Bimmerlabs 330i Tune DIY Step by Step
12-22-2022, 04:06 PM | #793 | |
Rep 38
Okay well the vehicle developed a no com no start. Couldn’t connect through inpa or ista after the flash. I feel like I’m very tech savvy, built my own gaming pc after all. I followed all the instructions to a T. Like I said, the only differences were I was using a trickle charger, an Amazon cable, and a MacBook laptop running a windows 10 partition on the hard drive. It flashed the RSA delete fine but when flashing the 325i to 330i batch file it gets disturbed then a bunch of errors pop up and car would not turn back on after that. No lights on the dash, nothing. Even with a new battery I was not getting power to terminal 30, relay that wakes up cas module. Tried to flash back to stock and nothing happens. No connection to the car. Took it to the dealer and they couldn’t even figure it out and recommended that I needed to buy a new dme cas and keys to get the car to work and wanted to charge me more than what I bought the car for, so I junked the entire car. I’m willing to throw $100 at someone to remotely do it for me if possible. Last edited by E90_slides; 12-22-2022 at 04:17 PM.. |
01-26-2023, 12:18 PM | #794 |
vegasbmwlover
Rep 2
hey bud, how's it going? So i have a 2008 bmw 328i coupe. It has the GM1912 trans module. VIN# WBAWB3353p131856
Im new here not sure how to add photos or screenshots. I successfully added the rsa delete, and the 328i-330i tune. But my DME is giving a no coding error and there isnt a ZB# next to the UIF data from inpa. Everything in the car is running smooth though, and disa flaps are working so i know tune is there. My question is can i run this 330i euro flash ZB#7587776 from WINFKP? or do i need the specific Opa and Oda files with it? |
02-23-2023, 01:32 AM | #795 |
Rep 2
HI guys, After use the Bimmerlabs provide 2 stock tunes get the problem, my car is 08 E61 LCI 530XI, after tuning my engin can't start, i use the two program to tuning but they are not working. the battery are good, after tune i also use inpa to remove the error code. but the engine are stell not work. So What may i do to revert original state and start the engine? thanks
The two different stock tunes are https://www.e90post.com/forums/attac...1&d=1677137608 Last edited by Josh Hsiao; 02-23-2023 at 01:40 AM.. |
02-27-2023, 08:01 AM | #796 | |
33
Rep 35
The first time I looked at the Bimmerlabs table, I thought everything on one line was just different file-formats of the same tune and I only flashed the "program" which led to a crank-no-start. |
03-02-2023, 08:29 AM | #797 |
BMW Enthusiast
39
Rep 30
Hello! Is there any way I can get this files? I really what to try it. I know it's been gone for a while I read al the thread hahah. Maybe someone has it
08-03-2023, 04:15 PM | #798 |
Rep 4
Drives: 2008 BMW 328xi
Hi, new here
Bimmerlabs is down and I’m looking for 3IM tuning software from bimmerlabs to upgrade from 328xi to 330i 3IM tune, really grateful if anyone has a link or files I can download Thanks for your time -Kenny |
10-03-2023, 05:05 AM | #799 |
35
Rep 62
I’ve tried the RSA delete and got a few errors, also with the bimmergeeks site down. I’m now in a pickle. After trying to install the stock tune from the file. The car wont crank at all. I’ve just spent a few hours communicating to and fro. But nothing works. I tried NCS to default code the modules back pre RSA delete. But not getting any response any more.
How do you go back to pre RSA delete?
Ultimate Driving Experience........
01-23-2024, 05:24 PM | #800 |
Rep 7
I have a question for my more experienced colleagues.
After a successful transfer from 328i to 330i, both physically with the manifold and programmatically with the ready-made software from BimmerLab, I wanted to simultaneously update my GM GA6L45R also using a ready-made file from Bimmeslab via WinKFP, similarly to the engine map change. The file downloaded from Bimmeslab for the gearbox is successfully loaded without any errors, but it is not possible to shift gears from P to D or anything else, and P is not displayed on the dashboard. It seems like there is no communication between the car and the gearbox controller after installing the dedicated file from the BimmerLab website. The WinKFP program automatically starts transmission after enabling the .bin file. What am I doing wrong? |
01-23-2024, 07:18 PM | #801 |
Rep 7
02-06-2024, 02:22 PM | #802 |
Rep 2
auto or manual
hi William, is your e92 328xi is it an auto gearbox, or manual? so I've ran this tune on n52 engines only all manuals, but rn I have a 08 n51 and I can't seem to find a bimmerlabs tune for it when I ran the vin only stock ones, which is weird because I found a rsa delete, and then two stock files so naturally i'm wondering if running the mafless tune on this engine would work, it came from factory with 3sim but a tune for 230hp (smh) im just wondering if the fact that the manual gearbox tune on a auto car would have any other horrific consequences other than losing cruise control, if it fails I can always just revert back with the stock files I found,so I don't see a downside in trying it out, really want to go for it just need to hear your opinions first
02-06-2024, 02:29 PM | #803 |
Rep 2
hey sounds like you bricked the car, when youre running winkfp make sure bootsectorupdate is not activated!!!
run the rsa delete again after you have corrected the winkfp bootsectorupdate debacle and make sure the dkan cable is linked properly with the rate being 1:1 not 16:1 make sure you save these changes too so you dont have to do it every time, then run the tune again. just curious can you send a link for the tune on bimmerlabs because i have an 08 328xi that has the same transmission, maybe i can try it out and tell you if its the tune thats wrong |
05-04-2024, 10:44 PM | #807 |
83
Rep 251
Drives: E82 N52 6MT A51
Thanks E92William and hassmaschine. Just flashed my manual 128i to 130i. Install went extremely smooth. Not a single error on car and pc . Will be installing the manifold soon. The car pulls noticeably harder with just the tune and I experienced no draw backs. Cant believe a $50 cable and an awesome car community got me this
