08-14-2022, 10:16 PM | #46 |
2840
Rep 3,715
08-15-2022, 01:39 PM | #47 |
2379
Rep 4,218
Que? Pump gas?
Mods: Yes.
08-15-2022, 02:47 PM | #48 |
2840
Rep 3,715
Yup, IDK anything about it, never ran it as a stand alone map. Released 8/4/22 as an additional v5.9 OTS map. v5.9 is the latest of all the M2 maps at the moment.
I assume it was just spun out of the Stg 2+ Multimap which included 93 octane as a map setting (Map 3), and has different boost and timing targets as the other 2+ maps (you can see this in the prior log I posted) and different from the regular Stage 2 93 map. Last edited by ZM2; 08-15-2022 at 02:55 PM.. |
AmuroRay2379.00 |
08-15-2022, 06:11 PM | #49 | |
7367
Rep 7,541
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
08-15-2022, 07:48 PM | #51 | |
7367
Rep 7,541
It's not always the case though, zm2's logs look fine with afrs going to low 12's at redline and dropping early. The other guys had high 13's until near the very end where it hit like high 12's for a couple hundred rpm. |
ZM22839.50 |
08-15-2022, 07:59 PM | #52 |
214
Rep 385
I checked with BM3 and it turns out a factory reset back to all the defaults fixed my psi issue. It looked like a bug. I was stuck in an endless look of absolute values
Do you have another thread detailing your build by chance? I have been looking at the turbo upgrade you are using for a while now but not completely clear on the supporting mods I need to create a reliable and efficient build. I am targeting around 500whp. I have the Dorch Stage 1 HPFP but no other fueling mods. |
ZM22839.50 |
08-15-2022, 08:06 PM | #53 | |
214
Rep 385
Stage 2+ 93 Standalone: 36.1 psi peak (absolute): https://www.bootmod3.net/log?id=62f5...729b2d5d52172e MultiMap Stage 2+ 93: 34.2 psi peak (absolute): https://www.bootmod3.net/log?id=62f5...90c6b67441dc2c Last edited by PilotxERAU; 08-15-2022 at 08:12 PM.. |
ZM22839.50 |
08-15-2022, 08:49 PM | #54 | |
2840
Rep 3,715
I don’t have a build thread, but you’ll need E85 and a Stg 1.5-2 turbo, or a giant laggy turbo to get to 500whp on 93. I’m a nice flat 480whp with a TTE460 and E50 on the Stg 2+ Multimap, with stock like spool. Apparently Pure is releasing a new PS1 with similar/better flow and good spool, but I haven’t seen more details on it. The Dorch stage 1 is good to 495whp with the updated HPFP table that I worked on with Dorch & PTF and a Stg 3 E50 beta map that Halim gave me, but the TTE460 drops power above 5500rpm with 23psi to hit that peak, hence why I just run the Stg 2+ Multimap with E50 to have nice flat top end power. If you want to bridge the gap to 500whp, you have two options: 1. Get a PS2 and run the same map but have more lag, 2. Run E60-80 on the 2+ Multimap with a TTE460 or new PS1 which will require an upgraded LPFP and more year round ethanol maintenance. And that’s why I stopped with my setup. 480whp @ 5500rpm and 540wftlbs @ 2600rpm is just a blast. However, I would love to see someone try to run E60-80 on a Stg 1.5 turbo to see what the curve looks like. |
08-15-2022, 09:39 PM | #55 |
830
Rep 647
That’s probably around 100whp and 120wtq more than where I’m at on the S291 tune which sounds… fun. Enough so I’m likely following you down the tte460 path.
I emailed Pure recently about their PS1 and sadly they didn’t mention anything new. The current PS1 is $2,000 less but if I’m going in this much I like the idea of the extra headroom the tte460 seems to bring. |
ZM22839.50 |
08-15-2022, 10:12 PM | #56 | |
2840
Rep 3,715
08-16-2022, 03:16 AM | #57 | |
214
Rep 385
I am new to the flexfuel game. Do I need anything other than the Dorch stage 1 to start mixing E85 in my tank? Even on the 93 octane map my timing is not the greatest. I would like to bump up the octane a bit. Am I good to add some pump E85 to help that without any concern? |
08-16-2022, 06:39 AM | #58 | |
2840
Rep 3,715
If everything looks good, you should be able to run up to E60 with the Dorch Stg 1 in the summer for more timing advance & power, and E50 in the winter. Altho, I’ll drop to E30-35 in winter so cold start cranking isn’t as bad. Changing bn Emixes during the year and pump gas on road trips is where the ethanol sensor and Multimap become very convenient. |
08-16-2022, 08:29 AM | #59 | |
214
Rep 385
So the stock LPFP is fine handling Ethanol? Looks like you are in Maryland, I am in the NOVA area, any stations you recommend for E85? Last edited by PilotxERAU; 08-16-2022 at 08:35 AM.. |
08-16-2022, 09:17 AM | #60 | |
2840
Rep 3,715
E25-30 is enough to clean up the Stg 2+ 93 map timing. If you want to feel what a high Emix map feels like, add half E85, half 93 (will get you E45-47ish) and flash the Stg 2+ E30 map--tons of fun. When you get tired of calc'ing Emixes, get the PTF flexfuel sensor and run the Multimap. It literally only took me only an hour to install and I was taking my time. Up here it's mostly Royal Farms & Sheetz stations for E85. Where you are it's those and a few Sunoco & Shell stations: https://afdc.energy.gov/fuels/ethano...on=reston%20va Download the Alt Fuels app from NREL to your phone for easy station finding: https://apps.apple.com/us/app/altern...ns/id718577947 Last edited by ZM2; 08-16-2022 at 09:24 AM.. |
08-16-2022, 10:21 AM | #63 |
2379
Rep 4,218
I missed that, thanks. Am I seeing 11-13 degrees in timing and 19PSI at redline on 93+? WOW
Mods: Yes.
08-16-2022, 10:27 AM | #64 | |
2840
Rep 3,715
But you have to remember that the Multimap maps are Flexfuel enabled, so they’ll increase timing based on Emix. Because I logged all four maps in the same log, they’re all with E50 and are benefiting from higher octane & timing adjust. And, not quite apples to apples, but in my very first post there is a Stage 2+ Multimap Map 1 log on E15. You’ll note boost is 19-20 psi while timing dropped to 7 to 8 degrees (vs 15 deg on E50) to compensate for the lower Emix. Last edited by ZM2; 08-16-2022 at 10:51 AM.. |
08-16-2022, 12:24 PM | #65 | |
2379
Rep 4,218
Mods: Yes.
08-16-2022, 01:12 PM | #66 | |
214
Rep 385
ZM22839.50 |
