06-02-2021, 01:44 PM | #45 | |
Rep 58
06-06-2021, 03:20 AM | #46 |
535
Rep 916
12
11LMBiSTT1552.50 Taco_Bueno955.50 jninja514.50 Belong560.00 wdeerfield2757.00 j2nicee55.00 drunkenmagnum27.00 mrgamby19.00 bigdaddyaar0n14.50 RodF8222.50 Unheardmyth21.00 MJBO2664.50 |
06-21-2021, 03:39 PM | #47 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Dyno day today! The car and turbo performed well, running 33.5 psig of boost, I was able to dial in the ignition timing to MBT. Final numbers were 838 whp and 739 wtq with the Dynojet SAE correction factor. I will upload the dyno graph as soon as I get it.
06-21-2021, 05:08 PM | #48 |
516
Rep 1,247
Drives: 2022 Taycan GTS, 2018 M4, 2016
Great job. Always love to see your work. Just a quick question. I been reading that this turbo performs really well in both lag time and power compare to twin turbo. But what is real benefit from twin to single in general speaking other than more hp. Thanks
06-21-2021, 05:20 PM | #49 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Twin turbos should spool faster and have better transient response because the two turbines have a lower polar moment of inertia, but I'm extremely happy with the response and power of this EFR 9280, especially utilizing the OEM electronic wastegate actuator.
06-21-2021, 07:36 PM | #51 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
I am limited to what I can say due to the agreement I have with the company I am testing parts for, but whats up?
///BMW Junkie473.50 |
06-21-2021, 07:52 PM | #52 |
474
Rep 1,009
I only saw EU5's mentioned and wanted to see if you could share more insight on what it appears to be a DI only setup, but I understand if you're limited at this time.
Pure F82
06-21-2021, 08:32 PM | #53 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
I have been authorized to say they are Pre release Twin XDI-EVO High pressure pumps, and they have been wonderful. Fuel pressure has been solid since installing and tuning them. These pumps with EU5 injectors are sure to be a massive hit as they will support enough power for 90% of people, even on ethanol
06-22-2021, 10:07 AM | #54 | |
773
Rep 961
This is on a stock block or built motor? I'd be afraid with those TQ #'s .
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
chetrickerman10446.50 |
06-22-2021, 12:02 PM | #55 |
535
Rep 916
He said stock block with CNC Head.
Wanted_M772.50 chetrickerman10446.50 |
06-22-2021, 12:12 PM | #56 |
872
Rep 433
Single turbo S55 sounds so much better!
Now we know why AA EL exhaust sounds good but not single turbo good. |
chetrickerman10446.50 m3less130.00 |
06-22-2021, 03:26 PM | #57 |
215
Rep 190
06-22-2021, 07:02 PM | #58 | ||
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Thank you!
Wanted_M772.50 DeezBluBallz161.50 |
06-23-2021, 08:01 AM | #60 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Yes, the tires were spinning on the first pull
06-23-2021, 09:09 AM | #61 |
535
Rep 916
07-20-2021, 02:27 PM | #62 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Here is the dyno sheet finally. Its a very fun powerband.
07-20-2021, 03:40 PM | #63 |
215
Rep 190
07-20-2021, 03:40 PM | #64 |
1553
Rep 3,787
07-20-2021, 09:38 PM | #66 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Unfortunately no
