07-10-2022, 02:49 PM | #67 | |
Forced Induction Connoisseur
988
Rep 773
Drives: 23 X5MC / 23 720s
Garage List 2024 G87 M2 [0.00]
2023 Mclaren 720s [0.00] 2005 Honda S2000 [0.00] 2008 BMW M3 [0.00] 2023 BMW X5MC [0.00] 1964 Ford Mustang [0.00] 1968 Pontiac GTO [0.00] |
Oy vey, look at all these shekels
r33_RGSport13123.50 |
07-10-2022, 02:51 PM | #68 | ||
13124
Rep 18,795
Special order item.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com Memorial Day SALE!! 05/24 - 06/03 • Coupon Code: "MEMORIAL" MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
07-11-2022, 03:44 AM | #69 |
Rep 3
07-11-2022, 08:57 AM | #70 | |
13124
Rep 18,795
Replying.
07-11-2022, 08:23 PM | #71 |
1397
Rep 1,988
I'm on the fence with the 1500 vs 2000 for the x5 45e. I suppose the 45e has less dust than a non hybrid because of the regenerative braking. The 2000 is recommended for the north east but the graphs show that regardless at cold temps the 1500 is better than OEM. Another user has also said on an X5m that the 1500 was fine in the cold. I dont want to be disappointed getting the 2000 and saving a little brake dust vs oem. For 600+ for the set I really want improvement. What to do?
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO 2016 340i xDrive : AW/CR (sold) |
07-12-2022, 07:06 PM | #72 |
221
Rep 192
07-24-2022, 03:52 PM | #73 |
106
Rep 145
Just ordered a set...
Now the electronic parking brake, I guess I can use my scan tool to reset it. |
07-24-2022, 05:30 PM | #74 | |
4604
Rep 3,550
All that I have ever had to do is back out the brake manually via star bit, once all the "home" the break at first start performs a calibration to reset the distance. Super easy since you are already doing the break job.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0 2019 718 Cayman Base 2015 M235 Manual On the list for the M2 CS |
07-24-2022, 07:08 PM | #75 |
106
Rep 145
Just seems easier to do it electronically but we will do it the manual way.
07-24-2022, 07:54 PM | #76 |
1397
Rep 1,988
Ok so the is2000 vs m sport brakes for the 45e.. what percentage reduction we talking about here? 50%? How about the is1500 (which you did not recommend for NY climate)?
First and foremost I don't want to lose braking capability on a 5600 lb car. Brake dust comes second but to spend close to 700 on a set looking to see how much dust reduction I'll get for that price. And lastly do these wear any faster than stock pads?
07-24-2022, 07:58 PM | #77 |
4604
Rep 3,550
Funny I thought the other way around, since it has to come off anyway and you can back it out by hand. lol But yeah I didn't know if for some reason there was anything for the 23 models that required it to be a must.
07-26-2022, 10:37 AM | #78 | |
13124
Rep 18,795
IS2000 will take about 50 miles, roughly. It is all depending on what kind of traffic condition that you are driving on. From my testing from my home to office, which mostly highway and about 12 stop light round trip and little highway traffic. Non M doesn't have drilled rotor, so it doesn't have as much friction. When I tested IS1500 on my G05 X5 40i with M Sprot brake and drove it to cold climate area (close to freezing temp), early in the morning there is no initial bite. Took me about 1/4 to 1/2 miles with 2 stop sign before I re-gain the initial bite. Upon returning from my trip, I've changed it to IS2000. So far I haven't took it to cold climate area yet, but I went to a place where it was 50º in the morning and initial bite is not affected at all. Wear wise, it is depending on your traffic condition. I have seen guys with M car that lives in heavily congested area and always stuck in traffic, his stock brake pads only last him 10k miles. Keep in mind that brake pad doesn't wear out based on your driving distance, it is based on how often and how hard you are rubbing it against the rotor. It is not like tire where it have friction to the ground all the time.
10-02-2022, 06:16 AM | #79 |
106
Rep 145
Did the front pads yesterday and didn't have to retract the pistons, truck has only 4700 miles. Hoping for the same today on the rear and not deal with the electronic parking brake.
10-02-2022, 06:33 AM | #80 |
480
Rep 1,301
Electronic Parking Brake is only on the rear.
_____________________________________ 2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4 |
10-02-2022, 07:19 AM | #81 |
106
Rep 145
I am aware of that. What I said was that the fronts did not require pushing in the piston. Hoping to have the same result in the rear as to not deal with electronic brake.
10-02-2022, 03:01 PM | #82 |
106
Rep 145
Was able to do rear brakes without dealing with the electronic parking since the thickness of the RG pads were about the same as factory. So I able to slip the caliper back on without issue. Truck has 4800 miles on it.
Dust output is night and day better. |
10-02-2022, 03:04 PM | #83 |
13124
Rep 18,795
Good to hear.
10-02-2022, 03:08 PM | #84 | |
2311
Rep 2,098
Maybe tricky if your pads are worn down? |
10-10-2022, 10:56 AM | #85 |
148
Rep 880
Got a set of IS1500's from Ben about a month ago. They work great, no noise and still great bite.... Actually a little more bite than the stock pads. So nice to be able to wash the car and not have the wheels get dirty again after 2 days. Not a cheap mod, but totally worth it IMHO.
10-10-2022, 11:12 AM | #86 | |
13124
Rep 18,795
10-10-2022, 01:53 PM | #87 |
3201
Rep 1,866
@r33_RGSport I love my IS1500 thank you!
So much better
2024 M8C; 2024 X6MC; 2021 G80 M3C; 2022 P992140
RETIRED: 2021 F93, 2021 F96,2019 F82 M4C, 2018 F80 M3C, 2018 F86 X6M- black fire, 2015 F13 M6, 2015 F10 M5, 2012 F10 550i M-Sport, 2012 F13 650i X-Drive, 2009 E60 535i M-Sport, 2007 E60 530i |
r33_RGSport13123.50 QF8221.00 |
10-10-2022, 02:01 PM | #88 |
13124
Rep 18,795
Thank you for the support.
