04-05-2024, 06:47 PM | #46 |
1629
Rep 1,138
Drives: 2009 E92 M3 Dakar Yellow II
04-05-2024, 07:24 PM | #47 |
///M Powered for Life
11517
Rep 10,345
It's still a thing, and I had them as well
04-06-2024, 12:58 AM | #48 |
111
Rep 60
Here's a brief update from the weekend progress before final assembly onto the subframe and chassis:
1. The engine harness has been installed following the repairs mentioned in the previous post. 2. New CCW oil pump with related pulleys, tensioners mentioned in previous post has been installed. 3. New water hard line has been installed. 3. The clutch and flywheel have been transitioned to the new engine. 4. Various components such as the clutch fork, throwout bearings, guide tube, and plastic pin in the transmission have been replaced as part of maintenance procedures. |
04-10-2024, 01:40 PM | #50 |
881
Rep 3,454
awesome thread! congrats on the new motor. I think a stroker could be in my future
subscribing for future updates |
e90sanmarino110.50 |
04-13-2024, 08:02 AM | #51 |
111
Rep 60
As per the previously outlined schedule, today marked the successful start up of the stroker engine. Following the 9 liters of break-in oil, coolant, and power steering fluid, I proceeded to prime the vehicle until receiving a low battery warning on the dashboard. Notably, during this process, fuse number 70 and the crankshaft position sensor were unplugged. Subsequently, the engine commenced operation without issue. Maintaining the engine speed at 1500 rpm, I ensured optimal circulation of the oil pump. Upon reaching operating temperature, I varied the rpm within a range not exceeding 3000 rpm, observing a discernible improvement in both idle smoothness and rev responsiveness over time. After a 30-minute runtime, I promptly conducted an oil flush to expel any residual debris and metal flakes.
Outlined below is my strategy for the forthcoming break-in period: 1. Mileage 0-100: Utilizing Torco break-in oil, adhere to a maximum rpm threshold of 4000. 2. Mileage 100-500: Continuation with Torco break-in oil, gradually increasing rpm to a maximum of 5500. 3. Mileage 500-1200: Transition to 10-60 OEM oil with Redline additive, while maintaining a maximum rpm limit of 6500. 4. Mileage 1200-2000: Employing 10w-60 OEM oil, gradually extend the rpm range up to 7500. However, despite the successful engine start, several setbacks were encountered: 1. The transmission drain plug fractured upon application of torque to specification. 2. The clutch slave unit experienced a failure, resulting in clutch pedal going straight to the floor. Anticipating the acquisition of replacement parts next week, I aim to resume the engine break-in process by the week's end. Attached is a clip showcasing the initial startup, along with a visual assessment of the oil condition post start up: https://youtube.com/shorts/ww9-nvPkV..._ydM6ITitYUU7S |
akkando5872.50 omgzirra_exe1549.50 |
04-13-2024, 09:34 AM | #52 |
Rep 11
Hello, do you notice oil temperature is slightly higher than previous? I recall in the day drive my oil temp is pointing at 100 or slightly lesser. But after installing the 4.6L, the oil temp is slightly more pointing more than 100.
04-13-2024, 09:49 AM | #53 |
111
Rep 60
Hi, yes I noticed the oil temp gauge is slightly higher than 100. Although today was quite hot and I was reving engine for 30 mins. Also, I was on break-oil. What was your experience like? You noticed that while driving?
04-15-2024, 11:49 AM | #54 |
Rep 11
I just complete my break-in. But the tune map seems gives me checklight (increased emissions). Waiting for them to get back to me. But I would say during the break-in period can feel the car very responsive. I can only rev it once i sort out the tune file.
04-15-2024, 12:10 PM | #55 | |
1550
Rep 1,751
by far the most stressful part after installation... constant thoughts where flowing thru my head.. and hearing sounds that didn't exist lmao. although i do note, i evidently stopped using 10W-60 on the 4.4L and strictly only use 5W-50 from Redline/Amsoil/Motul then the stress from tuning was another headache for me. congrats on completing your build and swap!!! you also! congrats!
