10-13-2022, 01:40 AM | #45 | |
570
Rep 896
You may have already attempted to cover this and/or maybe you need more seat time before opining on this, but how do you feel the car maintains it's composure over bumpy/crappy roads? Also, how jarring do you feel the car is over sudden bumps or depressions in the road? Def looking forward to photos, to get an idea of stance. Many thanks!
Previously:
2010 E92 335 (6MT) 2011 E92 M3 ZCP (6MT) |
10-13-2022, 12:44 PM | #46 | ||
75
Rep 133
I've attached a few photos…sorry for cloudy day and dirty car. I'll try to find an old picture with Eibachs and stock shocks for comparison. |
RElias21570.00 |
10-13-2022, 12:53 PM | #47 |
75
Rep 133
Photos aren't exactly like to like but should help compare.
Sunny pics = Eibach V1 + stock shocks (from two years ago) Cloudy pics = Eibach V1 + Evolve Bilstein B6 |
RElias21570.00 TractionControlDelete4602.50 |
10-14-2022, 09:01 PM | #48 |
30
Rep 119
Thanks for your review JeffB-M3. May I ask which EDC coding you are using? OEM base?
General question for Imran@Evolve. How would these pair with CS EDC coding? |
10-15-2022, 07:32 PM | #49 |
75
Rep 133
10-17-2022, 05:04 AM | #50 |
BimmerPost Supporting Vendor
5386
Rep 3,796
I used both OEM and CS coding. OEM is great but CS is incrementally better. Even more composed. Worth the small investment. Get the GTS Traction, E-Diff and Steering at the same time. Excellent way to spend $200 or so.
TractionControlDelete4602.50 gemurdock6.50 |
10-19-2022, 09:10 AM | #51 |
457
Rep 312
I have B6 Damptronic with Swift springs on my E92 M3, and Tractive on my F80 M3. I think the Bilstien back to back with the Tractive, most people would take the Bilstien.
10-19-2022, 12:45 PM | #52 |
284
Rep 703
That's not exactly an apples to apples comparison. Bilstein is know to be more of a stiff setup on F8x. I have tractive coilovers on my F80 and I'm loving it so far.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
10-20-2022, 12:12 PM | #54 | |
570
Rep 896
Previously:
10-21-2022, 04:42 AM | #55 | |
5386
Rep 3,796
B16 EDC are very good in compliance/handling. Our EDC are slightly more compliant. Handling is dependent on what springs are being used. With normal springs not as good as B16. With MSS better than B16 - this is what we ran on our demo car as its final iteration. |
RElias21570.00 |
11-15-2022, 10:50 PM | #57 |
110
Rep 216
Just got my M4 back. Running the Evolve x Bilstein B6 Damptronic Dampers with MSS HAS now. The reviews and videos on Youtube are indeed true and accurate. Car is very compliant on my brief drive home, tested on local roads that are complete garbage and also on the highway. Car soaks up bumps very well and car stays very planted along with my hotchkis sway bars. My OEM shocks only had about 34k miles on them, granted my car is 2015. Swapping over was a very nice improvement.
I actually swapped over from KW HAS since it was too low for me. I was running KW HAS + OEM EDC. Car was a bit bumpier, perhaps due to it being lower, but the Bilsteins + MSS HAS is much more satisfactory. Drove on the highway in Sport and it rode like a Lexus, but stayed planted. Comfort / Sport on crap local roads and it was not bad at all. Sport+ definitely felt rougher, but tolerable and improved response. Very satisfied with the upgrade and highly recommend as an alternative to the KW DDC / Bilstein B16 that is said to be much rougher ride.
2015 Black Sapphire F82 M4: Bootmod3 Stage 1 Tune / GTS DCT TCU DIFF Flash / Remus Catback / VRSF Charge & J Pipe / MST Intakes / Mishimoto TMIC / RK Autowerks Crank Hub / Apex VS-5RS 19x9.5 ET22 19x10.5 ET45 / Powerflex Bushings / MSS HAS / Evolve x Bilstein B6 Damptronic / Vorshlag Camber Plates / Hotchkis Sways
11-16-2022, 06:25 AM | #59 | |
5386
Rep 3,796
Deteria109.50 |
11-16-2022, 08:31 AM | #60 | |
570
Rep 896
I've only seen Imran@Evolve review on youtube. Have you seen others? Can you provide links? Also, can you post photos of your setup on the MSS HAS?
Previously:
11-17-2022, 05:14 AM | #61 | |
5386
Rep 3,796
FrozenGT1142.50 |
11-17-2022, 08:09 AM | #62 |
Rep 35
Hi there I’m sorry is this has been covered somewhere. But I recall it being said that the b6 are not recommended for lowering springs. Are your version of the b6 shorter to suit lowering springs?
11-17-2022, 08:31 AM | #63 |
5386
Rep 3,796
The normal B6 and our version are perfectly fine to use with lowering springs. We had been using normal B6's with 30mm lowering springs before developing our own.
11-17-2022, 10:44 AM | #64 | |
Rep 35
So I have a 2017 m3 competition bm3 stage 1 with gts dct and gts mdm on eibach springs with 763m wrapped in mps4s Would recommend your b6 dampers with my springs, or am I going to be better with the mss springs you mentioned. Thanks again for your input |
BermudaKID16.00 |
11-17-2022, 11:58 AM | #65 | |
5386
Rep 3,796
Nickshawf803.00 chipper19.50 |
11-18-2022, 10:35 AM | #66 | |
110
Rep 216
Sorry haven't been out and about since I got the car back to snap nicer photos. Took a few quick ones while in the garage. Height-wise, I purposely went with form & function since I don't want to destroy my front lip and I don't much care for being that low. I had my shop do a 5mm drop from factory measurements. Also I believe I'm running ~ -2 degree front camber. 265/35 & 285/35 19s.
