Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > N54 Dyno Chart Compilation
      12-10-2010, 10:28 PM   #45
s2k_335i
This is it!!
s2k_335i's Avatar
No_Country
16
Drives: FBO 335i without meth
Originally Posted by gbreeE90 View Post
Your numbers are very low for your mods, why did you remove IC?
The last time i ran this with the AMS FMIC, its was 370-380. I dont think the IC made up 60 hp. I sold my IC to my buddy.
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang.
      12-14-2010, 02:45 PM   #46
Doug007
Drives: Spacegrau 2009 335i 6MT
If HP and TQ are on the same scale they will always cross at 5252 rpm.
If, however, the scaling is different they will cross somewhere else. The dyno on the top of page 2 has HP on a 0-350 scale and TQ on a 0-400 scale and the curves cross at about 4700 rpm. Plot them both 0-400 and you would be back to crossing at 5252rpm.
Originally Posted by LaLakers91tc View Post
they shouldn't ever cross at any other number....
HP is a number derived from Torque (foot pounds) x RPM / 5252
Thus at 5252 on every graph, torque will equal hp
2009 Spacegrau 335i
      12-14-2010, 03:15 PM   #47
R1000K3
R1000K3's Avatar
56
Drives: 335i MT
Originally Posted by Quisp View Post
I guess that makes sense to a degree, but the Dyno Dynamics one crosses under 4000 which wolld mean quite a large variance. Is there some other factor that would chnge the 5250 number?
The only factor that will make hp and tq values to cross at any other rpm than 5250 is when the torque is measured Metric units, i.e. Nm. The rpm crossing point will then be 5250*1.356 = 7120 rpm.
      12-14-2010, 07:53 PM   #48
Quisp
Does not play well with others
80
Drives: BMW
Thanks for clearing it up.
      12-15-2010, 03:19 PM   #49
m54b25
Drives: exM3, exX5, 335i, C63 RT
Originally Posted by bigdog34uz View Post
These are some really high numbers for just a tune. Are all these on legit dyno's just curious. Mild Flash tune doing 344 with 364lbs of torque is high! I want those numbers. I want to do wife driving.
Yes, feel free to come to come to the dyno! The 1st dyno was done at the BMW Pembroke Meet... the new 15th run was retuned on 93octane Chevron 12-01-10. Just PAW Mild tune got better +10whp on stock car using barelly 14psi tapering to 8psi!
Users with the same tune on another E90 335i Steptronic w/10k RTF tires & full tank of gas has done 12.746@107.77Mph just with this tune.
File Type: pdf PAW E90 Stock 335i Mild Tune Got better.pdf (67.8 KB, 427 views)
File Type: pdf PAW E90 Stock 335i Mild Tune Got better STD!.pdf (67.7 KB, 425 views)
      12-29-2010, 02:20 PM   #50
timo1980
11
Drives: 135i
07 335i coupe with procede and dual cone intake
07 335i coupe with procede and dual cone intake dyno graph(done at topspeed atlanta)
      12-29-2010, 08:41 PM   #51
My2Cents
My2Cents's Avatar
Drives: 2007 BMW 335i Sedan
2007 335i e90 6MT. Dyno'd on Mustang Dyno.
Baseline:
Fully stock
4th gear pull
72 degrees F
91 octane
253.9 hp
247.7 Ft-Lbs.
Mod'd results:
Dinan stage 2
Dinan exhaust
K&N drop in filter
4th gear pull
62 degrees F
91 octane
291.1 hp
310.9 Ft-Lbs.
Gain of:
37.2 hp
63.2 Ft-Lbs.
My stock tq seems low. Most other stock numbers I have seen have been much higher than the hp number. Also my hp gains appear to be a bit low. What do you guys think?
      12-29-2010, 09:10 PM   #52
BrianMN
114
Drives: 4 Door Family Sedan
All around it seems pretty low for stage 2, but it is still conservative and on a mustang.
      12-29-2010, 10:35 PM   #53
jaybird124
jaybird124's Avatar
157
Drives: 2017 M3 ZCP
Sweet gains!
'17 M3 Imola Red/Carbonstructure Cloth, Competition, Lighting, 6MT
Retired: '93 325i |'99 Jeep Wrangler Sport |'06 330i Sport |'08 335i Sport |'08 328i Sport |'09 335d Sport
      01-09-2011, 11:12 PM   #54
Penn999
Penn999's Avatar
50
Drives: 335i coupe
Stage 3 mods, 100 octane. (no meth) at 16psi. Mach V Dynojet(Blue) SAE. Bone stock 335i on 93 pump, same day, same dyno, also SAE. Why does almost everyone on here use STD....makes no sense. Use SAE. CORRECT THOSE NUMBERS....Since everyone else has STD here is a second graph with the same run only in STD. Gotta compare apples to apples.
