M2 Technical Topics > Suspension | Brakes | Chassis > BMW M3/M4 F8X Carbon Fiber Strut Mod on the BMW M2
      03-19-2019, 04:59 PM   #45
Bee Pee
Bee Pee's Avatar
1788
Drives: AW M2 DCT
Originally Posted by M Fifty View Post
Noting that I've removed the steel strut brace, have all the bolts, fitted the top hats, set the rivnuts, and (given that I'm obsessive) have the correct plastics, I'm looking for some dry weather to fit the rest.
Not driving it atm obvs...
M50
By correct plastics - do you have m2C plastics ?
If so please post part numbers
TIA
BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      03-19-2019, 05:08 PM   #46
JonD
205
Drives: 1 Series Coupe, M Sport
The two side panels are;
51768073534
51768073533
Saves cutting the originals
      03-19-2019, 05:20 PM   #47
JonD
205
Just been checking realoem, seems the M2OG and the comp share the same part numbers for the upper rad support (crosslink) so no need to change that.
Edit: I’ve just had chance to cross ref the crosslink part numbers with the M4, they are the same, I’m puzzled why Bluebro changed it on his conversion.
      03-20-2019, 06:41 PM   #48
Bee Pee
Bee Pee's Avatar
1788
Drives: AW M2 DCT
Edit: I've just had chance to cross ref the crosslink part numbers with the M4, they are the same, I'm puzzled why Bluebro changed it on his conversion.
Bluebro retrofitted this twice
1st time was on his f22 m235i - crosslink upgraded to F8x version.
2nd time was F87 OG M2 - existing standard f87 crosslink used
      03-20-2019, 08:13 PM   #49
PilotxERAU
214
Drives: 2018 F87 M2
I got mine dialed in thanks to Bee Pee posts and others on the forum
Appreciate 2
Bee Pee1787.50
ddnmkun156.50
      03-21-2019, 02:53 AM   #50
M Fifty
847
Drives: M2 & 330CI
M50
TIA
BP
I bought
M2C Cowl Panel Cover - 51 71 8 073 546
M2C Engine Hood Seals (fits by the bonnet hinges) - 51 76 8 073 533 &534
M3/4/2C Covers - 51 71 8 059 699 and 64 31 8 059 697
plus the rubber covers that go over the strut tops.
The M3/4 bits were used, but the rest were new.
The M2C Cowl panel cover fits at the base of the windscreen and allows you to use the M3/4 Covers.
Appreciate 3
JonD204.50
Bee Pee1787.50
pal437.00
      03-21-2019, 03:58 AM   #51
Bee Pee
Bee Pee's Avatar
1788
Drives: AW M2 DCT
M50
TIA
BP
I bought
M50
Many thanks for the list. Ballpark price for them ?
M2C cowl cover - have you had a chance to compare m2 vs M2C parts ?
I was under the impression that both m3/m4 L&R scuttle covers could fit with m2 cowl cover panel.
Cheers,
BP
      03-21-2019, 05:41 AM   #52
Bee Pee
Bee Pee's Avatar
1788
Drives: AW M2 DCT
Pilot,
Looks superb - did you re-use or change many of the plastic parts ie seals etc near the windshield and on the tops of the fenders ?
Thanks,
BP
      03-21-2019, 05:56 AM   #53
PilotxERAU
214
Drives: 2018 F87 M2
Pilot,
Thanks,
BP
Other than the M3/M4 top hat engine seals I reused all the OG M2 plastics. Cut them with a dremel. No one knows the difference 👍🏼
Bee Pee1787.50
      03-21-2019, 01:37 PM   #54
M Fifty
847
Drives: M2 & 330CI
M50
Cheers,
BP
I paid a little over £75 for the cowl and the hinge covers.
The cowl fits identically to the OG one, but has fixings to suit the M3/M4 L&R scuttle covers.
      03-24-2019, 01:31 PM   #55
M Fifty
847
Drives: M2 & 330CI
Finished!
I still need to do some tidying up, but it's drivable.
Finally torqueing up the bolts that go into the rivnuts will have to wait until I find a way to get my 3/8ths Torque Wrench in there without unbolting the front wings...
Appreciate 2
JonD204.50
Bee Pee1787.50
      03-24-2019, 01:44 PM   #56
JonD
205
Nice work M Fifty! Straight forward enough job?
