2010 2011 BMW 5 Series Forum F10 M5 Diffuser Install with Comfort Access F10's |
06-02-2014, 12:23 PM | #23 |
5507
Rep 8,835
I don't believe you can order it painted but i'm sure If you are willing to pay for it any vendor would arrange for this to be done. I'd contact Evan at Tischer or maybe even IND since they do lots of paint work on parts they sell.
Alan
07-17-2014, 02:01 PM | #24 |
Rep 15
Drives: 13' 550i xd AW
anyone know the part # for the M5 diffuser, i know tisher has the package but what just wondering what the part # so I can check wholesale price. Someone hit mine and need to order new one. Is it two pieces or one? mine I have came 2 separate pieces.
2013 550xi AW Msport, BMS STAGE 2, Meistershaft EV exhaust, acs springs, high flow filters & scoops, Niche m130 wheels, m5 diffuser
HelixBmw39.00 |
07-26-2014, 08:02 PM | #25 |
Rep 7
http://realoem.com/bmw/showparts.do?...79&hg=51&fg=17
Should be parts labeled 25 and 26 for the M5... |
07-30-2014, 12:42 AM | #26 |
59
Rep 513
Do all comfort access BMWs have the foot activated tailgate?
2018 Lamborghini Huracan Performante
2012 Ducati Panigale 1199 S 2019 Ducati Panigale V4R |
08-26-2014, 08:54 AM | #28 |
5507
Rep 8,835
Once you get the bracket you can mount any diffuser meant for the M5. The rear bumper area is the same between all F10 models once you get this.
All comfort access cars have the foot activated tailgate.
10-22-2014, 04:56 PM | #29 |
Rep 47
2011 550I M Sport has not trunk Comfort Access feature??
I'm adding the OEM M5 exhaust and OEM M5 Diffuser.
my car is a 2011 M sport with comfort access, however it does NOT have trunk comfort access feature. Do I need to order the M5 specific Bracket for the M5 diffuser? Or, as I have no trunk comfort access, is this not necessary? Thanks! |
10-30-2014, 11:04 PM | #30 |
Rep 3
Drives: 2015 Bmw 535i Msport
I've always thought the M5 diffuser looked amazing, but I'm wondering if the bracket will fit on the 2015 model? I have the comfort access including the trunk.
03-06-2015, 11:52 AM | #32 |
5507
Rep 8,835
You need to be able to maneuver the bumper insert out and back in and the only way to do that is to loosen one side of the bumper gain more room. To loosen one side of the bumper there is a screw that tailight is blocking.
03-06-2015, 07:53 PM | #33 |
37
Rep 256
I just did this the other day. You need to remove one side so you can remove the screws that are holding the bumper. Then remove the black plastic piece and replace it with the new one that will go with your M5 diffuser. I eventually just did the other side as well so I can install my new diffuser the remount the entire bumper. It isn't as bad as it looks removing the entire bumper.
03-06-2015, 07:57 PM | #34 | |
23
Rep 152
03-09-2015, 11:57 PM | #36 |
91
Rep 291
03-10-2015, 01:38 AM | #37 |
27
Rep 159
I have a 2014 535i Msport and I would like to add the 550i diffuser as I would like to add a quad exhaust. Which is the part number for the 550i diffuser in this diagram and where can I order this from? Thanks in advance! |
03-10-2015, 03:41 AM | #38 |
23
Rep 152
You can't really see but it's pretty simple. I actually found out how to do it from one of the other guys on the forums here. Look up how to install M5 diffuser and there should be one guy that just cut the plastic piece just like I did.
04-02-2015, 02:37 PM | #39 |
36
Rep 168
My conversion from Non M bumper to M5
Here is my conversion from Non M bumper to M5 bumper with quad exhaust
http://f10.5post.com/forums/showthread.php?t=1110496 |
04-02-2015, 02:39 PM | #40 |
36
Rep 168
Extra parts
And i have some remaining parts from my conversion
http://f10.5post.com/forums/showthread.php?t=1110483 |
05-09-2015, 01:39 PM | #41 |
Rep 43
Just did this today. Wanted people to know that when removing the bumper cover, you DO NOT need to remove the light. In fact, you can skip the steps about removing any of the plugs within the trunk which holds the inner linings together. All you need to do within the trunk is to remove the drip guard and you can access the one bolt that is holding the bumper cover. Don't fool yourself, this takes sometime, about 3 hours.
08-19-2015, 06:19 PM | #42 |
452
Rep 844
I have had comfort access all this time and never known that... I always just used the button on the trunk! Guess not a huge loss if I do this and lose that.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
08-19-2015, 07:13 PM | #43 | |
Rep 81
08-19-2015, 08:17 PM | #44 |
31
Rep 340
