BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > CODERS E90 E91 E92 E93 in UK
      11-30-2021, 05:01 AM   #837
mburns02
Drives: BMW E92
Hey, looking for help with diagnosing a starting issue with my E92 (possible DDE fault) either available remotely (I have ISTA) or local to the North-east (Stockton-on-Tees specifically)
      12-14-2021, 01:35 PM   #838
whitep
Drives: 2007 E91 220d Tourer
HI All, Can anyone help me code an injector if I install it? I simply cannot get inpa to work.
I am near Colchester.
      01-20-2022, 10:35 AM   #839
John the Hat
Drives: BMW 325 SE
I have a small problem. I have the Bimmergeek's software installed and I seem to be able to connect to the car (2010 325i E97) but I can't download the vin either in NCS Expert or in INPA. In INPA I get both battery & Ignition "spots" in black but the cable seems to drop the connection after a while & the Ignition one goes out.
Error typically:
Error in EDIABAS or in SG description file IFH-0003: Data transmission HOST/Interface CAS disrupted
Error COAPI4.CPP coapiReadOrder 4
[14:56:21.960] [2022-01-20] [SERIES] Error in EDIABAS or in SG description file FA_READ: A_E65CAS
That looks like a communications issue to me. Anyone know how to test the K+DCAN cable ? I have one off E-Bay which CLAIMS to be INPA compatible but I seem to have the com port set up on Windoze fine (although I am going to do a clean re-install in case it is messed up somehow). Failing that, anyone Cambs / Beds way have a known good cable we could test against ?
I am goingto crack this EVENTUALLY :-)
      02-09-2022, 05:00 AM   #840
razvandvl
Drives: E90 320d 2009
Hi,
Anyone can help me with some coding for a 2009 320d?
I need some advanced ones like I want to change the steering wheel, add cruise control, code a new key etc.
Anyone around London, Essex?
Many thanks,
Raz
      08-03-2022, 03:08 AM   #841
Divszy
14
Drives: BMW E92 335i (N54)
Looking for someone who can code around the west midlands, closer to coventry the better... Id like to have my front PDC's recoded (lost the coding when the headunit had to be replaced)
May also look at injectors in the future, too.
      08-31-2022, 05:17 PM   #842
marklee77
Drives: bmwe91 nissan s14,500hp v70
looking for someone to code in noxem in kent orpington br6 area
      10-10-2022, 05:58 PM   #843
istilllooking2003
Drives: BMW 325i
Hello everyone,
I am new to the forum. Would someone please help me out with the following problem?
I have a bad MRS or Airbag module. I picked up one from the junkyard that I would like to work with my e90. I have downloaded and install NCS/INPA on my computer. Would someone happen to know of a step document or step video performing this task?
Is there someone out there that could do this remotely and I watch?
Thank you in advance for any advise.
      11-04-2022, 03:47 PM   #844
Matt_E90
Matt_E90's Avatar
Drives: BMW 330d M Sport
Aberystwyth, Wales.
Can offer basic coding (still learning)
I can also offer help with retrofits, wiring etc
      12-04-2022, 11:38 AM   #845
Arch Stanton
49
Drives: BMW 335i touring
Any coders in the NW (Ideally Cheshire or North Staffs) areas that I can DM with?
      04-10-2023, 01:51 PM   #846
Lazygit
Drives: 320d SE Business Edition
Programming
Hi, could you code this DAB unit if I can fit it to my 2010 E91 LCI, please?
https://www.facebook.com/marketplace...40626896661393
Thank you
      08-04-2023, 09:42 AM   #847
dengeniul
Drives: bmw 3 series e93
Hello, is someone relatively local in the southwest who knows how to code? I just need a cd changer coded in so I can use my MMI box. Thanks
      02-12-2024, 07:12 AM   #848
ageekinthecity
Drives: BMW 325i Coupe
Can anyone in south-west London help me coding the AC Control Panel from the LCI version into the older version?
Thanks!
      04-18-2024, 07:12 PM   #849
Avilock
Drives: BMW 318i
Is makkan00 still coding?
