crazy electrical mystery - need some advice
10-11-2011, 03:30 PM | #23 |
133
Rep 4,764
Weird. I know there is an auto disconnect if in an accident, but the wire melting near the front box is strange. Was is touching something hot, or was the current melting the wire from the inside out?
So many fuses on this car you would think it would pop a fuse somewhere before damage. |
10-11-2011, 03:33 PM | #24 | |
Team Zissou
3084
Rep 10,198
10-11-2011, 03:34 PM | #25 |
125
Rep 3,004
10-11-2011, 03:36 PM | #27 |
Some say...
239
Rep 4,296
Drives: Fresh
Just to clarify, the car still drove completely fine? Didn't die while driving down the road did it? This thread has me a little worried...
I have exhaust and an intake... |
10-11-2011, 03:37 PM | #28 |
Team Zissou
3084
Rep 10,198
10-11-2011, 03:41 PM | #29 |
Team Zissou
3084
Rep 10,198
10-11-2011, 03:42 PM | #30 |
Putting more gas in the car...
Rep 36
That's really strange. If the battery cable is burning thru the insulation then it has to be the result of a high current draw - most likely from a short or a misbehaving component. I don't know much about the electrical systems on the BMW but unless the cable is somehow bad, there has to be an actual reason for the increased power draw (coming from an EE background).
I don't blame you one bit in getting it replaced - just make sure they've thoroughly checked out the reasons of WHY it happened.
2008 BMW 535iA | Cobb Stg2+ | Injen Intake | AR Catted DP's | CP-E FMIC | Turbosmart DV's | ER Charge Pipe
10-11-2011, 03:49 PM | #31 |
133
Rep 4,764
They are not talking about replacing the entire main wiring harness are they? Isn't there a repair piece for just the section? Reason I ask is because of the price you mentioned, was that the part or part and labor? What was the part name?
I don't see anything near that price on realoem except the entire car main harness. |
10-11-2011, 03:57 PM | #32 |
Some say...
239
Rep 4,296
Drives: Fresh
OMG I hope I am not having this problem, you have PM coming your way for more details when I get to work.
10-11-2011, 04:08 PM | #33 | |
Team Zissou
3084
Rep 10,198
but the SA just called me back a couple minutes ago to say: "ok i misunderstood what the tech told me, the tech NEEDS to check behind the glove box because he THINKS that might be the issue"... so this isn't actually confirmed yet thanks for scaring the shit out of me! |
10-11-2011, 04:35 PM | #34 |
133
Rep 4,764
Thread below isn't 335, but an interesting read. Could it be somehow the IBS (Intelligent Battery Sensor) has issues? Also there are so many modules that could have gone bad. I hope the tech does a ton of testing before suggesting a fix and can explain whey they are fairly certain they have determined a root cause:
check out posts 21,22, and 24: http://www.e90post.com/forums/showthread.php?t=490168 |
10-11-2011, 04:47 PM | #36 |
133
Rep 4,764
This 325 had the key stuck issue and it was just a bad battery:
http://www.e90post.com/forums/showth...%22accident%22 This guy had crazy electrical problems and it turned out to be a bad positive battery cable (<$200): http://www.e90post.com/forums/showthread.php?t=334159 This poor guy had electrical issues, towed it, then 4 days latter a battery fire destroyed the entire car (pics in the thread): http://www.e90post.com/forums/showthread.php?t=577054 |
10-11-2011, 06:37 PM | #38 |
37
Rep 471
i had that blip a couple times.... but mine was caused by corrosion around the positive terminal....
i don't see how it can take 16 hours to replace the wire from the back to the front... when i ordered the cable i got that one you are talking about by accident and had to send it back... it was $300-400 and yea.. looked like a pain.. but 16 hours seems steep... can't splice it really, i wouldn't anyway.. that's sketchy.. and it's a FAT cable... so was the update in your first post the same "not confirmed" as the few hours ago note here ?? still up in the air ?? |
10-11-2011, 06:40 PM | #39 |
37
Rep 471
also, maybe just seriously cleaning the positive contact and terminal ?? seems stupid to suggest it, but checking connections being tight doesn't help if there is some corrosion in there... take it off, make it all shiny again and put it back on... (post and clamp)
i don't think, even if the wire was melting, that would be the cause.... seems that it's sketchy battery connection, but if the wire was hot/melting... (well i would certainly replace it if it was, but yea.. gotta find the real cause of the melt, and maybe it's sucking a lot of current or something, causing the rest of the car to not get enough)... |
10-11-2011, 06:43 PM | #40 |
369
Rep 8,693
Drives: 06 330i
pics
10-13-2011, 09:55 AM | #42 |
Team Zissou
3084
Rep 10,198
bump - update.
SA called, they do need to order that cable but labor will only be half what they thought. so ~$940 total instead of $2300.... that's sort of good news at least. there is some code being thrown about "map overheating". I'm only relaying info from the SA, so she might be mistaken. But she also said the DME might have an issue and need replacing - but it might be covered under some emissions warranty. |
10-13-2011, 11:07 AM | #43 |
Team Zissou
3084
Rep 10,198
this guy posted up a service bulletin that sounds exactly like my issue:
http://www.e90post.com/forums/showpo...69&postcount=6 |
10-13-2011, 11:23 AM | #44 | |
133
Rep 4,764
http://www.realoem.com/bmw/showparts...67&hg=61&fg=10 Part number from 3/2007 production is 61 12 9 269 907 Does not come up on Tischer. If I were you, I would IM Evan at Tischer and see what they would sell one for. Install looks easy. The old part number 61129232801 does come up on getbmwparts.com and it's $88.32, so the new part number should be close in price. If you find, that is what the dealer wants to do, I would do it myself for $90 (and a couple hours) vs. their $940 |
