04-07-2020, 08:24 PM | #67 | |
188
Rep 458
https://www.bootmod3.net/log?id=5dfe...729b4642a50c7f stg 2 e30: https://www.bootmod3.net/log?id=5d6d...90c652e3aa327e
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
04-07-2020, 11:49 PM | #68 | |
575
Rep 585
With the Stage 2 93 map the car hits 1116 PSI vs target of 2878 PSI at 4242 RPM This is because of the relatively high boost of 18 - 20 PSI between 2900 - 4500 RPM By comparison MHD equivalent map has about 16 - 17 PSI in the same area. The Stage 2 E30 map gets to 1522 PSI vs target of 3100 PSI at 4357 RPM with boost 0f 18 - 20 PSI between 3200 - 3800 RPM. Adding boost on top of that would result in hard crashing rail pressure. I'm surprised BM3 haven't lowered the load/torque targets in their maps to better cater for the HPFP limits. They should target 170 - 175 Load Target at WOT from about 2000 RPM to about 4500 RPM then ramp it up.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
04-10-2020, 04:09 AM | #69 |
18
Rep 49
04-14-2020, 11:22 PM | #70 |
enthusiast
116
Rep 221
How to view those staging lights to know when to get on it? When I switch to video I don’t see it.
How to use it overall? I connected to satellite. Just got Dragy but will run tomorrow.
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph. |
04-15-2020, 07:13 AM | #71 |
316
Rep 420
My results with this auto configuration:
MHD stage 2 98 RON. CSF Intercooler Radiator, Full Catalytic Exhaust, Cold Inlet. 0-100 3.66c. 100-200 8.2c. 0-402m 11.6c. When using methanol with control through JB4, the results so far are: 0-100 3.6 s. 100-200 7.7s. 0-402m 11.34s |
04-15-2020, 10:42 AM | #72 | |
156
Rep 242
04-15-2020, 11:03 AM | #74 |
Petrolhead
1951
Rep 3,520
I’ve never used or own a dragy. But from the videos I’ve seen, I believe the staging lights come on automatically before it detects the car moving. It doesn’t pop up and you don’t have to respond to it. It’s an overlay on the video after it has been recorded.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
04-15-2020, 01:20 PM | #75 |
188
Rep 458
I have the same issue as you and I use an android phone. Not sure if it is just android users that have this issue.
04-15-2020, 03:07 PM | #76 | |
401
Rep 1,018
Open the Dragy app> me>videos
Choose the video you want then tap next on the top right corner then tap export also on the top right corner. The Dragy app will set the staging lights automatically. Quote:
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
Tunes: Self Made Tunes - MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=...33-34-35-36-37 |
boosted116.00 |
04-15-2020, 04:39 PM | #77 | |
812
Rep 1,363
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
04-15-2020, 05:07 PM | #78 | |
575
Rep 585
I plan to get into the 10's on stock turbo without meth
04-15-2020, 06:19 PM | #79 | |
812
Rep 1,363
04-15-2020, 09:34 PM | #80 |
enthusiast
116
Rep 221
Very happy, overall, changing signature . With some practice, I can drop a bit more.
Only flash and catted downpipe in signature. 0-60 3.56s
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph. Last edited by boosted; 04-15-2020 at 09:39 PM.. |
04-16-2020, 12:12 AM | #81 | |
575
Rep 585
Do you have xHP tune for transmission? I'd expect a 60ft time of 1.7 seconds or better with X drive in a tuned car. Also, are you starting in 1st or 2nd gear?
04-16-2020, 02:10 AM | #83 | |
enthusiast
116
Rep 221
I have MP stg 1 trans flash, so I’m all set. I did break torque around 2300rpm (last night) in D and Sport +.. not manually shifting to 1st or 2nd gear. I need to practice to achieve 1.7s or lower. Any suggestion - I’m all ears as this is my first AWD
OzBMR574.50 |
04-16-2020, 03:08 AM | #84 | |
575
Rep 585
A lot of people have recorded quicker times by being in Sport+, shifter to the left, manual shifting, and launching from 2nd gear. This eliminates 1 x gear change to 60 mph and is quicker for quarter mile. Rev 2nd gear out to about 6800 RPM, change 3rd and 4th at 6500 RPM. Rev 5th out to 6700 RPM and record 100 - 200 km/h and 60 - 130 MPH times too
boosted116.00 |
04-16-2020, 12:36 PM | #85 | |
enthusiast
116
Rep 221
I’ll try it this weekend, thanks.
04-17-2020, 05:13 AM | #86 |
Rep 5
320xi swapped in 340xi
Tune: Stage 2 KK-Performance Downpipe: Mikes Custom First and only attempts[IMG][/IMG] |
04-17-2020, 11:22 AM | #87 |
156
Rep 242
04-17-2020, 11:24 AM | #88 |
Rep 5
