower than standard) > Coil springs (70 N/mm) > Use with original top mounts REAR FEATURES > Conventional shock absorber > Single bleed adjuster > Height adjustable (approx. 15 mm lower than standard) > Coil springs (120 N/mm) > Use with original top mounts SPRING RATE FRONT 70 N/mm REAR 120 N/mm |
chris_flies3028.50 |
08-17-2020, 02:14 PM | #76 |
3890
Rep 54,589
Drives: F80 M3
Ohlins BMS MI01 fronts with Swift springs and rears with SPL adjustable toe arms installed.
08-25-2020, 05:16 PM | #77 |
219
Rep 210
What spring rate are you running in the rear? I am currently running a 7in 450 front and an 7in 850 rear on my ohlins. Do you think thats stiff enough in the front to go to a 6in? is 7in ok in the rear? I am starting to get worried about coil bind but i haven't noticed it on track yet.
08-26-2020, 01:32 PM | #78 | |
1Addict
3243
Rep 7,910
08-26-2020, 01:51 PM | #79 |
219
Rep 210
08-26-2020, 02:27 PM | #80 |
3890
Rep 54,589
Drives: F80 M3
08-26-2020, 02:50 PM | #81 |
219
Rep 210
ya im currently running a 245 Yoko a052 and have a 12mm spacer and 7" spring. It is still pretty close and would like the inboard clearance as well as fender clearance if i could run a smaller spacer
08-26-2020, 03:36 PM | #82 |
3890
Rep 54,589
Drives: F80 M3
08-26-2020, 04:25 PM | #83 | |
219
Rep 210
