      03-17-2023, 07:07 PM   #45
Tommm
Driven Crazy
Tommm's Avatar
190
Drives: his wife nuts 128i 6m
Originally Posted by SirSmokeAlot View Post
I cannot get a spare for my 135i that I recently got. Tried calling a local BMW dealership and everything. Pretty much the wheel and tire spare that fits a 135i that Dackleone posted is no longer available. I saw it on ebay for upwards of 880$-950$. It's like damn, I'll just get all new tires for that price. :/
Maybe someone can point me in the right direction to get one at a reasonable price? I'd really appreciate it. I'm in North Carolina if that helps.
Must it be exactly what Dackel has? Would a full size tire in the trunk cramp your style too much?
'08 128i 6M
      03-18-2023, 07:02 AM   #46
SirSmokeAlot
SirSmokeAlot's Avatar
11
Drives: 2012 BMW 135i Coupe
No, not really. When I talked with the BMW dealership about this, they said a BMW rim and tire would be like 1100$ though. As far as having an actual replacement, and I assume it would be for the front, seeing as the front and rear are different sizes.
      03-18-2023, 09:24 AM   #47
Tommm
Driven Crazy
Tommm's Avatar
190
Stop and think why they call it a spare. It is used in emergencies. Find a curbed wheel on craigslist or facebook, and put an old tire on it. Or you can spend $1,100 for something that will probably rot in your trunk.
I have a set of 16s from a Z3 with tires that I autocrossed with that you can have cheap.
'08 128i 6M
      03-19-2023, 10:56 AM   #48
SirSmokeAlot
11
Yep, for emergency and just piece of mind knowing that I have a spare in the trunk should something happen. I think the main thing is, that the spare would have to fit over the brake calipers? I'm just looking for something at a 200-250$ range, for a wheel and tire spare, nothing fancy. Just something for an emergency.
      04-18-2023, 08:50 AM   #49
bobowar135
bobowar135's Avatar
Australia
3479
Drives: 08' Sedona Red 135i
A 17 inch or bigger will clear our huge front calipers. I've been through this myself after I changed to normal tyres.
      04-18-2023, 05:55 PM   #50
gjm120
2185
Drives: 2013 128i, 2021 230i
I bought a used BMW 17" wheel, put one of my runflats on it when I went to regular tires, and got an Ebay Mercedes C class jack that fits our jack points perfectly. Also got a decent air compressor and a plug kit.
The spare takes up about 1/2 the trunk so if I'm traveling it stays home. I know it doesn't make much sense to have a spare riding around town and not having one when traveling, but...
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
      04-19-2023, 06:21 PM   #51
SirSmokeAlot
11
Thanks for the idea, might do this myself. How much you end up spending on it all?
      04-20-2023, 10:26 PM   #52
gjm120
2185
Around $110 for a BMW style 262 wheel and around $70 for the jack.
This was about 5 years ago, so numbers are from rough memory and I'm sure everything is pricier now.
      04-21-2023, 09:46 AM   #53
gap
109
Drives: 2008 135i
I've carried my compact spare/jack in the trunk for 100,700 miles and 14 years and have yet to use it. In hindsight having a air compressor in the trunk for nail leaks would get you to a tire service shop for repair.
ER CP, Forge DV, Wagner FMIC, PE, Maddad Mid, ER Sports OC, BMS OCC, RB Check Valve, AFE intake, Cobb AP3- Stage 1+ drive, BMW SS, PS Springs, Yellow Koni external, M3 Control Arms F & R, M3 Strut Brace, M3 Sub Bushing, Rouge Toe, Dinan Camber Plate and Rear Shock Mts., E93 M3 front sway bar, Mfactory Diff, Arc 8 PSS 235/40/18-265/35/18
1addicts
