05-28-2013, 08:25 PM | #24 | |
41
Rep 666
So yes a car could run with RBs installed without any supporting mods, other than a tune. But why would you want to? |
05-28-2013, 08:34 PM | #26 | |
171
Rep 2,682
I think Steve may have been referring to Advan's upcoming ST kit. Vishnu don't make RHD ST kits I believe. |
05-28-2013, 08:36 PM | #27 |
171
Rep 2,682
05-28-2013, 08:38 PM | #28 |
41
Rep 666
05-28-2013, 09:13 PM | #29 | |||
41
Rep 666
When you are talking $30K "if not more", think built motor with an OS Giken twin-plate clutch, complete cooling upgrade, methanol injection kit, fuel system upgrade etc. plus install and tuning. Oh, the above would also use a larger frame turbocharger than the Garret GTX3582R we are currently working with for the prototype kit, the GTX35 kit will not require a built motor. Cheers, JD. |
05-29-2013, 12:44 AM | #30 | ||
128
Rep 3,099
and can you clarify the wastegate design being inferior? as the vargas design is billet, just as the RB one is..? "carefully machining them to accept the TD04 compressor Wheel, and Custom TF035 / TD04 turbine wheel. We then replace the factory waste gate arm and flapper valve with the 100% stainless steel version and include OEM actuators." and the latest up-to-date dynos with a good tune show about the same numbers and spool compared to the vargas. slower spool was due to some reason, tuning i believe power wise.... up top you could be right? little more to the left? that i'm not sure on, still waiting on more logs and graphs Quote:
i know i personally would be convinced to buy it for the right price with teh right sized turbo, when i'll already have everything else done. GTX42? or 6466/6766? om nom nom haha |
05-29-2013, 03:39 AM | #31 | |
41
Rep 666
"The wheel is slightly smaller, we really liked the profile and design the TF035 had, that is why we chose to use it and have it modified to fit our needs. its a full back design which are more efficient at moving exhaust through the wheel which in these things is very important, we shall see." Here are rader1's dyno results. Peak torque looks to be about 4,250 rpm by my calculations. A RB turbo car will usually see peak torque by 3,500 rpm. Perhaps rader1's dyno graph is not a true representation of the spool characteristics of the VTT "Stage 2" turbos, but that is the only valid graph I have seen thus far. Is there another one out there I have missed? I have seen several logs showing slow spool too, but one of those from jpsimon was definitely in 3rd gear, so that is neither here nor there. Perhaps the others were too, so I am happy to ignore those for the time being. |
05-29-2013, 04:06 AM | #32 |
41
Rep 666
Here is dyno graph from my own 135i, that illustrates the comparative torque curve of the vehicle when equipped with RB turbos and prior with the OEM TD03 snails.
As you can see the RBs take longer to spool initially, but the peak torque rpm of the RB turbo vehicle with a conservative tune, is VERY similar to the FBO OEM turbocharged car, when the stock turbos are being pushed quite hard. Last edited by Justin@ADVAN Performance; 05-29-2013 at 04:11 AM.. Reason: Revision |
05-29-2013, 04:21 AM | #33 |
128
Rep 3,099
Mmm it's a bit lame, how little info there is
Most of them seem to be getting on it in the next few weeks - hopefully a good cobb protune fairly well optimised ... Plus in the next 3 months or so apparently stage 2 vargas is getting 'options' so possibly some standard td04 option like the rb's? Unless rb's come down in price again though... Vargas is pretty cheap The one you posted is still 475whp - albeit on a dynojet Ed: i can't read your graph.. What rpm is each km/h and wht is the left column 'n'... Can't be newtons as thats not torque at all lol |
05-29-2013, 08:40 PM | #34 |
39
Rep 672
That is tractive effort. It is the force applied to the rollers at the radius of the rollers. Therefore the shape of it is the same as the torque shape, but the units are not the same.
05-30-2013, 12:11 AM | #35 | ||
41
Rep 666
yeah there is not a lot of solid info out there on the VTT "Stage 2's" which is a bit surprising, as these were initially released to customers as beta sets, for the purposes of testing and evaluation. I have not read anything about the turbo "options" you refer to, but if Vargas swap out their TF035HL "fullback" wheel for an "actual" TD04L wheel, the cost of the Vargas turbochargers will go up quite a bit. They will have to machine the exhaust housings for readaptation of the larger TD04 centresection, which is a MUST if they go to TD04L wheel. Right now the original OEM TD03 centresections are being used with the 035... exhaust wheel, at a considerable saving of machining time over the use of a true TD04 centresection. As it stands right now Rob's turbochargers are only $300 more when compared to the VTT S2's with the upgraded thrust component option, assuming equivalent shipping charges, core charges and import duties/taxes (which they all should be). Prior to VTT/Tony coming onto the scene, RBs cost quite a bit more to purchase. Competition has forced Rob to revise his prices downwards, which is good news indeed for the N54 enthusiast. It is great to have options when upgrading the turbochargers on your vehicle and major props go to Tony for his advancement of the N54 platform and the achievements made in such a very short space of time. However for the sake of a $300 difference between Rob Beck Turbochargers and VTT "Stage 2's", I know where my money would be going. Quote:
thanks Adrian. "DynaNewtons" is a relative measure of the tractive effort or force applied to the rollers on a "Dyno Dynamics" dyno. The figure is dependant upon gear selection and final drive ratio and perhaps tyre size too, ummm Adrian? Last edited by Justin@ADVAN Performance; 05-30-2013 at 02:21 AM.. |
05-30-2013, 12:24 AM | #36 |
39
Rep 672
Yep like anything to do with torque or force on a dyno, the numbers will vary alot with anything that effects gearing... so gear/diff ratio, tyre size etc.
The useful thing with tractive effort/torque on a dyno is not really the numbers as much as the shape of the graph. A nice flat graph starting as low as possible and staying flat as high as possible is the best result for general driving enjoyment. Some people like a really low hump which indicates a "torquey" engine which is lazy to drive around town, but ultimately in any form of motorsports, a flat torque curve is ideal. My preference is for flat torque. I can always change gear if I want more acceleration. |
05-30-2013, 12:27 AM | #37 | |
16
Rep 511
05-30-2013, 12:31 AM | #38 | |
39
Rep 672
I would not buy a turbo because someone with experience thinks it will work well. But if they do make it and test and find it works well, I would happily part with my cash. I am sure Vargas will do the testing and find out if it works well. Until then I would stick with proven options. |
05-30-2013, 12:54 AM | #40 | ||
128
Rep 3,099
yeah there's no solid info on the 'options' other than vargas stating the stage 2's aren't finished regardless of what the beta's come back with there are 100% more results in the next couple of weeks though. hmm $300 isn't so bad i'm still reserving my judgment for final figures as to which is the better though. if RB's make more power, spool better, and are potentally more reliable, yeah, they'll get my money obviously. but it's enough time away that there should be final info on how the vargas options perform. for example, dzenno pushed out 550whp on his with RB's... with headwork and a thicker gasket.. and he's pushed out something like 475 lazily on vargas stage 1 replacements... itd be cool to see him put on some stage 2's... though he'll probably skip straight to 3's.... Quote:
the beta testers for stage 2's got their's for a CRAZY price.. something like $1500 - so it's a no brainer for them haha |
05-30-2013, 07:31 PM | #41 | |
16
Rep 511
