Apple CarPlay on CIC?
04-28-2020, 03:15 AM | #45 |
Rep 8
I have the Andream box and reverse camera installed and working on my e93 with CIC - really impressed with it.
Can confirm it uses the OEM microphone, but I have had to plug in to the AUX port for sound. It appears sometimes it is required, sometimes it isn't depending on your configuration. |
04-28-2020, 11:05 AM | #46 | |
[Oo=||=oO]
1105
Rep 2,470
04-30-2020, 08:22 AM | #49 |
401
Rep 1,579
Switching to backup camera is not an issue once the carplay is booted up. The delay can be when you first start the car and the system is not yet fully booted up. CIC solves this issue by displaying the camera image while the system finishes booting in the background. Do the carplay systems do the same? I can't check as I am still on my factory camera.
05-01-2020, 03:02 PM | #50 |
[Oo=||=oO]
1105
Rep 2,470
Thanks dude. This is rather good response. Have you had any issues with it? Sync etc.? How long did you have it? I am looking for a unit, but it seems like there is a newer unit available on the market every 3-4 months, so I was inclined to wait. However, if this is performing in similar manner as any other stock units, then I might pull a trigger on it sooner than later.
Thanks |
05-01-2020, 03:05 PM | #51 | |
[Oo=||=oO]
1105
Rep 2,470
05-22-2020, 10:55 PM | #53 | |
401
Rep 1,579
But I do like the ability to save an address in google maps on my laptop. I can go to my car and select the saved places and start navigation. It is really nice when you need to go to multiple places in one trip. I don't know about mirror mode. Apple's carplay is limited to official carplay apps. |
06-04-2020, 05:22 PM | #54 |
Commander, USN (ret)
13
Rep 19
Hi guys. Installing an Andream unit in a '11 E93 with CIC w/o Combox. Can anyone confirm the correct dip switch settings? Thanks!
Steve328i
2011 335i vert |
06-05-2020, 08:38 AM | #55 | |
[Oo=||=oO]
1105
Rep 2,470
06-08-2020, 07:54 AM | #57 |
13
Rep 19
All installation issues are resolved. Carplay and reverse camera have functionality.
Will post a description of the installation process later for anyone who may be considering getting an Andream or similar unit.
Steve328i
2011 335i vert |
06-08-2020, 10:33 AM | #58 |
[Oo=||=oO]
1105
Rep 2,470
Please do. My andream unit and backup camera is on the way - hopefully. It's been stuck in transit for over 5 weeks now.
06-16-2020, 05:32 AM | #60 |
Rep 55
I'm going to be a bit more generous and go for a B+
I've just installed the Road Top version (because it was available on Amazon Prime next day delivery) to my 2012 E91 CIC iDrive. It loses points for the sound quality being marginally worse than than using my phone plugged into the USB socket and for the skip / back buttons not working. Apart from that it really is pretty good and carplay works just aswell as it does in our factory fitted 2017 Polo. My phone auto connects wirelessly with no problem and the CarPlay screen is up before I leave the end of my drive. Also I should have tested it in without fitting the cable to the iDrive controller as apparently it's not needed. Mine works fine with it in place but would have saved a bit of faffing running an extra bit of loom. |
08-05-2020, 01:46 PM | #61 | ||
Rep 7
09-22-2020, 03:55 PM | #62 |
66
Rep 202
I just got my Andream MMI yesterday for my e92 w/ CIC.
I’ve connected everything, but keep getting the red screen when I push menu button. I tried connecting the data wire from screen directly to MMI but no luck. Any idea? __________________
11' 335i xDrive Sapphire BLK/Saddle Brown interior - VRSF FBO - PS2 - Fuel-it Stg. 2 LPFP - PR COILS - Injen CAI
09-22-2020, 09:55 PM | #63 | |
66
Rep 202
I’ve double and triple checked all connections, the menu and back button work to activate/deactivate the unit( hear a click from box and screens turn red/back to normal). I have 3-4 On switches, the rest off. I dismounted the screen to verify connection and also tried connecting screen directly to box with out extension. Would it be possible firmware? Faulty box? Really running out of ideas, any info you might have would be greatly appreciated. Thank you in advance 🙏
08-28-2021, 04:39 PM | #64 |
Rep 14
I just installed one of these with a backup camera and the iDrive control isn’t working. It is completely dead. Switching it back to the factory cable directly restores functionality (but no MMI capability) so I know my controller is still good. Switches 3 and 4 are on rest are off. No error codes thrown. The CIC and steering wheel controls all work still. Is there something else I am supposed to connect besides the one iDrive harness to the power cable? the is a “high CAN” on the iDrive harness that isn’t connected to anything.
09-08-2021, 07:05 AM | #65 |
Rep 1
Screen not turning on
Hey guys i just installed a cic carplay unit into my e92 2011 and as i was trying to test if everything is working before putting everything back together the screen didnt seem to turn on but i could see the cic unit working and the carplay unit working anyone know why this could be?
09-09-2021, 10:44 PM | #66 | |
358
Rep 1,736
'09 335D
