M3 vs Non-M Front Subframe
09-30-2020, 06:40 PM | #45 | ||
Cometh
1092
Rep 1,309
Drives: Boy's Soul
E90: 22,500 E93: 15,750 http://youwheel.com/home/2016/06/20/...ehensive-list/ There are no figures for the E92 but journalists reported that the E92 is 25% stiffer than the E90. It is not known how much of the increase in stiffness is due to the chassis itself or the additional bracing BMW added to the E92. Quote:
https://www.e90post.com/forums/showthread.php?t=78473 |
feuer4277.00 |
09-30-2020, 11:44 PM | #46 | |||
136
Rep 269
I have found this excellent document on the cars reinforcement effects. https://publications.lib.chalmers.se...391/219391.pdf One of the conclusions is that local lateral stiffness may have more effects on handling steering and ride characteristics than the global torsional rigidity. " The results presented in Section 4.2 show that the largest factor affecting handling and steering characteristics is lateral stiffness for front and rear, whilst camber stiffness front is shown to be the third largest factor. Global values for torsional and bending stiffness is shown to have a large affect on Primary ride, but very limited affect on handling and steering characteristics in relation to the other factors. " |
09-30-2020, 11:47 PM | #47 | |||
136
Rep 269
The Nightman1091.50 |
04-06-2021, 01:30 PM | #48 | |
53
Rep 81
I have done a 'how to' on BabyBMW which I am more active on. How to Fit the E9X M3 Belly Pan to the E8X 1er |
04-06-2021, 08:47 PM | #49 | |
3768
Rep 2,738
CalvinNismo53.00 |
04-15-2022, 01:36 PM | #50 | |
55
Rep 111
05-27-2022, 08:25 AM | #51 |
Rep 32
I ended up doing this with the original strut braces since I upgraded to the M3 one. Had to shorten them slightly and repaint them after flattening the ends to drill a new hole, but it worked out really well.
05-27-2022, 06:54 PM | #52 | |
3768
Rep 2,738
https://www.e90post.com/forums/showp...&postcount=276
05-28-2022, 04:08 AM | #53 |
319
Rep 565
heres mine, i made the mistake of using 7075 al bar which after the fact I learned is not really weldable or bendable. so I had to use spacers since theres a height difference between front and back of sub-frame.
already have monoballs in front with m3 and other strut bars but these bars added a ton of feedback. not sure if it help handling but any increase feedback on a front strut suspension is appreciated but most dd probably wont like it |
Biginboca3767.50 |
05-28-2022, 12:27 PM | #54 |
86
Rep 233
05-31-2022, 11:50 AM | #55 | |
373
Rep 532
Drives: 2007 E70 4.8i, 2008 E90 335i
I did this recently and on my 335i.. I didn't realized that there is a slight interference with the gas tank on the 335i. The gas tank has a "well" (which extends down by about 3/8") that interfered with the rear passenger bar. I thought my bar was bent at first but realized that it is because the 335i has a different gas tank than the M3. The well is actually visible in your picture. It is probably fine to just tighten up the bar and let the gas tank flex but it is something to be aware of. I ended up installing 3/8" spacers between the cross brace and the bars so that it didn't flex the gas tank too much. I believe that 1/4" spacers were enough and only lightly flexed the gas tank but 3/8" makes it a non issue. Given that it is a simple spacer and longer bolts I think it is worth adding for a 335i. As a side benefit it also allows the original bolts to be installed in the outside holes so that they are plugged. -Rich
2007 E70 X5 4.8i with 10" android screen Running 265/60/18 AT34s All Terrains (Mainly for road trips)
2008 E90 335i with 10" android screen, 7" intercooler, inlets, Dinan intake, JB4 BEF, E85 conversion, Mfactory LSD, M3 suspension, EDC shocks with custom controller. |
05-31-2022, 05:12 PM | #57 | |
373
Rep 532
It is described well here: https://www.e90post.com/forums/showthread.php?t=165246 I have to think about the single bolt point on the rear of the e92 bars where they bolt to the subframe attachment. That seems like it could pivot slightly where the M3 version is one piece in the back so it won't pivot. I know there is much debate about this with front strut bars... Can this have the same issue? -Rich
05-31-2022, 05:20 PM | #58 |
319
Rep 565
not really, both bars are weld to the center plate and the way the bar are setup it make more sense as braces, the e92 way. the m3 way is only cause they could Not route the bars the same way due to the resonator. part of me wishes i too went m3 brace to match and maybe will need extra room for exhaust
06-03-2022, 03:02 AM | #59 |
349
Rep 2,289
The M3 version looks to be made out of larger/ thicker metal also. The previous post also says that the M3 version has different designs for the e92/e93/e90. Maybe you were sold the wrong one, just a thought. So is this even a worthwhile mod in your opinion?
06-03-2022, 05:40 PM | #60 | |
373
Rep 532
I haven't driven it much after putting it on and sadly haven't had time to take it out to throw it around corners. It seems a little thicker. I think the only place it "could" be really better than the e92 version is that the e92 version just has a single bolt hole on the rear as I mentioned. There probably isn't enough movement in the body to allow that to pivot but it is more likely to pivot than the M3 version is because it is welded in the rear (rather than front) and the front is a 2 bolt point connection. e92 picture from ecs: This is probably not a significant difference and the spacers are a disadvantage. There are however usually more used M3 braces around so they are often cheaper used. I think I only gave $100 for mine. Note there is also another ear brace that goes in the rear of the e93: https://www.realoem.com/bmw/enUS/sho...88#51618045988 I have one but didn't realize that I needed to add mounting points to the body of the car that are only really reachable when the rear subframe is out so I haven't installed it. -Rich
07-02-2022, 04:07 PM | #61 |
37
Rep 184
Drives: 2008 Bmw 328i Coupe
I have a small question. Would using similar hardware to the m3 strut tower brace be better or similar to using rivnuts. Marked in red.
07-03-2022, 11:46 AM | #62 |
319
Rep 565
you mean a nut and bolt through the subframe? nope, rivnut imo is best and easiest way
tylerhart_2137.00 |
04-21-2024, 11:09 AM | #63 |
50
Rep 134
I know this is an old post but I have just found a company manufacturing steel undertray or what they call sump guards. They bolt into the front subframe were some of us have put in brace bars, it’s via a bracket so not sure how much bracing it would actually do.
https://www.sump-guard.co.uk/steel-s...0-91-2004-2011 |
04-22-2024, 03:46 AM | #64 |
624
Rep 3,201
Drives: E92 325i MSport Coupe
It looked good until I realised that there's no access to the sump plug, so you'd have to remove it every time you do an oil change!
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