Probably start mine in a few weeks, but as it’s my daily will be done in the day. Unfortunately some of my parts have gone awol in the post, so need to source some of them again
      03-24-2019, 02:21 PM   #57
M Fifty
847
Drives: M2 & 330CI
Well, mostly it was just follow NewTIS.info and the various threads from people who have already done it. However:
1. Make sure the battery is disconnected before you try test fitting the aluminium brace as it gets alarmingly close to the lead for the jump start terminal.
2. The bracket for the ABS unit gets in the way. You may wish to follow the approach of others and put some felt between it and the brace.
3. Buy a bag of press rivets from BMW. You'll need them, even if you don't mangle a few.
4. I set the rivnuts on the inner wings using an approach using a bolt, some penny washers, some spring washers and an oversized nut described on YouTube. It works well. As previously mentioned, torquing the bolts once the brace is fitted is a bit tricky.
5. Either invest in some cheap towels to act as protective blankets or recycle the oldest ones in the house.
6. The engine cover needs to come off to reseat the engine bay seal that sits between it and the windscreen. The front right mount for the cover goes back on much more easily with some lube on the rubber bush.
7. A really big breaker bar works wonders when finally tightening the two bolts just in front of the windscreen.
8. Take your time, and while i think I could do the whole thing in under 4 hours now, give yourself a couple of days.
HTH
Last edited by M Fifty; 03-24-2019 at 06:09 PM.. Reason: Realism on time. It's 30m/side for the strut tops.
pal437.00
      03-28-2019, 04:40 PM   #58
M Fifty
847
Drives: M2 & 330CI
Noting that I've only had the chance to give it some on the 10 mile drive to work (over half on rural roads, the rest on streets) and the weekend still beckons, the results are surprising.
Steering, general front end feel, and - surprisingly - braking all feel significantly different.
Steering and front end in corners over 40 mph.
Brakes more generally, but Big Stops...
So, the combination definitely does something compared to the OG steel items. As to how?
      04-16-2019, 07:34 PM   #59
Mike0105
58
Drives: 2018 BMW M2
Can anyone with an M2 LCI let me know if they had to change the strut mounts in order to retrofit the carbon fiber brace? It's the one piece I'm still not sure about.
Thanks,
Mike
      04-16-2019, 07:54 PM   #60
PilotxERAU
214
Drives: 2018 F87 M2
Thanks,
Mike
Yes you must switch out to the M3/M4 5 bolt top hats.
M Fifty846.50
      04-18-2019, 02:40 PM   #61
Mike0105
58
Drives: 2018 BMW M2
I thought the LCI's had that, at least I was hoping they did. That's the piece holding this project up for me although I do have a shiny carbon brace sitting in the garage.
Mike
      04-18-2019, 07:21 PM   #62
PilotxERAU
214
Drives: 2018 F87 M2
Mike
Unfortunately you have to pull the springs out and replace top hats. I was a bit surprised by this as well but I did it on my own first time ever messing with suspension. I followed a YouTube vid of a dude taking his off an M2 and it worked great. All in all I think it is worth it. The car is really ridged now. I can jack up one front side and the other wheel comes off the ground!
      04-19-2019, 03:29 AM   #63
M Fifty
847
Drives: M2 & 330CI
It is 'just' possible to replace the top hats without removing the spring by supporting the front suspension on a jack, undoing the top nut and then lowering the suspension until you have clearance to swap the top hats over.
Then carefully raise the front suspension again on the jack while making sure the spring seats properly and the damper shaft goes through the hole in the top hat.
You will still need to disconnect the drop link on the roll bar and the headlight aim adjuster as if you were removing the spring/damper/top hat and doing the swap with spring compressors on the bench.
      05-20-2019, 06:37 AM   #64
3t3p
New Zealand
455
Drives: M2
ALL those parts above on Rybrook BMW parts online with SMILE discount code =£1850.56
Ouch. Worth it? Bee Pee do you have it fitted?
      05-20-2019, 10:55 AM   #65
Bee Pee
Bee Pee's Avatar
1788
Drives: AW M2 DCT
not fitted m4 alloy brace yet - next month hopefully if work agenda and family priorities both align to allow me more fettling time
      05-21-2019, 11:04 AM   #66
3t3p
New Zealand
455
Drives: M2
Let us know how you get on please
Just made a thread on another aftermarket strut bar that looks easy to install at a more palatable price point....!
Tags
bmw m3, bmw m4, carbon fiber strut conversion
m2
