08-26-2016, 06:03 PM | #67 |
3392
Rep 7,544
Just did another forum members car today (kevn23). Pulls like a freight train. Almost made him throw up on the test drive in a straight line! Hopefully he chimes in after his drive back to Santa Barbara.
LI-M5 will answer your questions when I get back to a computer in a couple hrs
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
08-26-2016, 06:20 PM | #68 | |
39
Rep 131
Drives: 2023 i4M50
08-26-2016, 06:34 PM | #69 |
3392
Rep 7,544
sbassi39.00 |
08-26-2016, 06:37 PM | #70 |
39
Rep 131
Drives: 2023 i4M50
08-26-2016, 07:19 PM | #71 | |||||||
3392
Rep 7,544
My pleasure to answer your questions. Quote:
For local customers, we like to allocate 4hrs total, but usually get them done in 2-3 hours. The car today took two hours flat from start to finish, which is really good considering the DME's have to be pulled, drilled, have the passwords read, backed up completely, programmed, reinstalled, and then flashed over OBD + bleeding of cooling system. We are working on a step by step ECU removal guide which we will provide to customers to assist them with this process. Quote:
I'd rather you make a well informed decision than a blind purchase. Let me know if I can answer anything else! Thanks
Lerxst M4142.00 |
08-27-2016, 12:25 AM | #72 | |
30
Rep 105
08-27-2016, 02:54 PM | #74 |
95
Rep 587
Welll WoooWieee !!
im a Salesman and just by mike's responses im Sold lmfao... all seriousness though thank you for the very detail'd response , the time taken to respond is enuff to realize that there is a commitment of product and quality that you obv stand behind! so essentially you would tune for 650'ish hp at the rear wheel's w the new modd's i ment'd on 93 and running e85 whenever i want , will running e85 gimme a couple xtra been's like my piggy does ?? Also just to be clear not your personal nor any cust's car's are receiving DM's atall huh , hate to be a pia but in erly stage's of ecu flash's the flash's where cause DM's like crazzy even more than piggy's , it's was very frustrating ! and nvr wannna go thru tat agaiin ! ok i again really appreciate asweell as im sure the other member's that do/will/want the info stated in your reply ! will be in touch for sure , prolly sooner than later as ment'd trevor 's car is here already and just waiting for break in mileage to get his ecu's to you , hopefully you'll give us some sorto break on pricing if we do a few 2-3-4 cars together ! Much Thxx for your time NEIL Last edited by LI-M5; 08-27-2016 at 03:00 PM.. |
08-27-2016, 03:34 PM | #75 |
GLG-20
201
Rep 375
I too am interested in a flash, no piggys for me. I am not interested in drilling though.
Can you provide some more detail, and maybe some before and after pics of the alternative method of opening them up? |
08-27-2016, 04:48 PM | #77 |
243
Rep 881
You can either drill or cut the sealant material open. Most tuners will prefer to drill since its quicker. MissionPerformance can do both; I'm sure BPM has the same capability.
08-27-2016, 05:37 PM | #78 |
30
Rep 105
A little update, I put 3 gallons of e85 in and filled up the rest of the tank with 76 91. Had traction control going off in 3rd or 4th at 80mph...the car pulled stronger than yesterday.,maybe it's adapted more now.
08-27-2016, 11:14 PM | #80 |
30
Rep 105
08-28-2016, 12:20 AM | #81 | |||||
3392
Rep 7,544
And yes, to confirm, my car has never had a Drivetrain Malfunction in almost 10K miles, nor has the M5 I had prior to this one which was a 2014 with the mechanical wastegate. Any Drivetrain malfunctions would be as a result of an issue with the coil, plug, injector, or sensor, and not due to the software changes themselves. Quote:
Drilling is much safer, and the way we do it ensures that no shavings enter the internals of the DME, as they are drilled upside down while being carefully vacuumed. At your request we can open them instead of drilling, but we strongly advise against this for safety and longevity reasons. For the drilled DME's, we have a specially designed press fit high temperature seal that will ensure the DME's stay clean and secure for years to come. You might have to bring it back to be detuned! Glad you're enjoying it!
08-28-2016, 07:12 AM | #82 | |
GLG-20
201
Rep 375
Mike thank you as always for the thorough and articulate responses to questions. Sounds like upside down vacuum drilling is the safest way.
08-30-2016, 04:12 PM | #83 | ||
3392
Rep 7,544
08-30-2016, 09:51 PM | #84 |
Command Sergeant Major of the Army
142
Rep 639
Mike, do you have any packing tips once they're removed for shipping - bubble wrap or anything you recommend to keep them intact? Blue tape maybe covering the connectors?
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
08-30-2016, 11:55 PM | #85 |
1744
Rep 3,205
This is definitely tempting. Subscribed for more reviews. Still breaking in the beast so I figure I still have some time to research lol...
08-31-2016, 08:51 PM | #87 |
142
Rep 639
haha...still a month or so away brother, but it's going to happen.
Country Run here I come.
2018 F82 M4 ZCP
