The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 2E68 knock sensor 1 and low boost 3100 codes
      09-09-2018, 11:35 AM   #45
///Motivated
49
Drives: 335i, i3
Check my other thread for my update. The sensors were actually sensing mechanical vibration which caused the plausibility code.
      09-15-2018, 01:38 AM   #46
Serhio
Serhio's Avatar
11
Drives: 135i
Has anyone found a problem? ((((
The error shows even when driving calmly. It is good to go for a week and everything will be fine, and maybe in a day to show. Sorry for my English
      09-15-2018, 06:48 AM   #47
Bimmer_Engineer
Bimmer_Engineer's Avatar
1044
Drives: 2007 335i
Your English is great...much better than my Russian...
Check this thread out and see if it helps...
https://www.e90post.com/forums/showthread.php?t=1520525
      09-15-2018, 07:06 AM   #48
Serhio
Serhio's Avatar
11
Drives: 135i
it's all Google Translate
Thank you
p.s about the wiring already thought. about the roller rocker is something interesting. strangely
      09-15-2018, 07:39 AM   #49
Bimmer_Engineer
1044
Drives: 2007 335i
Thank you
I don’t know if you’ve already checked this, but I had the same issue and mine was solved by cleaning vanos...I would only move on to the rocker arms if that doesn’t work...
Good luck!
      09-15-2018, 08:10 AM   #50
Serhio
Serhio's Avatar
11
Drives: 135i
Good luck!
I do not understand the dependence of detonation on VANOS. If there is a problem with the VANOS, mistakes will be made on it
VANOS valves cleaned
      09-15-2018, 12:34 PM   #51
Bimmer_Engineer
1044
Drives: 2007 335i
I don’t know what the dependence of the knock sensors on the vanos is...but I cleaned my vanos over 2 months ago and I haven’t gotten the 2E68 since...
      09-16-2018, 03:26 AM   #52
Serhio
Serhio's Avatar
11
Drives: 135i
talk about the gears themselves VANOS?
      09-29-2018, 12:23 PM   #53
optigrab
More Boost?
optigrab's Avatar
59
Drives: 08 135i MSport 6AT
SUBJECT
N54/N54T - DME Knock Sensor Signal Faults Are Stored
MODEL
All with N54 and N54T engine produced up to 2/28/2011
SITUATION
The Service Engine Soon (MIL) lamp may be illuminated with the following faults stored in the DME.
E60, E61, E71, E82, E88, E89, E90, E91, E92, E93/N54, N54T (DME: MSD80, MSD81):
l 2E68 - Knock sensor signal 1 and/or
l 2E69 - Knock sensor signal 2
F01, F02/N54 (DME MSD87):
l 168001 - Knock sensor signal 1, signal: engine noise above limit value and/or
l 168101 - Knock sensor signal 2, signal: engine noise above limit value
High outside ambient temperatures can influence the frequency of the fault(s) being stored.
CAUSE
DME software error
CORRECTION
Program the vehicle using ISTA/P 2.41.1 or later.
Appreciate 2
      07-06-2019, 09:24 PM   #54
Julian2485
110
Drives: Black lci e90 335 xdrive
Originally Posted by optigrab View Post
SUBJECT
MODEL
SITUATION
CAUSE
DME software error
CORRECTION
Is this covered under some sort of warranty ?
      07-06-2019, 09:45 PM   #55
Bimmer_Engineer
1044
Drives: 2007 335i
How often are you getting this code? I still get it every once in a while...last was 2 weeks ago.
      07-08-2019, 12:02 PM   #56
Julian2485
110
It comes and goes i last got it last night. I feel like i get it every day to every other day when I'm just cruising. My engine is knocking it sound like a normal n54 engine. The code comes up during the day summer time. I don't get it during the winter
      09-23-2020, 09:55 PM   #57
Tyc0
147
Drives: BMW e92 335i
anyone ever really get to the bottom of this? dont mean to bring back an older thread but it doesnt seem like anyone ever found a real answer
      03-13-2021, 10:23 AM   #58
Aleksandro
Drives: BMW 118i
Hi, Guys ! Did someone find the original issue for this error code ?
I've got the same error code 2E68 Knock-sensor signal 1 on my BMW N46B20B Engine.
After this I replaced my knock sensor, but nothing changed. The error continues to show.
After this I noticed a very strange knock sounds from the Engine bay in range between ~ 2K- 3K RPM Video -
* The problem was identified and resolved
Guys if you get a code from knock sensor check the car in service immediately!
The function of this sensor is to "listen" for unusual knock signals from the engine cylinders. If find any error codes related to the knock sensor are registered.
In my case the engine has almost died! 4 from 5 services suggested me to replace the Engine with the same from the same car but on low millage.
Thankfully one service decided to check out and disassembly the engine.
The original problem was the rod bearings. They were almost gone! You can check the video! They measured precisely the crankshaft and for my luck, the crankshaft was not affected/damaged. The reason of this catastrophic failure was fake oil they said . I always used Castrol but here in my fucking country there is a lot of fake stuffs one of them is this oil brand.
Last edited by Aleksandro; 03-05-2022 at 08:29 AM.. Reason: The problems are founded and resolved
      03-13-2021, 03:39 PM   #59
Bimmer_Engineer
1044
Drives: 2007 335i
Hey...I replaced the sensor and it fixed mine. If that’s not the case then you might have an issue with your rocker arms. There was another owner here who had that issue.
      08-15-2023, 06:35 AM   #60
Dobrin
Drives: 2015 455i xDrive convertible
So, if the 2E68 code persists after replacing the knock sensors, how do I know if it is a mechanical failure with the engine? How do I know if it is rocker arms,, rod bearings, or something else?
      10-02-2023, 12:11 PM   #61
danfratamico
danfratamico's Avatar
No_Country
17
Drives: 2007 BMW 335xi
2007 BMW 335xi  [0.00]
Just out of curiosity, is anyone NOT using premium gas here? I have the same codes and noticed it about the same time I started using 89 in my car instead of 91 or 93. I will try filling up with 93 to see if that fixes the issue for me.
      05-12-2024, 11:30 AM   #62
Thatslow.n54
Drives: Bmw 335i E92
3100 boost pressure control deactivation. With a 2e68 knock-sensor 1
Got the same code yesterday. And a month back. Looking to see if anyone has experienced the same codes and knows an alternative fix for this problem.
I know this is an old thread but I hope someone is still watching.
For me to get ride of this code I have to turn off the car let it rest for 5 minutes. Plug in my code reader and clear it, let it idle for 5 minutes then drive. If I just clear the codes turn the car on and start to drive the code comes back around 2k rpm, if I let the car sit like expected earlier the code will clear and I can drive again for another 2-4 weeks before it comes back again.
Appreciate if anything has had the same problem / code and knows how to solve it.
Thank you, Dave.
