05-31-2017, 04:12 PM | #46 | |
KYHOMPB
219
Rep 461
Drives: Only BMW's Ja
First of all I think what you did here is totally awesome!! Great overall ingenuity and things like this are what make Bimmerpost the best car forum on the interwebz With all that being said I do have a couple concerns on the design however and just wanted to point them out before you start mass producing these. 1. The little plastic part circled below is the custom portion of the plastic base that is used to screw into the E9X paddles correct? If so, do you believe this piece is strong & robust enough to hold up to thousands of shifts overtime? Reason I believe this part might be the weak link of the design is because if you look at how the F8X paddles attach to the base you can see that there's a flat metal piece that extends from the paddle and this piece slides into the plastic base and screws in about 3/4" of the way down effectively strengthening the thin plastic OEM base. 2. The angle at which the E9X paddles mount to the custom plastic base seems much greater in comparison to the stock OEM LCI paddles. How exactly did you calculate this angle? Just from the few photos you've post it looks like if you mounted everything up including the OEM plastic boot adapter piece that attaches over the electronics then the face of the E9X paddles wouldn't be parallel to the steering wheel. Would you be able to take a sideview photo of the paddles mounted up to the steering wheel? 3. This is just a thought but I believe if people have upgraded to an actual E9X M3 steering wheel the whole assembly might not physically mount up correctly. The reason I bring this up is because when I did my retrofit the E9X paddle assembly didn't mount seamlessly to the back of my OEM M-Sport steering wheel (i.e. there's a bit of a gap). This makes me think that the OEM plastic adapter boot piece would not work with an actual E9X M3 steering wheel. Could be totally wrong here though lol. Does anyone have any experience with this? |
05-31-2017, 05:30 PM | #47 | |||
228
Rep 538
As I stated above I have literally stepped on a bracket with one side of it supported by a piece of wood and it didn't budge. I will freely admit I am not a heavy dude, but I assure you if I supported the stock pin or PCB in and stepped on a paddle I would break something. As for longevity. That is an interesting question. But two things: 1) The stock paddle is actually an aluminum paddle impregnated with a plastic mounting surface. 2) If I look up papers on longevity of polycarbonate (honestly even ANY plastic I suspect) we aren't even in the picture of fatigue. I am including a study done on mechanical and thermal fatigue of PC done by those much smarter than myself (I am an engineer but not a mechanical or chemical engineer). Here is an excerpt: "The Lexan141R material was injection moulded into tensile bars according to ASTM-D638, having a gauge length of 100 mm and crosssectional area of 3x10 mm2" That cross sectional area is smaller than the failure point we are talking about here. Using that they collected long term failure data with a certain amount of stress which results in this graph: Mine would follow the non-annealed line (lower of the two lines). What does this say? Well it says the failure is not measureable below lets say 40MPa or so. The stress we put on the paddle is a few orders of magnitude smaller than 40 Mpa (~5800 psi). Even leaving in some room for margin/error this certainly agrees with what I am seeing with physically standing on the part. Most importantly it shows that if you stay within reasonable limits of the part it simply doesn't fail due to applied stress. https://pure.tue.nl/ws/files/1927251...3620967040.pdf Quote:
Interestingly enough I actually will be replacing my steering wheel with an E9x steering wheel since mine is a little chewed up and I found an M3 replacement for a reasonable cost. So this is something I could actually test out... and probably should considering I will be using these . It may simply fit right up. If its a small tweak then I could offer two different types. If they are dramatically different then I agree it is possible that the adapter wouldn't work at all. Last edited by WhatsADSM; 05-31-2017 at 05:46 PM.. |
StephGOD218.50 GoodMoodley225.00 |
05-31-2017, 05:42 PM | #48 |
228
Rep 538
Also found a picture (courtesy of ESS) of the internals of the E9x M3 paddle (which I have also taken apart before). You can see the size of the plastic parts here that BMW deems acceptable for lifetime stress. There is a large arm there with a cross sectional area considerably smaller than the cross sectional area of what I am using here.
05-31-2017, 07:48 PM | #49 |
228
Rep 538
Here are the requested side view pictures. Also shown are my hands holding the wheel and the stalks fully depressed.
facebook image uploader |
StephGOD218.50 |
06-16-2017, 02:17 AM | #50 |
40
Rep 224
looks good !!
e84 x1 2012 Sdrive2.0d sold was a fun car in stick
03-20-2018, 03:25 PM | #51 |
246
Rep 439
Sorry if this is a dumb question, but does anyone know if this works on the older steptronic paddles?
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
03-20-2018, 03:31 PM | #52 | |
425
Rep 545
https://www.nelson racing wheel.com/paddle-shifters
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
519.E82246.00 |
04-27-2018, 05:31 AM | #54 |
1337
Rep 2,096
Drives: '11 135i M Sport
I don't think so. These will fit DCT transmission no problem.
07-02-2018, 06:11 PM | #55 |
14
Rep 77
So to bring this back again. I have a 2011 135i with DCT. Would I would need the e9x m style or f20 paddles? And we’d need to fabricate a bracket like yours. I’d like to buy these if available.
Sorry I’m reading the testing part you did and can’t determine which paddles you ended up with in the end. How do we get this 3D printed part. |
07-03-2018, 12:36 PM | #56 | |
270
Rep 437
07-03-2018, 02:08 PM | #57 |
5160
Rep 3,242
Or follow the suggestion to go with the Nelson Racing Wheel paddle kit like I did:
https://www.1addicts.com/forums/show...n+racing+wheel |
BAN_M2C4197.00 |
07-03-2018, 07:09 PM | #58 | |
4197
Rep 3,091
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [8.25] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
zx10guy5159.50 |
07-04-2018, 07:46 PM | #60 |
4197
Rep 3,091
Thanks, they are from European Auto Source, pinged then thru the M3 forums since they are from an E92.
Follow me on IG
11-11-2019, 02:02 PM | #61 |
Save the manuals!
6035
Rep 6,754
Nice write up! Curious though, are the F8X ones illuminated or is that just the photo?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
06-03-2020, 02:19 AM | #62 |
Rep 7
Thanks to this thread I went ahead and bought some cheap China paddles for F series.
https://www.ebay.com.au/itm/Aluminum...72.m2749.l2649 They worked perfectly. Only a 45 minute job to replace my OEM peeling plastic paddles. Last edited by YakuzaWAFD; 06-03-2020 at 04:40 AM.. |
06-03-2020, 11:45 AM | #63 |
707
Rep 2,450
How is it driving with the larger paddles. Do they get in the way or is it more convenient? Do they feel solid?
06-04-2020, 12:49 AM | #64 | |
Rep 7
They're solid unless you try to shift them at the very top as they can flex. I have found that my fingers naturally rest on them so they don't feel in the way. The aluminium is a much nicer feel than the plastic. |
houtan707.00 |
09-07-2021, 09:49 AM | #65 |
Rep 1
Hello guys!
Resurrecting this post from 4 years ago I recently found and bought on internet, these NRW (Nelson Racing Wheels) plug and play V2 Paddle Kits made especially for the BMW 135i e82 coupe LCI DCT N55 models. I'm waiting for the kit to arrive. It should take a few weeks yet. I will show the result here on this forum and also there on the instagram of my car project: @135i.nsane |
houtan707.00 |
09-07-2021, 11:27 AM | #66 |
707
Rep 2,450
Looking forward to the update!
