06-17-2021, 11:12 AM | #67 |
205
Rep 269
Has anyone actually confirmed if istep version F020-19-03-522 can be tuned via OBD2 or bench unlock required? It seems to be right on the "edge" of OBD2 locking.
06-17-2021, 06:22 PM | #68 | |
1426
Rep 1,821
And yes, 19-03-522 will be on 002 bootloader. Istep / ilevels are really easy to misreport, so going by istep is just silly when you can just look at dme btld version.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
Detoxified204.50 |
06-18-2021, 10:27 AM | #69 |
56
Rep 174
Dav3
I have the version F2020-21-03-530 on my M3 ZCP 2017 and Alex was able to tune it to Stage 2
MY02 S2000 > MY11 STI > MY01 E46 M3 > MY05 S2000 > MY06 911 C2S > MY88 944 TURBO S > MY17 STI > MY17 SS 1LE > C7 GS w/ ZO7 package > MY18 ZL1 >MY20 F87> MY17 F80 ZCP> MY18 Subaru STi Type RA > MY13 E92 "Stripper"
06-25-2021, 04:25 PM | #70 |
40
Rep 95
Where do we see the btld version?
Current: 2020 X3M, 2022 911 GT3
Past: 2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337 |
06-25-2021, 05:27 PM | #71 |
1426
Rep 1,821
It really depends on the program you are using.
E-Sys, INPA, Tool32, ISTA, and other BMW oriented programs all report it, since the bootloader and software are all part of the software version reporting. This is the so-called SVK - Steuergeraete-Verbau-Kennung number. I don't use the aftermarket mobile apps, but Carly and Bimmerlink could possibly report those as well.
06-26-2021, 01:50 AM | #72 |
950
Rep 1,028
UPDATE June 2021 Apparently, updated ISTEP version DOES NOT ALWAYS exclude OBD Flash possibility. Flashing lock actually depends on the bootloader version. If you contact BootMod3 and have an ENET cable, they can tell you if its possible or not. Source: Just flashed my F80 M3 with latest ISTEP. However, this should not apply for 2020+ Cars with new DME although Gx DME's have been cracked as of late
Current: G87 M2 / F21 M140 / 718 GT4 | E89 Z4 35is
Gone: E92 M3 | RS3 8V | E82 1M | AMG GT-S | X3M Comp | F80 M3 | Juke Nismo RS | E85 Z4 M Roadster | R58 Coupe JCW | F87 M2C| F87 M2 | F22 M240i | F82 M4 | E89 Z4 2.0i | F56 Cooper S | E92 330i | R56 One |
12-04-2021, 10:34 AM | #73 |
11
Rep 11
Has this method of determining whether or not the car can be flash tuned been confirmed? My istep version is F020-18-07-521. And my BTLD version ends with 001.
Based on this thread, my car can be flash tuned correct? I want to confirm this before making the purchase. Thanks! |
12-04-2021, 10:49 AM | #74 | |
1546
Rep 8,972
Yes it can be flashed... |
12-04-2021, 05:47 PM | #75 | |
11
Rep 11
I do not know what the issue is. I turned off the firewall on my computer and ensured all doors were closed, drivers belt was clicked in, etc. Any suggestions/advice? Thanks in advance. |
12-05-2021, 02:20 AM | #76 |
1546
Rep 8,972
I found Chrome problematic.
The browser needs full cookie access etc i set up a copy of Firefox with all security off just for BM3. Have you tried "download & flash later" then flash from the downloaded tab? They always reccomend that way. Else put in a support ticket, they're very good. I recently had a remote session where they took over my laptop to sort a flash fail Last edited by doughboy; 12-05-2021 at 02:29 AM.. |
10-06-2022, 08:43 PM | #77 |
12991
Rep 0
Where do you find the btld version?
06-16-2023, 10:39 AM | #78 |
Rep 58
06-16-2023, 10:50 AM | #79 | |
1546
Rep 8,972
Mines still as factory 2018, never updated at all, everythign works just fine including OBD tuning. But If you want to update particular modules then I think you can do that, just dont update the DME. |
06-16-2023, 01:57 PM | #80 | |
Rep 58
Id try to flash to the same istep, unless there is a different way for my case |
06-16-2023, 04:26 PM | #82 |
Rep 58
09-02-2023, 09:52 PM | #83 |
149
Rep 165
Just wanted to throw this out there for anyone who comes across this.
Recently my istep version was changed due to some 3g update by the dealer, but the BLTD version seems to have stayed the same. i used the obd2 connector and bootmod3 agent to check this. https://f87.bimmerpost.com/forums/sh...0#post30455840 |
09-20-2023, 11:59 PM | #84 | |
137
Rep 136
Edit - none of these will work to pull BTLD version. I emailed Bimmercode and OBDLink tech support. I'm downloading E-Sys instead and going that route. Last edited by MSH_; 09-22-2023 at 11:43 AM.. |
09-24-2023, 03:38 AM | #85 | |
950
Rep 1,028
MSH_136.50 |
09-24-2023, 09:42 AM | #86 |
137
Rep 136
09-24-2023, 08:23 PM | #87 | |
149
Rep 165
MSH_136.50 |
