02-20-2014, 10:18 PM | #45 |
74
Rep 348
Audi put awful brakes on the S4 to slot it well under $50k. I've improved a ton in the last 24 months regarding not over braking. I think the first time you go out with good brakes you just want to stand on them to see how far they can go before fading. Eventually your tires overheat and inflate up to 50 PSI, and that game ends.
WTB: 2016 M3 sedan, Black Sapphire, Extended Sakhir Lether, Ceramic Brakes, 19" black wheels, Lighting Package, HK sound, USB/Bluetooth
Sold: 2006 e90 325i 6MT, ground control coilovers, Remus exhaust |
02-20-2014, 10:19 PM | #46 |
21133
Rep 20,742
Drives: 2021 911 turbo
A 85mph front straight , that's a pretty slow track. Or maybe your FI german super sedan isn't that fast .
02-20-2014, 10:29 PM | #48 |
Driving Mika all over California.....
57
Rep 619
The last one went 13 pages. Only 4 were slightly on topic. I didn't help much and I apologize for that.
2008 E60 M5 Sepang Bronze Metallic, gloss black grills and gills, LED side markers, 12mm spacers all around, stud conversion kit, custom exhaust with Magnaflow mufflers and x-pipe.
02-20-2014, 10:30 PM | #49 |
555
Rep 2,633
02-20-2014, 10:30 PM | #50 |
21133
Rep 20,742
02-20-2014, 10:35 PM | #51 |
57
Rep 619
Very true! I just don't want to get into any more pissing matches. I don't know every single thing about the world of car racing, but I am certainly interested in knowing and I have the ability to listen when being taught by someone more knowledgeable. I have done plenty of track days, but mostly those were in the track owned cars. My main experience on the track is on a motorcycle (R6 and Aprilia Tuono) and that is a completely different world. I do agree that the exec pack is a waste of money that I would rather spend on the trip to Munich!
02-20-2014, 11:18 PM | #52 | |
612
Rep 10,407
You know that CSiC brakes being significantly lighter in turn have less thermal mass, right? Lower thermal mass absorbing the same amount of energy makes for a larger temperature rise. Now that's not the end of the world as the first thing temperature will affect will be braking power from a pad that can not maintain friction at a very high temperature. Luckily that is always sorted out well with a CSiC brake rotor as it has a pad matched to the temperatures that will be generated. In addition, BMW has for generations, used a compound brake rotor on M cars. These have the actual brake disc mounted on pins connecting to a lightweight aluminum hub. This allows for radial thermal expansion with much less tendency to warp. It also radically reduced the thermal pathway to the hub preventing temperatures in excess of what the wheel bearings can handle. Really the only way to cook wheel bearings on an M car is one and/or the other of: -Really poor braking skills or downright abuse -Running R-comp tires, that is what will really give a brake system a workout CSiC brakes make more sense for a lightly used street only car. In that case it is not so much braking performance that is gained but simply longevity and a lower unsprung weight. At the much higher temperatures seen during tracking the wear in the CSiC even with their appropriately matched pads is significantly accelerated. Thus for hard use and to minimize total long term cost, the regular cast iron rotors come out way ahead. As others have stated the best upgrades for braking are simply some upgraded pads, some top notch brake fluid and R-comp tires. Carry on...
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
02-21-2014, 12:07 AM | #54 | ||
Law Enforcer
25306
Rep 22,326
Drives: '22 Chalk Gray Porsche C2S
02-21-2014, 12:31 AM | #55 |
74
Rep 348
I measured a few 911 turbo with CCB coming off track in the instructor group. The temps were consistently lower, sometimes under 300 F. I was blown away. The S4 size cars come off minimum 500 degrees, 580 if you are cooking it.
02-21-2014, 01:05 AM | #57 | |
74
Rep 348
02-21-2014, 01:15 AM | #58 | ||
83
Rep 377
So i'm guessing it was in his advance to just let me order them also. |
02-21-2014, 01:56 AM | #59 | ||
612
Rep 10,407
There is no universal here, it is not that CSiC brakes are always hotter or always cooler. It is just that their thermal mass specifically makes them warmer than if they had more thermal mass. Quote:
Are you saying that all parts of a brake and hub system including rotor, hat, pads and hub are all at the same temperature during heavy braking? You might notice that one can also cook in a cast iron pan under very high temperature and that the handle of the pan is still handleable. Same thing applies to brakes, different parts reach different peak temperatures because of both conduction and convection cooling. Either way my original points stand. 1. Normal heavy track use with traditional rotors does not cook wheel bearings and 2. CSiC brakes are not the best choice for hard use due to accelerated wear and very high cost.
02-21-2014, 02:09 AM | #60 |
74
Rep 348
All your points are believable except for "accelerated wear". As compared to what? The pyramids? They might only last a few hundred thousand miles.
02-21-2014, 05:36 AM | #61 | |
21133
Rep 20,742
CCBs have better heat dissipation capabilities than cast irons, so they cool down faster (this is why they have better resistance to fade). But while in operation (during braking), they do run much hotter than cast iron ones. |
02-21-2014, 08:44 AM | #63 | |
593
Rep 5,396
this
02-21-2014, 08:46 AM | #64 | |
593
Rep 5,396
race pads and fluid will be all 99% of us need on the track with this car, myself included. I expect the brakes with these minor mods to perform very very well
02-21-2014, 08:54 AM | #65 |
187
Rep 722
Drives: 2011 M3 Sedan
Devil's Advocate:
Why assume the OEM "basic" brakes with the traditional M brake discs won't be good enough? (I worded my first post poorly, and paid the price...)
Dave Flogaus CCA #123862 11 E90 M3 Sedan DCT 94 E36 325is M-Tech (S50) Last edited by davem3fan; 02-21-2014 at 09:08 AM.. Reason: incomplete information |
02-21-2014, 08:58 AM | #66 | |
593
Rep 5,396
I completely agree with you. The only mod to make if you are a pretty quick driver and track often is race pads and upgraded fluid. Even on the e9x this is sufficient for most drivers, and these new 4/2 piston brakes should be far superior to the old sliding single caliper design.
