Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      03-10-2023, 12:45 AM   #45
polarbearz
polarbearz's Avatar
52
Drives: BMW M3
Originally Posted by Jlaflo View Post
The rears fit perfectly, no work needed at all just running some neg camber. Only running a spacer in front to clear the suspension.
Do you think the rear will clear with 285 or 295 tires?
      03-10-2023, 11:41 AM   #46
Jlaflo
91
Drives: BMW M3 F80
100% I’m doing 295 next I think
      03-10-2023, 02:48 PM   #47
polarbearz
polarbearz's Avatar
52
Drives: BMW M3
Did you change any arm in the rear? And what negative camber in the rear?
      04-16-2023, 09:38 AM   #48
Jlaflo
91
Drives: BMW M3 F80
Finally had a chance to install the girodisc rotors.
Wanted to try these new re71rs but ended up putting 295/35 square
Zero rubbing issues
      04-16-2023, 09:41 AM   #49
Jlaflo
91
Drives: BMW M3 F80
Front camber -3.6
Rear camber -2.2
All stock arms all around
      04-16-2023, 11:26 AM   #50
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
1106
Drives: F80
Zero rubbing issues
Awesome that those tires fit upfront,, especially on OEM suspension. That extra sidewall would be great for an arrive/drive car that has to deal with crappy roads like mine. What wheel/offsets? Sorry if already noted above.
      04-16-2023, 07:01 PM   #51
Jlaflo
91
Drives: BMW M3 F80
18x10.5 +25
12mm spacer up front
none on rear
      04-16-2023, 09:43 PM   #52
polarbearz
polarbearz's Avatar
52
Drives: BMW M3
18x10.5 +25
none on rear
Does 295/35 rub in full turn in the front? And does the rear tire rub the fender when drive pass the big bumps on the street?
      04-17-2023, 06:23 AM   #53
Jlaflo
91
Drives: BMW M3 F80
Front doesn’t rub. There’s like 1-2mm clearance to fender liner.
Rear barely clears. There was a little hint of rubbing on big dips. But it stopped
If my rear camber was -2.6 or more I think it’ll be perfect. But I’m keeping it how it is now at -2.2
      04-22-2023, 05:45 PM   #54
Jlaflo
91
Drives: BMW M3 F80
Not sure how common this is. But when shifting from 1st to second I would always get “locked out” if I was trying to power shift.
Decided to change my tranny bushing and it was literraly cut in half …
The solid bushings fixed the issue
The_Werm214.00
      04-23-2023, 07:57 PM   #55
heyyouduh
134
Drives: 2018 M3
do you have any pics that show how the 295/35/18 sits on the 10.5" wheel?
According to Tirerack the recommended wheel width for 295/35/18 RE71RS is 10 to 11.5" and the tread width is 10.7". Wondering if it is pinched on a 10.5" wheel. Thanks.
      04-23-2023, 08:05 PM   #56
Jlaflo
91
Drives: BMW M3 F80
Only pic I have at the moment
Appreciate 2
heyyouduh134.00
DaiLyCS166.50
      05-01-2023, 09:58 AM   #57
Jlaflo
91
Drives: BMW M3 F80
Was at Sebring this weekend. Still have braking issues. Have to brake really early just to make sure I stop. Instead of a 100% pedal. Brakes only work around 40% or lower. Forsure it’s fluid issue at this point. Car felt great nonetheless.
https://youtu.be/e6g_rTw6Xtk
Appreciate 3
EDMJAY91.00
Solo_G69.00
      05-02-2023, 02:47 PM   #58
polarbearz
polarbearz's Avatar
52
Drives: BMW M3
18x10.5 +25
none on rear
Can you clear the shock with a 10mm or 7.5mm spacer?
      05-03-2023, 09:59 AM   #59
Jlaflo
91
Drives: BMW M3 F80
Maybe a 10. I don’t think a 7.5 will
      05-23-2023, 02:44 AM   #60
Solo_G
69
Drives: F80 M3
These shots are sick! Your build is turning out amazing, hopefully I’ll get to check it out at an event!
      05-23-2023, 11:29 AM   #61
Jlaflo
91
Drives: BMW M3 F80
Added brake ducts to the f80 to see if it lol solve the problem at the track. It definitely helped. But my brakes get spongy and basically become pretty sketchy after 9-11minutes.
I think the brake pad is over heated from my previous setup?
Next time I’m out I’ll change to a fresh pfc11 pad up front.
Car definelty needs ausupenaion now. Feel like the car is pivoting dramatically from every throttle, brake, and turn input.
Dropped 3 seconds from my previous pb nonetheless.
https://youtu.be/H3TfQyqMzbQ
Appreciate 2
The_Werm214.00
sly1types431.50
      05-23-2023, 11:30 AM   #62
Jlaflo
91
Drives: BMW M3 F80
Thank you bro. Just lmk! I try to go once a month more or less!
      05-23-2023, 06:02 PM   #63
funk323
funk323's Avatar
182
Drives: BMW M4CS
2019 BMW M4CS  [10.00]
Beautiful build!
      05-23-2023, 11:34 PM   #64
uncle ben
uncle ben's Avatar
294
Drives: 06 330i
Any rubbing issues with those front cooling duct hoses?
Any tips on the install? I’m planning on installing mine this week.
      05-24-2023, 06:20 AM   #65
Jlaflo
91
Drives: BMW M3 F80
I had to squeeze the ducts alot to prevent rubbing. I am running a tall tire 295/35. If you’re 30 you’ll have alot more space. The ducts still shoot tons of air when I tested it with a leaf blower.
Remove the air dam for your front coolers. Makes a ton of more space
      06-30-2023, 05:02 AM   #66
3R1CS0
3R1CS0's Avatar
Drives: 19 F82 M4CS SMB
That’s crazy! You managed to fit 295/35/18 on stock suspension.
I’m also looking to run that tire size but on a 11” rim just like Assist’s M4. I’m on Ohlins R&T and I have full suite SPL arms.
Knowing that you have experience fitting that size you think I can fit 18x11 +34 (with spacers of course) with 295/35/18 in the front?
f80post
