DYI: Easiest way to get 1b file and generate FSC codes for CIC navi map update
11-12-2022, 01:58 PM | #837 | |
242
Rep 1,353
That will cause the unit to try to execute the script each time the USB is found and never get to the updates! For best results reformat the drive as Fat32, load the update files to it again then insert. Also isn't your 1b file too large??? See: https://www.bimmerpost.com/forums/sh...php?p=18314028 |
11-29-2022, 01:31 PM | #838 | |
Rep 2
My 1b file is 319bytes I think my Windows 11 just defaults to showing 1kb if the file is smaller |
11-30-2022, 12:36 AM | #839 |
Rep 26
Hi everyone, just picked up an 09 335i and cannot get FSC code to generate, always get file corrupted error. The 1b file I pulled is 319 bytes but is not being accepted by the generator app. The iDrive unit is updated and should be able to accept map updates via usb (checkmark/i symbol on nav). I read about repairing corrupted 1b files using hex editors but I am not sure. I used the app last year to generate a lifetime code on my 2011 so it must be an issue with this car.
2011 335xi N55 6AT FBO + 2009 335xi N54 6AT BONE STOCK
12-03-2022, 11:37 AM | #841 |
Rep 26
Not a retrofit, car is an 09 with CIC but was updated by dealer in 2011 so it should be able to take USB updates. The 1b file I get when viewing in hex is pretty garbled.
Build date was 09/08 so one of the first CIC E90s. Looks like the script doesnt work well on earlier cars. Last edited by darkfires102; 12-03-2022 at 12:03 PM.. |
12-03-2022, 12:20 PM | #842 | |
Rep 26
12-06-2022, 09:37 PM | #844 | |
Rep 1
12-07-2022, 11:00 PM | #845 |
Silent OPerator
Rep 37
Found the V1.91 thanks for mentioning
LEV
2011 ///X5 M package/all possible options Last edited by matyoka; 12-07-2022 at 11:46 PM.. |
12-08-2022, 09:24 AM | #846 |
Rep 6
Would this work on an 02/09 LCI E90? I don't have the tick / I in the nav. Would I still be able to update with USB or would I have to use the DVD (I only have the 1 disc slot on the professional system)
12-08-2022, 09:29 AM | #847 |
10543
Rep 41,205
Drives: 2018 Alpina B6 650ix GC
No Tick, No USB Update.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
12-08-2022, 09:59 AM | #848 |
Rep 6
12-08-2022, 10:03 AM | #849 |
10543
Rep 41,205
You would need DVD, BUT, firmware is so old, it's likely update would fail without firmware update, so DVD version likely useless.
MM3390.00 |
12-08-2022, 10:19 AM | #850 |
Rep 6
12-08-2022, 10:24 AM | #851 |
10543
Rep 41,205
Well, your entire car is running 13-year-old firmware...I would expect programming car would provide more benefits than just map update...
12-08-2022, 10:26 AM | #852 |
Rep 6
12-10-2022, 05:27 AM | #853 | |
spectator
81
Rep 507
USB updates work with AU cars without the Tick. It may be the same for UK cars. My 09/2009 E90 LCI has never had a tick on the Nav, and I've updated the maps 3 times using USB. Here's my experience (I had a problem with the generic/incorrect VIN of "1234567" in the 1b.hex file, but used a workaround instead) https://www.e90post.com/forums/showp...&postcount=306 |
MM3390.00 |
12-22-2022, 03:07 PM | #854 |
1078
Rep 1,959
Drives: E90 M3 LCI Jerez Black
2023-1 is now available but the XML file doesn't yet include this version. But IIRC correctly, it is easily added to the XML lookup file?
Found it on the other thread
12-22-2022, 03:12 PM | #855 |
10543
Rep 41,205
Yes.
12-24-2022, 07:47 AM | #856 |
12
Rep 30
No USB in globebox
Hi all,
I'm trying to get a 1b.hex file from my bmw 2012 f30 and it does not have a usb in the glove box. It has a CIC idrive system. Am i still able to generate a FSC code? |
12-24-2022, 07:59 AM | #857 |
10543
Rep 41,205
What is short VIN (last 7)?
Tags |
cic and idrive, cic code, fsc code |
