08-03-2016, 05:11 PM | #45 |
BMW forever!
1395
Rep 2,428
This is why I am against buying new engine models for at least a couple of years.... but I do understand how you feel. Good luck
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
08-04-2016, 09:28 AM | #47 |
33
Rep 77
Yea... it didn't do it since i got the car back... and yesterday morning it did it once...
Current:2021 X5 M50i | 2022 XB7
Old: 2013 335i x-drive |retired 05-2016 ||2014 320i x-drive | retired 03-2018 ||2016 340i x-drive |retired 03-2018 ||2018 X5 |retired 06-2021||2018 430i | retired 10-2021 |
08-17-2016, 08:01 AM | #49 |
1412
Rep 3,211
08-18-2016, 08:15 AM | #50 |
33
Rep 77
Yea i've got an appointment next week... It only does it when the A/C is on... when the a/c is on i feel like the whole car struggles... i get a stumbling effect... and the squeak happens... when the a/c is off i got no issues.
08-18-2016, 08:31 AM | #51 |
1412
Rep 3,211
Did they say/or can you tell if the squeak was coming from the A/C belt slippage or the A/C unit internals?
I doubt the whole car would struggle unless high loads were placed upon it via the A/C belt.. perhaps the A/C unit itself was struggling causing high resistance high load on the belts causing eventual slippage.. keep us informed thanks. |
08-18-2016, 08:48 AM | #52 | |
33
Rep 77
All i could tell is that the squeak is coming from the driver's side and i'm sure of that 100%.
When they replaced the tensioner and belt, they started with that because they didn't know what to start with. After i got my car back, I tried reproducing the noise with the A/C on and off and i wasn't able to. 2 weeks after i got my car back, the noise happened again. This morning, cold start, floored my car with a/c off, no noise. Turned on the a/c, floored the car, squeak happened at first shift. Turned it back off, floored it, no noise, etc... once engine is warmed up the squeak doesn't happen again and that's what makes it hard to figure out. the timeframe is short to diagnose the origin of the noise. But it definitely only happens when the A/C is on. Quote:
08-18-2016, 01:38 PM | #54 |
33
Rep 77
Lol break-in is done... i'm over 4000 miles.
08-18-2016, 03:18 PM | #56 |
892
Rep 7,047
That almost sounds like an intake leak somewhere.
It could affect how the trans shifts, because depending on where the leak is it could disrupt the power flow, which can cause an odd shift. My 340i AT doesn't do this. Last edited by RPM90; 08-18-2016 at 03:25 PM.. |
08-20-2016, 09:38 AM | #57 |
1412
Rep 3,211
BTW do you guys who have this squeal get this in conjunction as well?:
'stumble' or rough idle after initial start once the RPMs go below 1000 and how the engine acts like its a cold startup everytime the car is started, regardless of how warm the engine is Also usually when the transmission squeaks like that the fluid is low or needs changing.. but these are almost new cars we're talkin about |
08-20-2016, 10:51 AM | #58 |
1412
Rep 3,211
BTW.. the M3 guys had an issue similar to this and the solution:
Dealer changed all belts and tensioners in the engine and the noise went away Hopefully its just that.. let us knoww hat yer dealer eventually does |
08-21-2016, 05:02 PM | #59 | |
33
Rep 77
Yea I get that stumble
08-25-2016, 04:49 PM | #61 |
2564
Rep 1,710
I stopped by a dealer today and spoke with the service manager. He said BMW was aware of the issue and was looking into it, but to date no one is sure what is causing the sound. He also mentioned that every one of their 340i demo/loaner's was making the sound. Said if a TSB was released they would call.
08-26-2016, 01:05 PM | #62 | |
33
Rep 77
Does your car do it with the A/C on or off?
08-26-2016, 01:45 PM | #63 | |
5944
Rep 10,317
Good luck. Hope the dealer will find the root cause. |
08-26-2016, 06:38 PM | #65 |
2564
Rep 1,710
