Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions BimmerUtility?
      04-26-2022, 03:20 AM   #45
antond
Drives: G21 330e Xdrive
This is all a bit confusing to me, I've coded a few things back in the day with a TokenMaster token on my f10 but it seems like the game has changed in those years.
Is this assumption correct:
All I need to code my soon-to-arrive G21 MY2021 is:
- A 64-bit Windows laptop
- OBD-Ethernet adapter
- BimmerUtility license
- recent ESYS
- recent PSZData
I'm specifically thinking about coding LCA, TLA, ASD menu (330e so should come with active sound design), B&O menu (I have HK), Comfort+ mode
Or do I need anything else?
      04-26-2022, 05:35 AM   #46
shawnsheridan
shawnsheridan's Avatar
10545
Drives: 2018 Alpina B6 650ix GC
- recent ESYS
- recent PSZData
That's all you need.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
antond3.00
      04-26-2022, 05:48 AM   #47
antond
Thanks man!
Off to buy a laptop and a license I go, then.
Can you please PM me the links to the last 2 items in the list?
edit; sorry for asking but... do you happen to have promo codes available for a bit of discount?
(if not, you should ask them, because you surely must drive quite a bit of their sales).
      04-26-2022, 07:12 AM   #48
shawnsheridan
10545
Thanks man!
PM sent.
antond3.00
      04-27-2022, 04:24 PM   #49
shawnsheridan
10545
Originally Posted by Bambazonke View Post
I am working on one specifically for "G" series models the problem is my version of Launcher Pro does not allow me to interrogate to Depth 2 level to reveal the start, end line values and the mask allocation. I am presently awaiting for another Forum user who has ESys Expert to supply the information before I can release it to the public domain
Cheat Editor Added to BimmerUtility:
Appreciate 2
Almaretto2376.00
      04-27-2022, 06:31 PM   #50
Bambazonke
Bambazonke's Avatar
Australia
215
Drives: 2017 X5, 2020 X5 & 2021 X5
  [0.00]
Excellent thanks Shawn how do I upgrade my current version of BU to the above
Current: MY 21 X5 3.0d xDrive MSport
MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive
      04-28-2022, 07:16 AM   #51
shawnsheridan
10545
BU upgrades (if available) automatically each time app is Opened. Just close and reopen the App.
srbs73560.50
      04-28-2022, 07:39 PM   #52
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
      04-28-2022, 11:29 PM   #53
hayko_M340
141
Drives: 2020 BMW M340I
Does anybody know if Bimmer Utility will be able to code in M related HUD options as well as shift lights on G chassis cars? Link to thread who was able to do it remotely and no need to change module as many stated before as it was done on a X3 M40i which I'm 99% uses same HUD and Live Cockpit Pro found in G20's specifically M340I. Not asking for FULL M Options such as Vertical Track Display found on G80 M3, G82 M4, etc. I know you need a different module for those. Currently have M display with redline etc. but lost shift lights and all options in HUD besides speed which many people are on the same boat. Any help or feedback is greatly appreciated!
https://g20.bimmerpost.com/forums/sh....php?t=1716624
      04-28-2022, 11:34 PM   #54
Almaretto
Almaretto's Avatar
2376
Bimmer Utility will be able to read the necessary modules and make changes if you know which parameters to code.
      04-28-2022, 11:39 PM   #55
hayko_M340
141
That's the issue, people have been able to accomplish it but no one is willing to share the parameters and what needs to be changed even though the hardware is similar if not the same across a wide range of models.
      04-28-2022, 11:45 PM   #56
Almaretto
Almaretto's Avatar
2376
Bimmer Utility has NCD compare function, so you could always generate NCDs from different models, compare, and experiment.
TJZ67201847.50
      05-04-2022, 02:51 PM   #57
Marcelo_BSB
29
Drives: 328
Hello guys. bought the Bimmer utility, installed everything. But when I click on the E-sys connect button or where the various bmw models should appear for me to choose is blank. Did I forget a step?
Sorry for the english, but it's the translator.
      05-04-2022, 03:00 PM   #58
shawnsheridan
10545
If the "Open Connection" window under "Target" is empty (no targets), verify the following:
  1. That the "psdzdata" folder is installed properly (From the PSdZData_Lite or PSdZData_Full extraction, copy the "psdzdata" folder to "C:\Data" (i.e. "C:\Data\psdzdata")
  2. That the psdzdata chassis folders each have an empty "dist" folder. Make sure that there is an empty "dist" folder in each of the psdzdata chassis folders, and if missing, create as needed, e.g.:
    • C:\Data\psdzdata\mainseries\F001\F001_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F010\F010_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F020\F020_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F025\F025_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F056\F056_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\I001\I001_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\K001\K001_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\KE01\KE01_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\KS01\KS01_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\M013\M013_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\RR21\RR21_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\S15A\S15A_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\S15C\S15C_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\S18A\S118A_xx_xx_xxx\o dx\dist
  3. The the E-Sys "Options" => "Settings" => "Directories => Data: path" is set properly (e.g. "C:\Data")
      05-04-2022, 03:01 PM   #59
Almaretto
Almaretto's Avatar
2376
You need Psdzdata installed.
      05-04-2022, 03:12 PM   #60
Marcelo_BSB
29
Drives: 328
I will reinstall psdzdata. Thank you for your attention.
      05-11-2022, 04:44 PM   #61
panki_86
Slovenia
138
Drives: G20 M340i xDrive Individual
It is new esys out?
I have Esys 3.39.1 with BU and psdzdata 4.35.21.
In past i get FW 3/2022 at dealership on mine G20. Everything was fine with BU.
Today they (dealership) changed my GWS module and updated some modules.
Now i can read and code everything except BDC 7083 and 44ED.
When i read them i get error File for "cafd_xxxxxxxxx" not found (C012).
      05-11-2022, 04:47 PM   #62
shawnsheridan
10545
Originally Posted by panki_86 View Post
It is new esys out?
4.35.21 is latest, and just released.
Are you sure you deleted and replaced your psdzdata folder in c:\data with 4.35.21 psdzdata folder?
What is full name of both missing CAFD files?
panki_86137.50
      05-11-2022, 05:12 PM   #63
panki_86
Slovenia
138
Sorry my mistake. I have psdzdata 4.35.12.
I will try tomorrow with .21.
When you say "just released" i know i didn't update it recently
Thanks for fast answer!
I will report tomorrow if it works.
      05-11-2022, 06:02 PM   #64
jzsb
Drives: bmw 340i xdrive
May i receive the latest e-sys and psdzdata as well?
      05-12-2022, 10:40 AM   #65
shawnsheridan
10545
PM sent.
      05-12-2022, 01:47 PM   #66
panki_86
Slovenia
138
It is new esys out?
Ok, now it reads BDC_body3 7083 and 44ED, but i get "No mapping determined for this cafd" in BU.
So i need to wait for BU to support last mapping
g20