07' MT, Quaife LSD, BMW Performance LED Steering Wheel, HPF FMIC, AA BOV, HPF Exhaust, DCI, Procede V5, AR Stage 1 oil cooler, AR OCC, AR CL DP's, Vishnu Meth Kit, UUC SSK+DSSR, UUC Shift knob, (19 inch)VMR V715's/Yokohama Advan AD08's, Hartge Pedals and Floor Mats. Awaiting Install: M3 Rear Subframe Bushings, Full M3 suspension bits, AST 4100's, DSS axles. Future plans: Vishnu Single turbo kit
      01-09-2011, 11:14 PM   #55
RS LED
RS LED's Avatar
13
Drives: E92
Injen intake
AR downpipe
HKS cat back
Vishnu V4
91 octane
I mess up with map, i switch around before dyno
but the numbers came out kinda low ...
any suggestion or commend?
run 1 map 1
run 2 map 2
run 2 map 2
      01-11-2011, 03:00 AM   #56
ETS Michael
ETS Michael's Avatar
76
Drives: 335i
Stock Baseline
Procede Baseline (Autotune) V5 12-17 maps
Bone Stock.
Talk about a power change... It's amazing how the v5 transform the car without doing anything. This car is bone stock and makes amazing power and torque with no other mods. I will post up the rest of the runs with full bolt ons and step by step graphs shortly.
Michael
      01-11-2011, 09:58 AM   #57
Penn999
Penn999's Avatar
50
Drives: 335i coupe
Originally Posted by ETS Michael View Post
Stock Baseline
Michael
I look forward to seeing those graphs of the step by step bolt on process. What psi was that full bolt on 92 pump number on. Also, I would like to see that graph. I havent updated to the V5 bc these new maps that are coming out soon...any eta on those. Robert said they should be out this week or next week right?
      01-13-2011, 03:29 AM   #58
RS LED
RS LED's Avatar
13
Drives: E92
What octane was it ?
Stock Baseline
Bone Stock.
Michael
      01-14-2011, 11:17 AM   #59
ETS Michael
76
Drives: 335i
92 pump gas from Chevron. We made 400 on pump with all the bolt ons.
      01-18-2011, 02:14 AM   #60
Naptime
#Hashtag
Naptime's Avatar
Drives: around in circles
Any pics of the exhaust?
      01-26-2011, 09:33 PM   #61
ultimateracing335
ultimateracing335's Avatar
Greece
35
Drives: blk 335i sedan with mods
Ultimate Racing exhuast
Ultimate Racing downpipes
Ultimate Racing intake
Ultimate Racing bov
Jb4
Cooling mist dual cm7
Pump gas with 70 percent meth 30 percent water.
RB turbos
      01-26-2011, 10:43 PM   #62
BrianMN
114
^ Holy cow that's a ton of power! You nearly held 500ft/lb of torque for a 4,000rpm range! And that's with stock turbos, on pump gas? I mean dang, that is extremely high.
Could we see some datalogs? Not questioning or anything, just like to see how it ran
      01-27-2011, 12:25 AM   #63
ultimateracing335
Greece
35
Sorry Brian I forgot to add the RB turbos to to the list of mods. Data logs are on n54 tech and the tuning is a work in progress. Im having some fueling issues. NEED MORE FUEL!!!!
      02-02-2011, 04:12 PM   #64
san6279
Drives: 2007 335i
Car:
e90 07 AT Sport Pkg
Mods:
Dinan Stage 2, CAI, Intercooler
Conditions:
Temp: 58 deg F
Hum: 12%
Dyno: Dynojet
Gear: 4th
Max HP: 299
Max Tq: 340
Max Boost: 14.35 psi
Numbers seem to be in line with what others are reporting, although max HP is quite a bit less than RWHP reported by Dinan @ 342. Dinan stock RWHP was 296. Also, their max flywheel Tq reported 421 at, deduct 15% for driveline (can you make that adj for Tq, same as hp?), call it 366. Dinan reports max boost at 13.2, so not sure if readings on this were accurate or not. These Dinan numbers w/o CAI or intercooler, which probably don't make a big diff anyway at the dyno. Generally happy with the car. A bit disappointed in the numbers.
      02-03-2011, 11:51 AM   #65
acj75
acj75's Avatar
37
Drives: '07 E92 335i
Baseline:
Fully stock
4th gear pull
72 degrees F
91 octane
253.9 hp
247.7 Ft-Lbs.
Mod'd results:
Dinan stage 2
Dinan exhaust
K&N drop in filter
4th gear pull
62 degrees F
91 octane
291.1 hp
310.9 Ft-Lbs.
Gain of:
37.2 hp
63.2 Ft-Lbs.
Originally Posted by san6279 View Post
Car:
e90 07 AT Sport Pkg
Mods:
Conditions:
Temp: 58 deg F
Hum: 12%
Dyno: Dynojet
Gear: 4th
Max HP: 299
Max Tq: 340
Both of these seem a little low to me for a stage 2 Dinan tune. I just had my Dinan Stage 1 dyno'd a week ago on a Mustang at the local Cobb shop. I didn't get to do a stock baseline, but I added one at random from their database to this chart for comparison. Max boost on my car was 11.2 psi:
'07 E92 BMW 335i
      02-03-2011, 12:35 PM   #66
san6279
Drives: 2007 335i
Thanks for the response. Wish I could load my graph. I only have a paper copy and no ability to scan right now.
One thing I'd like to add is info on air/fuel. It shows at about 15 from 2K to 3K and then tapers down to 12 by about 4.5K rpm. Is that normal?
I know, in general, there can be variations between dynos and even day to day, but just seems a bit low compared to some others I've seen online....and definitely from what Dinan reports.
Unfortunately I don't have a baseline to compare to.
Am considering sending the info to my SA to see if it is worth having Dinan take a look. I would expect a canned response, but no downside to asking.
