11-01-2013, 10:31 AM | #23 | |
Yankee Air Pirate
157
Rep 978
ED cars are basically the exact same thing as one built to be shipped directly to a US dealer -- so they have every feature hardware and software required by the US (an obvious example is the orange front side reflectors). The have the US plate mounts in the trunk, and the euro plates are taped on. They include the european driving mandatory items (first aid kit, warning triangle) in the trunk, but US customs will dictate their removal at port or processing if you dont bring them back... Bottomline is that ED care should just be considered a US-spec car allowed to drive in the EU. For this discussion, the ED car is no different than any other M5 delivered to a local dealer. The best comparison of files would probably be between a no kidding european M5 and a US one. I dont know if any of our non-Brit european members have upgraded to the '14 yet.
deposit placed for 2025 G99 ///M5 Touring || 2020 F90///M5 || 2014 F10 ///M5 || My Epic ED trip report|| || 2009 BMW R1200RT
11-01-2013, 10:34 AM | #24 |
115
Rep 653
B-1 Pilot:Yup, and that what we are doing: comparing the coding data side by side (see my posts higher up). I have located a UK 2014 ///M5 owner and as you mentioned it would be nice to have more to work with. Hopefully they are reading this and will come forward.
So a vehicle built for and sold to a US market customer/ dealer leaves the factory in a "final" US region state/ specs. This means, no reprogramming is taking place before or after USA-bound shipping for the ED delivery. |
11-01-2013, 10:45 AM | #25 |
Yankee Air Pirate
157
Rep 978
as far as I know, this is correct.
11-01-2013, 11:01 AM | #26 |
115
Rep 653
And it makes sense, it would hinder their operations since it would be one more thing to perform, time spent, staff assigned, chance something might go wrong etc.
***why can't I use the syntax to address you directly, works for other other ones but not you screename: ? Maybe we can conduct some research for the assembly parts, not sure what web sites to use to compare european and US builds though. I only know of realoem.com |
11-01-2013, 08:50 PM | #27 |
124
Rep 1,840
Drives: '14 M5 CP Dinan Stage 2
DRL?
11-01-2013, 08:53 PM | #28 |
124
Rep 1,840
Heres what it says. I read that as they will add it to the car. Thoughts?
11-02-2013, 07:59 AM | #29 |
115
Rep 653
DRL: daytime running lamps or lights
In the discussion above, we were referring to the rear tail lights being on when the front halos/ angel eyes are on (via DRL ON in iDrive > Settings > Lighting). Like this: To your other comment: yes will prob. have to remove 5AP and 8S4 from the VO and then code a few modules. But there are prob. other differences within the modules (question is also which ones) we would like to uncover. Hardware: apparently no differences based on realoem.com I hope this is correct! Headlights assembly for a Euro Spec'ed LCI F10 01 LED module for turn signal, right 1 07/2013 63117352554 02 LED module for cornering light, left 1 07/2013 63117352477 02 LED module for cornering light, right 1 07/2013 63117352478 03 Gasket set 2 07/2013 63117349288 04 LED display for fan, left 1 07/2013 63117352479 04 LED display for fan, right 1 07/2013 63117352480 05 LED main light module 1 07/2013 63117367261 06 Headlight control module, LED 2 07/2013 63117381018 Headlights assembly for a USA Spec'ed LCI F10 01 LED module for turn signal, right 1 07/2013 63117352554 02 LED module for cornering light, left 1 07/2013 63117352477 02 LED module for cornering light, right 1 07/2013 63117352478 03 Gasket set 2 07/2013 63117349288 04 LED display for fan, left 1 07/2013 63117352479 04 LED display for fan, right 1 07/2013 63117352480 05 LED main light module 1 07/2013 63117367261 06 Headlight control module, LED 2 07/2013 63117381018 |
11-02-2013, 10:56 AM | #30 | |
Knight Commander
563
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
11-02-2013, 01:02 PM | #31 | |
124
Rep 1,840
11-02-2013, 01:21 PM | #32 |
Yankee Air Pirate
157
Rep 978
yes, the simple high beam assist works on our cars (its a simple toggle on and off when the camera senses oncoming lights).. the advanced version that doesn't actually turn the highs off, but shapes the beams around the oncoming traffic has not been DOT approved yet, so it is coded off on US bound cars.
couple of vids..
11-02-2013, 01:47 PM | #33 | |
129
Rep 1,622
Edit: never mind.. looks like the system doesn't recognize the "-" character so when you type it out, it recognizes all characters before the dash. By the way, isn't there a VO for region? I hope you can crack this. Would be a nice feature to have in the US.
2013 BMW INDIVIDUAL ///M5 {Frozen Black/Amaro Brown/Amaro Brown Alcantara/White Contrast Stitching/Piano Black Trim}
11-02-2013, 03:54 PM | #34 |
Knight Commander
563
Rep 5,948
dashes and spaces and other non traditional characters prevent you from using the @ to tag people. I have the same issue with ///M Kid and ONE OF 40 FS M3
They should have a warning message to help pick taggable names.
11-02-2013, 08:21 PM | #35 |
is nonexistent with N/A
21
Rep 1,126
Or, better yet, when you type in @, it should give a popup to tag people.
11-02-2013, 08:24 PM | #36 | |
Knight Commander
563
Rep 5,948
11-02-2013, 11:02 PM | #37 |
129
Rep 1,622
test..
@avlnch @ONE\OF\40\FS\M3 "@ONE OF 40 FS M3" @ONE*OF*40*FS*M3 "@ONE OF 40 FS M3;" @ONE OF 40 FS M3; ONEOF40FSM3; Hmm.. I don't know, I give up. @Jason - is this the DBTech Mod for vB? do you know if it supports usernames with spaces and dashes?
11-03-2013, 09:44 AM | #38 |
Rep 62
Hello, I just took delivery of a F32 with LED's and I'm on the same mission to enable the full adaptive functionality. Let me know what I can do to help out.
11-03-2013, 10:03 AM | #39 | |
21
Rep 1,126
ONE_OF_40_FS_M3 |
11-03-2013, 12:36 PM | #40 | |
124
Rep 1,840
11-10-2013, 03:56 PM | #44 |
BMW Motorsport
237
Rep 2,225
Drives: BMW ///M4 F82 / BMW ///M5 F10
its done
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White |
