The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > E Series NBT Evo Retrofit Development Thread
      04-02-2024, 07:01 AM   #441
painsage
Drives: BMW E60 520d
Originally Posted by RedErik View Post
Do you get no signal message or completely black screen? If all black screen check what have you under VEHICLE_STATE_CONCEPT, should be conventional_clamp.
I realized that someone had rewired the emulator, not to be the factory pinout like in the schematics, today im gonna revert it back to stock and try then. I noticed on my bench, changing gatewaytable to 5 or 7 makes it blackscreen, im guessing the eNBT will fix this when its all in car?
      04-02-2024, 07:37 AM   #442
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
Mine's set to 5 and runs fine on the bench without emulator connected.
      04-02-2024, 07:51 AM   #443
painsage
My ID6 is from G30 so its KCAN4, i have not gotten an answer yet does the adapter support KCAN4...
      04-02-2024, 07:59 AM   #444
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
So is mine, but that makes no difference. KCAN4 in G30 is an equivalent of KCAN2 in Fxx. It's just an arbitrary number to differentiate CAN buses - i.e. they were given numbers to differentiate their use. KCAN4 connects HU, ATM, IHKA and ZBE, but the technical spec of each is the same.
      04-02-2024, 08:02 AM   #445
painsage
So is mine, but that makes no difference. KCAN4 in G30 is an equivalent of KCAN2 in Fxx. It's just an arbitrary number to differentiate CAN buses - i.e. they were given numbers to differentiate their use, 4 does HU, ATM, IHKA, ZBE etc. But the technical spec of each is the same.
You saved me of hours of overthinking, thanks a lot. Im using ZBE3 from NBT from F10, i did zbe_35UP to nicht aktiv in my EVO, this should make the controller work, correct?
      04-02-2024, 08:06 AM   #446
rlesko
243
Drives: F30 335i
2012 335i  [0.00]
I'm not sure this is totally accurate- aren't some of the KCAN buses are actually running at different frequencies and possibly data length? While I'm sure that some of properties of the different KCAN networks in the car are the same, I don't think they are all the same and the numbering is totally arbitrary.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo
      04-02-2024, 08:14 AM   #447
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
This is from TIS:
The K-CAN is counted according to the number of bus connections that lead from the central gateway module: for example K-CAN2 to K-CAN8.
Overview of the bus systems
In principle, two groups of bus systems are distinguished:
-> Main bus systems: for example, Ethernet, FlexRay, K-CAN2 to K-CAN8, MOST, PT-CAN and PT-CAN2
‐> Sub‐bus systems: BSD, D‐CAN (diagnosis-on-CAN), LIN, local CAN
Body CAN: Body CAN
The K‐CAN is responsible for communication of the components with low data transfer rates. The K-CAN is also linked to the other bus systems via the central gateway module (ZGM). A number of control units in the K‐CAN have a LIN bus as sub‐bus. The K‐CAN has a data transfer rate of 100 kBit/s and consists of 2 twisted cores (two twisted wires). The K‐CAN has the possibility to be operated as a single-wire bus in the event of errors.
Body-CAN2 to body-CAN8: K-CAN2 to K-CAN8
The K-CAN2 to K-CAN8 is responsible for communication of control units with high data transfer rate. The K-CAN2 is also linked with the other bus systems via the central gateway module (ZGM). The K-CAN2 to K-CAN8 has a data transfer rate of 500 kBit/s and consists of 2 twisted cores.
Powertrain CAN: PT-CAN
The PT‐CAN connects the engine control system with the transmission control unit, but also interconnects systems in the area of safety and driver assistance systems. It is line-based with tap lines to the individual systems. The PT‐CAN has a data transfer rate of 500 kBit/s and consists of 2 twisted cores.
Powertrain CAN2: PT-CAN2
The PT‐CAN2 forms a redundancy for the PT‐CAN in the area of the engine control system and also transfers signals to the fuel pump control module. The PT‐CAN2 has a data transfer rate of 500 kBit/s and consists of 2 cores with an additional wake-up line.
Ethernet
Ethernet is a manufacturer-neutral, cable-based network technology with a data transfer rate of 100 MBit/s. The TCP/IP (Transmission Control Protocol/Internet Protocol) and UDP (User Datagram Protocol) protocols are used as transfer protocols.
FlexRay
With a maximum data transfer rate of 10 MBit/s per channel, FlexRay is significantly faster than the data buses used so far in vehicles in the areas of body and drive/chassis and suspension. The central gateway module sets up the link between the various bus systems and the FlexRay. Depending on the equipment fitted in the vehicle, the ZGM has one or two so-called star couplers, each with four bus drivers. The bus drivers forward the data of the control units via the communication controller to the central gateway module. The deterministic data interchange ensures that each message is transferred in the time-controlled section in real time. Real time means that the transmission takes place in a specified time.
MOST bus system
MOST is a data bus technology for multimedia applications. The MOST bus uses light impulses for the data transfer at a rate of 22.5 MBit/s and has a ring structure. Data transfer on the ring bus takes place in one direction only. Only the central gateway module can implement data exchange between the MOST bus and other bus systems. The car information computer (CIC) acts as the master control unit The gateway to the rest of the bus system is the central gateway module.
So as you can see there are various buses in a car, but all KCAN2 to KCAN8 are the same. They just connect different equipment to make the required topography and not overload each bus.
rlesko242.50
      04-02-2024, 08:17 AM   #448
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
I didn't change anything for the ZBE apart from coding in all ZBE_TOUCH functions. As far as I can tell, ZBE from F10 and G30 are the same, just the button layout is different, but you can change that with coding to suit yours.
      04-02-2024, 08:21 AM   #449
painsage
Hmm, im gonna try. The only thing thats weird right now is the gatewaytable thing. I am using ZGW2 on my bench, how about you?
      04-02-2024, 08:24 AM   #450
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
I'm using ZGW-02 8SK as I read somewhere that others can cause communications issues of some sort.
      04-02-2024, 08:26 AM   #451
painsage
I had ZGW1 black box with most, then flashed to ZGW2, maybe thats whats causing the gatewaytable issue. Im gonna update you when im in car.
EDIT: Can you PM me any of your contact info in case i need help? I cant use PM function.
      04-02-2024, 08:27 AM   #452
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
That would explain your issues, I think...
      04-02-2024, 08:35 AM   #453
painsage
One more thing, what adapter are you using? I'm using the base NBT adapter from Adrian (CarSystems), the one with 10 pins.
      04-02-2024, 08:38 AM   #454
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
My DMs are disabled, was getting too many messages. Here, it will save me typing all of that, at the end of this video you will find all my contact details.
      04-02-2024, 08:39 AM   #455
RedErik
RedErik's Avatar
Scotland
1050
Drives: E63 645Ci
I think the forum is blocking that link... www . bmw custom retrofit . com /navigation-retrofits/bmw-nbt-retrofit-adapter-for-e-series-nbt-e-series-evo-id5-id6
      04-02-2024, 08:48 AM   #456
painsage
I have that exact one, im gonna shoot you a DM on Facebook, already sent a request, thanks a lot.