04-17-2024, 05:17 AM | #56 |
111
Rep 60
Wow that was really fast. How many miles was your break-in procedure. Hope CarBahn sorts out for you soon. Update us with the progress and your impression once you do.
04-17-2024, 05:24 AM | #57 |
111
Rep 60
[QUOTE=omgzirra_exe;31074727]this is pretty similar to when i did my 4.4L break in proceedure.
by far the most stressful part after installation... constant thoughts where flowing thru my head.. and hearing sounds that didn't exist lmao. although i do note, i evidently stopped using 10W-60 on the 4.4L and strictly only use 5W-50 from Redline/Amsoil/Motul then the stress from tuning was another headache for me. congrats on completing your build and swap!!! Thank you man! Yes, I’ve been hearing noises here and there too and got paranoid. I’m in Japan right now picking up some parts for the transmission and keep rewinding the clip I took where I heard some noises. I thought I was the only one who had OCD lol. May I ask why you change to 5W-50? I might do it also since all the OEM oil I need to import from US or Germany while 5W-50 is readily available here. |
CamasM3e933224.00 omgzirra_exe1549.50 |
04-17-2024, 03:17 PM | #58 | |
1550
Rep 1,751
[QUOTE=e90sanmarino;31079438]
a good thing to remember, once you build your motor it no longer follows "oem" suggestions at least in my opinion. so you really need to go out of your way and test what works best, and inspect it and see how your engine behaves. for me i find that 300V/RedLine/Amsoil in 5W50 is what my engine enjoyed. after all the work done to it.
04-18-2024, 03:29 AM | #59 |
Rep 11
Carbahn recommended break-in is 1000km but I go at least 2000km to play safe. I am now sorting out with Ani for the my tune file. She is very responsive
04-21-2024, 10:46 PM | #60 | |
111
Rep 60
[QUOTE=omgzirra_exe;31080952]
04-21-2024, 10:49 PM | #61 |
111
Rep 60
Yes that is my plan also but only covered 80km so far . That is great to hear that at least their software department is responsive
04-22-2024, 04:53 AM | #62 |
111
Rep 60
Finally, I have started the vehicle's break-in period. I am gradually acclimating the stroker engine, restricting throttle input to no more than half and ensuring that the RPMs remain below 4000 for the first 160 kilometers. Having already covered 80 kilometers, I can attest to its smooth operation and performance. Despite my efforts, maintaining the engine speed below 4000 RPM proves challenging, as the engine exhibits a strong inclination to rev higher.
Further break-in procedures will be conducted tonight, with an oil change scheduled for tomorrow. However, I have observed an issue following my initial drive. Upon cold start, there is a noticeable chatter or slapping noise at idle from the belly pan area. While I suspect it might be related to forged piston slap, I cannot confirm its exact origin. Importantly, this noise ceases once the vehicle reaches operating temperature. I have already contacted Carbahn regarding this matter, but I am also interested in your insights. Tomorrow, I will inspect the oil for any irregularities. Attached are recordings of the engine idling both at cold start and at operating temperature for your reference: |
04-22-2024, 05:08 AM | #63 |
mTekMods
2169
Rep 2,922
forged pistons are pretty clacky when the engine starts up cold, they expand at a different rate than cast pistons which is why the noise goes away when the engine is hot.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
e90sanmarino110.50 CamasM3e933224.00 |
04-22-2024, 08:53 AM | #64 |
111
Rep 60
Thank you for the clarification. I appreciate it, and I can now proceed with the engine break-in process with confidence
04-22-2024, 12:23 PM | #65 |
111
Rep 60
Today, I recorded a short clip while breaking in the engine. Despite only applying 1/3 throttle, the sound of the Eventuri Carbon Plenum is clearly audible. Having covered the initial 100 miles (160 km) of the break-in process today, I plan to change the oil tomorrow.
04-22-2024, 12:24 PM | #66 | |
1550
Rep 1,751
You can somewhat mitigate that with different oil, so you can test it out. Like I said, for me, I found Redline/300V 5W50 made things quieter, but I live in SoCal. Your mileage may vary in VN. However, I still hear the noise if I'm putting my ear against my hood or fender on cold starts.
