03-03-2017, 09:00 PM | #45 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
The clutch slave cylinder pushrod had popped out and jammed. They inspected inside the housing with a camera and there was no evidence of any metal grinding. Clutch disk, pressure plate and throw out bearing all looked normal. They put everything back together and the car drove normally. They have ordered a new slave cylinder and will compare them side by side before installing the new one.
He mentioned that our slave cylinder has a plastic housing and may not have been able to handle the stronger pressure plate. I haven't heard of anyone else having this problem even with aftermarket clutches.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
ayao646.00 |
03-07-2017, 07:23 PM | #48 |
2619
Rep 2,819
New slave cylinder installed. It now feels perfect. Something was definitely wrong with the original, either damaged during install or was already going bad. Pedal movement felt choppy and is now light and smooth. Problem solved. I paid $108 for the part. They didn't charge me any labor. I'm happy with that.
03-07-2017, 08:40 PM | #49 | |
Thread killer
646
Rep 1,896
03-07-2017, 09:25 PM | #50 |
2619
Rep 2,819
Yes, but variably, and seemed to be getting better. I didn't feel the choppiness before the clutch was changed, but now in hindsight I do think the pedal felt more firm than it does now, so it may have already been failing.
ayao646.00 |
03-13-2017, 03:43 AM | #51 |
70
Rep 359
Sorry to thread jack, but since we're on the transmission topic now, i would like to ask if anyone have gear engagement issues?
Occasionally when my car is cold in the morning, i have some difficulty engaging into gear. it goes away as the car is being driven. Anyone would like to chip in as to what might be wrong? |
03-13-2017, 08:45 AM | #52 |
2619
Rep 2,819
If its only happening when cold, it may be the fluid. That's an easy fix. I'd start with new fluid if you haven't done that yet.
How many miles on your car? Did your fluid get changed at 1200 miles and 30k miles?
03-13-2017, 11:51 AM | #53 | |
98
Rep 309
If you have a fluid cocktail in there (thicker) for a single mass flywheel and gear chatter like I do, more D4 ATF would thin it out and slick it up. |
03-13-2017, 12:05 PM | #54 | |
70
Rep 359
yup i had my fluids changed quite regularly, around 10,000kms per fluid change. used original BMW fluids, but to no avail.. i still get trouble engaging sometimes. |
03-13-2017, 12:59 PM | #55 |
389
Rep 2,186
Looks like you might have air in the system, it's actually a little tricky to bleed the clutch as it shares the same fluid as the brakes And you have to keep the fluid tank Filled to the top for it not to suck air while bleeding
Get it checked |
03-14-2017, 01:24 AM | #56 | |
70
Rep 359
mechanics checked my car and couldn't find anything wrong with it.. sigh. |
03-16-2017, 06:51 PM | #58 |
292
Rep 2,898
05-26-2017, 10:29 PM | #60 | |
22
Rep 31
Wonder if it's really related to brake / clutch fluid? |
05-28-2017, 01:32 AM | #61 |
389
Rep 2,186
the brakes share the same fluid as the clutch from the same reservoir, so when bleeding the brakes you should bleed the clutch so you get some nice fresh oil in there and not mix the old with the new especially when changing brands of fluid
06-13-2017, 10:19 AM | #63 |
2619
Rep 2,819
Is it a dual mass flywheel with the same thickness as stock?
06-13-2017, 07:14 PM | #64 |
98
Rep 309
Yeah, but one of the things I think is wrong with the clutch masters is the thermal expansion of aluminium is 7x that of steel.... and I think its messing with the sac mechanism of the pressure plate. Maybe I just answered my own question.
06-13-2017, 07:18 PM | #65 |
389
Rep 2,186
Well most of us aussies are going down the dual mass flywheel and 550i clutch it is holding quite well on street and track
You wont be able to do any 4000rpm launches but it lasted twice as long my twin plate did and still going strong |
06-13-2017, 08:57 PM | #66 |
98
Rep 309
What kind of tq are you making?
