12-25-2012, 10:00 AM | #67 |
23
Rep 33
Has anyone tried to fit the M Performance knob and boot?
http://www.trademotion.com/partlocat...catalogid=4462 |
12-25-2012, 10:06 AM | #68 |
86
Rep 340
It's a little better than the stocker, to be expected with
The additional weight. The height takes a little getting used to though, if my fingers are draped over the front of the knob they can get pinched now between the knob/shaft and the boot ring in 3rd and 5 th changes. Not a big deal but another difference.
'24 G80 Base in Dravit/Full-Kyalami, Allocated January 9th, delivered April 30th. Sandlapper CCA.
"Team 6SP/Moonroof" |
12-27-2012, 07:55 PM | #69 | |
24
Rep 495
01-02-2013, 10:02 AM | #71 | |
7532
Rep 12,318
HIGHLY recommended.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
01-07-2013, 09:11 PM | #72 |
Rep 4
This is by far the best mod I have done. It is a pain getting the M3 boot seperated from the plastic frame (much harder than the M5 boot), but definitely worth it. Thought I was going to tear the leather a few times, but just need to be patient. Used needle nose pliers to seperate once got a smaller corner started. Also, didn't need to cut M5 boot, just cut holes for clamps to peak through.
All the M's I have had, couldn't stand the throw. This shortens it up and like the weight. Concerned the shifter was going to be too short, but it is perfect. No issues. |
02-06-2013, 09:34 PM | #73 | ||
314
Rep 8,496
1. you mentioned the extra materials from the M5 boot, how did you clean it up? 2. Does even the F30 OEM BMW knobs snap-in in the same manner and fit as this swap? I'm using a F30 M Performance knob. |
02-06-2013, 09:38 PM | #74 | |
314
Rep 8,496
02-07-2013, 06:08 AM | #75 |
2757
Rep 4,445
Nice work. I did the conversion a while back with the $99 option and pulled the stock 6mt cap from the stock one. Lighting is a bit off but not noticeable to me. The lighting on this is spot on.
02-07-2013, 07:59 AM | #76 | |
24
Rep 495
I'm local if you want some help. Just let me know. |
02-07-2013, 09:10 AM | #77 | |
314
Rep 8,496
I'm also not doing the F10 M5 swap, I'm doing a F30 M Performance swap, but I imagine I would have the same issue, there appears to be a lot of excess material on the F30 boot and the M3 ring is smaller, so I'll have the same issue. I appreciate this. |
02-10-2013, 03:51 PM | #78 |
24
Rep 495
Sorry for the delay in posting these; it was a busy weekend. I didn't take a picture of the M3 boot as I was removing it from the ring but here are some pics of the M5 boot as I was trimming it and shaping it for the M3 ring.
I started by hanging the knob between my knees and fitted the ring to where I wanted it. Then I folded the leather over the top, held it with the clamps, and cut small slits where the tabs would poke through. Then I trimmed off the excess leather leaving small flaps to go around the plastic tabs of the ring. I used Gorilla Glue and would put it on the boot/ring, clamp it, and let it sit for at least 30 minutes. Then I would move on to another part and continued to trim off excess leather. These last two were near the end; I didn't take a pic when it was fully finished but this should give you a good idea of what I did. The leather is glued to the ring and trimmed off at the edge of the plastic ring. Only the little flaps that go over the plastic tabs go over the ring. In the end it all worked out great with one minor exception. The leather of the M5 boot was thicker than the M3 boot. This made it very difficult to get the plastic tabs to click back into place on the center console trim. I ended up pulling the center console off, turning it over and clipping the boot back into place. It's a tight fit but it went on and I have no concerns about it coming off. Was all this necessary? As others have shown, no, it was not. I worked on this over the course of about 4 days in the evenings after work. The same thing can be accomplished by just poking holes for the tabs and snapping it in but I wanted it glued to the ring like the stock one was ensuring it would never slip or move. Plus, it was more fun to do it this way, for me anyway. |
03-06-2013, 04:22 PM | #79 | |
314
Rep 8,496
I appreciate this detailed write up and pics. I'll post pics of my upcoming project. I'm attempting a F30 M performance knob install. I'll have to trim and glue the boot to the M3 base ring as well. I'll probably try gluing it to a smaller surface area to ensure the snap goes in easily. |
03-06-2013, 09:05 PM | #81 |
1126
Rep 1,083
I Installed Mine Recently, using Glue, and Clips, a lot of Clips
03-06-2013, 09:33 PM | #82 |
314
Rep 8,496
03-06-2013, 11:12 PM | #83 |
1126
Rep 1,083
Actually, I borrowed Clips from my Colleagues. And then I returned them after I finished
03-07-2013, 11:47 PM | #84 |
Rep 386
It seems like everyone is keeping the F10 M5 boot and just reusing their M3 ring. Is it possible to separate the M5 boot from the knob (without trashing the knob) so that it could be combined with IND's tri-color stitched M3 boot?
2011.5 M3 Coupe: Space Gray, 4MY, ZCP, ZCV, ZP2, 494, 5AC, 655, and 752
Mods: Full Venture Shield protection kit, RPi scoops, Euro fog light switch, LUX V4, clear reflectors, OEM black chrome grilles and side gills, black hood vents, IND F10 M5 shift knob and boot |
03-08-2013, 11:10 PM | #85 |
314
Rep 8,496
Hey, let me know if you're interested in a custom extension piece from IND. We can try to do a group buy.
I've emailed them for a price quote for an extension adapter (behind the boot) that extends the stem by about 1 inch. So this piece would snap in to the OEM stem on one end, and your knob on the other. And I suppose since IND will be making a few at a time, you can ask for different lengths. Let me know if you're interested. |
03-11-2013, 06:53 PM | #86 |
50
Rep 368
03-12-2013, 01:49 AM | #87 |
709
Rep 1,141
+1 same here. Those binder clips worked like a charm. However, I wish my M5 boot was in better condition. Mine was delivered wrinkled .
IG: @jeff.m3
#SAVETHEMANUALS: 2008 E92 M3 Jerez/Bamboo: SOLD | 2011 E92 M3 Alpine White/Fox Red: SOLD | 2016 F80 M3 Santorini Blue/Amaro Brown: SOLD | 2015 F10 M5 Monte Carlo Blue/Black Novillo: SOLD | 2008 E92 M3 Alpine White/Black Novillo: SOLD | 2023 G80 M3 Atlantis Blue/Kyalami Orange |
03-15-2013, 09:23 PM | #88 |
50
Rep 368
