Spacers on OEM E92 only
11-02-2017, 04:42 PM | #45 |
574
Rep 940
im looking for spacers as well just not sure what size to get
wheels are style 230s 19 inch - 275/30/19 michelin ps4s and 245/35/19 for the fronts on stock suspension i thought fronts would rub at full turn with 245s but they surprisingly dont rub at all thinking 10mm for front and rear.. i dont want the rear to rub at all so im hoping 10mm does the job... |
11-02-2017, 06:49 PM | #46 | |
106
Rep 4,502
12-11-2017, 07:10 PM | #47 |
339
Rep 142
New member here. Thanks for all the heads up on spacers with Oem wheels. After reading up on this I decided to go with 12 front and 15 out back on 193’s. I have an extra set of 15s but I don’t prefer them any farther out. And as far as the rear I have a set of 18s which I think would be too tight. Anyways I’m very happy with the fit. No rubbing on stock m-sport suspension, with 225s and 255s.
Thanks again. |
Snake882.50 |
12-15-2017, 09:31 AM | #48 |
312
Rep 404
I run a 15 / 20 spacer setup, no rubbing no modifications. style 189 wheels on firehawk indie 500's
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
12-15-2017, 09:32 AM | #49 |
312
Rep 404
note, the above pics was with runflats, not the firestones.
12-15-2017, 09:50 AM | #50 |
312
Rep 404
06-14-2018, 02:32 AM | #51 |
166
Rep 430
Drives: 2008 BMW 335i Coupe
Would 12-15 mm in the rear be OK for 18 inch Continentals? M-sport suspension here
06-14-2018, 12:29 PM | #52 |
Basic Bimmer
523
Rep 935
Drives: E92 328i 6MT ///M
Yes. I run 20mm in the rear with stock 18's on my M Sport LCI coupe.
Black Sapphire 328i ///M Sport Coupé Save the Manuals! |
Subhaancassim660.00 |
06-22-2018, 04:05 PM | #54 |
Rep 6
Ive recently purchased 20 mm spacers for the rear of my E92 335D, at first i thought it looked awful, but as it turned out as the car was jacked up the suspension on both sides had extended fully.
After a day or two of driving the ride height returned to as it was and it is now (in my eyes) sitting perfect. Looking at this thread Im going to go with euther 10mm or 12mm for the front. F:225/40/18 R:255/40/18 Thanks guys |
07-03-2018, 05:55 PM | #55 |
Rep 14
I have 10mm front, 15mm in the back sitting on stock 335is suspension and stock size pilot 4s. Rear rubs under compression and driver side front rubs on the front inner fender in full lock. Passenger side seems to barely clear.
07-16-2018, 08:41 AM | #56 |
541
Rep 3,131
Drives: 2011 335i e92 DCT
I posted a while ago but I’ve got bigger spacers now
2011 M Sport 335i E92 Stock M Sport suspension Stock 19 inch 313M wheels Stock tyres sizes, Kumo KU39 20mm bolt on spacers front and rear Works pretty well Rear scraps very rarely if the road dips Front scrap only just on hard lock reverse Otherwise 95% of the time they are fine |
04-09-2019, 05:00 AM | #57 |
Rep 1
Hello there,
Spacer question. I have 2007 E93 335i M sport suspension my setup: 8" 225 / 35 / 19 front ET29 9" 255 / 30 / 19 rear ET40 OEM 296M 19 inch wheels I have performance brakes installed (rear hubs were swapped from 135i to allow brake fitment, which worked as a spacer already adding ~ 6 - 8 mm comapring to stock. front is fully stock/ OEM) it is explained here in the first post pictures: https://www.e90post.com/forums/showp...91&postcount=1 so my question: which spacers would work w/o rubbing (cosidering rear is already having ~ +8mm). I was thinking about adding 12mm spacers on both rear and front. Any thoughts ? Many thanks in advance. Last edited by chevee; 04-09-2019 at 05:09 AM.. |
02-07-2020, 08:27 PM | #58 | |
90
Rep 664
I've come to the conclusion tire brand also makes a difference. I had 12mm rear on 265 Continental and no rubbing at all. I went down in size to 255 Michelin and now it rubs on dips. I might have to roll fenders now |
05-07-2024, 10:55 AM | #59 |
19
Rep 79
Hi guys,
Sorry to bring this topic alive from the dead ) I really cannot find any good information about spacers for the E92 LCI. I have the 193M style wheels and would like to bring them out a bit, without rubbing. I read here that 12mm on the front rubs, but 10mm from what I know is not recommended for BMW's due to the hub lip? Also, on the back, 12 or 15mm should work? Wheel size: Front: 225/40/18, 8J, ET34 Back: 255/35/18, 8.5J, ET37 Last edited by minulache; 05-07-2024 at 11:01 AM.. |
05-08-2024, 10:35 AM | #60 | |
624
Rep 3,201
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
05-08-2024, 11:34 AM | #61 |
210
Rep 169
^ above setup is pre-LCI, though, correct?
My buddy put 12mm all around on his LCI sedan, and reported a slight amount of rubbing in the rear (maybe only with passengers?). It might depend on the specific tire and camber settings. I think 15mm rear on an LCI is going to be a bad time without camber or fender work. |
minulache18.50 |
05-08-2024, 03:14 PM | #62 |
19
Rep 79
That is the thing, apparently the LCI and Non-LCI are different when it comes to spacers. On non-lci bigger spacers have no problem, but on LCI they do. That is what I am trying to find out...
05-08-2024, 04:12 PM | #63 |
210
Rep 169
Correct, LCI rear track width is 8mm wider, so LCI rear wheels are already "spaced out" 8mm vs. Pre-LCI.
ie., 20mm spacers on a Pre-LCI results in the same track width as 12mm spacers on an LCI (which is pushing it). |
minulache18.50 |
