Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Rear Diff Leak (2020 M340i xDrive)
      05-16-2022, 11:57 PM   #45
cyam
208
Drives: BMW M340i X (2020 G20)
I have been told by dealership its a leaking gasket and they are ordering parts to fix it under warranty. That's certainly different to the solutions mentioned here, but we'll see what they discover and do when they actually go to "fix" it.
Originally Posted by cyam View Post
Yes - have a 2020 M340i about 20,000kms on it and I have noticed some drops of oil under the rear diff. I have it scheduled for dealer to inspect/fix next week.
I am unaware of any ECU flashes/upgrades, I had the car serviced last week and they said no software upgrades were needed. Mind you I have only had the car a couple of weeks. It was due a service which was of no charge to me. They should have noticed the diff leak IMO.
Will let you know what they say after I bring it in.
      07-29-2022, 03:56 PM   #46
xnick101
652
Drives: 2021 BMW X3 M
2020 BMW M340i  [0.00]
Going back to the dealer next week for this issue. My diff is starting to make noise now under load. Probably because it's low on fluid and they won't replace it. I will update what the outcome is. This is visit #4 for the same diff leak issue.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD
2021 BMW X3M
jpowers36225.50
      08-04-2022, 09:22 AM   #47
xnick101
652
Update: BMW is FINALLY doing something. They ordered a new diff cover to see if it will resolve the leak as it's coming from the breather ports and the drain/fill plugs are dry. No dealer in the US had one in stock is what they said so they ordered it straight from Germany. They said to bring the car back in 3 weeks when they get the part in stock. But in the meantime, they topped off the diff fluid.
2021 BMW X3M
KyK102.50
      10-19-2022, 03:09 PM   #48
baturbo
"It's so choice...I highly rec. picking one up"-FB
baturbo's Avatar
Australia
48
Drives: 2020 M340ix
How did you go? Did this stop the leek? Mine was done yesterday and I hoping this will fix the issue.
      10-19-2022, 03:50 PM   #49
xnick101
652
Yes, it has completely stopped leaking fluid after they replaced the diff cover!
2021 BMW X3M
baturbo47.50
      11-02-2022, 05:58 AM   #50
viciousmo
viciousmo's Avatar
311
Drives: G80
Hey nick, do you have the part # from the work?
      11-17-2022, 09:14 PM   #51
bimmerstar
bimmerstar's Avatar
149
Drives: 2020 BMW M340xi
any update to this thread? My diff is leaking. same issue as everyone else. is there a TSB?
2024 G87 Zandvoort Blue M2 w/ Buckets - Stock 93| 0-60 TBD | 1/4 TBD | 60-130 TBD
2020 G20 Tanzanite Blue II M340 xDrive - E30 BM3| 0-60 3.28 | 1/4 11.39@123 | 60-130 9.56
Past:
2017 W205 Black C43 AMG - E40 FBO No Turbo | 0-60 3.21 | 1/4 11.18@124 | 60-130 9.17
      11-18-2022, 11:54 AM   #52
G30M
G30M's Avatar
3942
Drives: BMW M550i; Kia EV6 GT
does that mean that if one's diff is not leaking not to touch it?
i was thinking of changing diff oil at 5000 miles
      11-22-2022, 06:03 PM   #53
xnick101
652
This is everything from the work order
2021 BMW X3M
Appreciate 2
      11-22-2022, 06:05 PM   #54
xnick101
652
Go to the dealer and show them. There is no TSB as far as I can see but it's blowing oil out of the top breather holes on the diff cover. Replacing it with the newer super-seeded diff cover is definitely the fix. I have had zero leaks after it was replaced.
2021 BMW X3M
      11-22-2022, 06:06 PM   #55
xnick101
652
You can change the fluid. The leak is not from the drain/fill plug.
2021 BMW X3M
      11-22-2022, 07:05 PM   #56
bimmerstar
bimmerstar's Avatar
149
did they replace just the cover or the vent assembly as well? and drain plug?
Past:
      11-22-2022, 07:09 PM   #57
xnick101
652
I am pretty sure the vent assembly is on the diff cover, it goes along the top. They originally replaced only my drain plug and it was still leaking. They replaced it again I believe when they changed the diff cover.
2021 BMW X3M
      11-29-2022, 11:00 PM   #58
shawntech
The Wolf
shawntech's Avatar
256
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
I provided the solve and workup. My car was the test mule and it is still operating correctly.
      11-30-2022, 12:08 AM   #59
panki_86
Slovenia
136
Drives: G20 M340i xDrive Individual
I was yesterday at dealership for diff leak. BMW have PuMA document for M340i diff leak and solution is to change diff cover
      11-30-2022, 07:38 PM   #60
bimmerstar
bimmerstar's Avatar
149
please provide details. doc number, pic of doc etc.
Past:
      12-01-2022, 07:55 PM   #61
RLYSLO
Drives: 2020 G20 M340ix
Same, I went for an inslection service this morning and asked them to look at the diff. Confirmed breather issue and is booked for two weeks time to replace rear diff cover.
Also got flagged for tuned DME but they were cool as about it and asked what I was planning on doing mods wise.
      12-01-2022, 11:52 PM   #62
panki_86
Slovenia
136
I didn't took a pic or doc number, but i saw PuMA at dealership PC.
This PuMA is from 2021.
      12-02-2022, 08:24 AM   #63
bimmerstar
bimmerstar's Avatar
149
can you please grab a copy of paper work or anything to show bmw covers the leak
thanks.
Past:
      12-12-2022, 03:05 AM   #64
RLYSLO
thanks.
Will do, I just dropped it off then. Will pick it up tomorrow afternoon hopefully.
      12-21-2022, 01:57 AM   #65
hayko_M340
141
Drives: 2020 BMW M340I
Is everyone who is facing this issue Xdrive? RWD here and noticed my diff cover oily/grimy and possibly a drop or two on the ground. Right at about 40K miles. Wonder if there is a TSB for RWD models.
      12-21-2022, 01:33 PM   #66
xnick101
652
There is no TSB. It's an issue on M340i's and Supra's. It's due to the design of the breather holes on the top of the diff. I have a RWD M340i and BMW replaced my diff cover under warranty and it does not leak anymore.
2021 BMW X3M
Tags
b58, g20, leak, leaks, m340i, oil, rear diff
g20
