      05-28-2011, 07:42 PM   #23
JB4-335
Australia
169
Drives: E92 BSM & E70 AW
Ok I'm ready to order my meth kit within the next few weeks.
The following is what I will be ordering:
VC2 Pro with 2.2 gallon integrated black tank with FCB without the flow sensor. The CM10 nozzle and the AR Elbow with one bung.
What are you guys considering?
      05-28-2011, 07:55 PM   #24
Orlin
Orlin's Avatar
Australia
44
Drives: F30 335i
as you probably already know, my order will be exactly the same. Thanks for all your help and advice regarding meth.
      05-29-2011, 06:59 PM   #25
adrian@vishnu
Australia
39
Drives: 135i
Originally Posted by BMW86 View Post
Adrian, what are your thoughts on the tank and tank being separated for the under hood version? The only prototype I've seen has the pump just above the charge pipe.
It you run empty and then fill up it may take a fraction longer to purge air in the feeder pipe, but I see no other issue. Most systems are using a flow sensor that detects actual meth flow, so should keep tune safe until meth flow is reached anyway.
      05-29-2011, 07:53 PM   #26
BMW86
Australia
398
Drives: RS3 Sedan / Macan S
I know this is dependant on many variables but how long will the under hood version last?
      05-29-2011, 08:09 PM   #27
BBK
89
Drives: A boring one...
2009 BMW 135i  [5.76]
Would I need the CM10 nozzle, or will the CM7 be fine if I have no BO mods?
      05-30-2011, 12:27 AM   #28
JB4-335
Australia
169
I just see more problems arising with the under hood meth setup as opposed to the usual trunk kits. I think the idea is excellent and would make for a nice quick setup.
      05-30-2011, 12:30 AM   #29
JB4-335
Australia
169
I think you could do either but maybe a CM7 may suite better. If you are going to get more mods down the track you can just order the CM10 nozzle later. Shoot Terry an email and see what he suggests.
      05-30-2011, 01:08 AM   #30
MrBlonde
MrBlonde's Avatar
Australia
122
Drives: Audi TTRS, M Coupe, 1299
CM7 is fine, actually you could go smaller still. The Americans tend to overfuel the methanol which does not bring better results.
.-=[ Kenny ]=-. 1999 BMW M Coupe 10.775 @ 134.35 mph w/1.600 60' (Best 136.07 mph) 25th August 2004. +2010 X5 35D+
Check out the 1Addicts Drag Racing Standings and Drag Racing 101.
      05-30-2011, 01:59 AM   #31
JB4-335
Australia
169
The American's overdo everything. The Biggest and Baddest around.
      05-30-2011, 10:22 AM   #32
xerox445
Damenslip-Tropfer
23
Drives: 2008 SGM 135i
And also makes it nearly impossible to get an accurate a/f reading, as the methanol has a much slower combustion event to begin with. Using meth to "dial in" your last bit of tune (as many tuners do) is far from optimal, and as Mr. Blonde stated, it just further propagates other issues.
      05-31-2011, 01:09 AM   #33
BBK
89
Terry suggested the CM10... He said he was going to take the CM7 option off the site!
      05-31-2011, 01:52 AM   #34
JB4-335
Australia
169
I had a feeling he would say the CM10.
      05-31-2011, 02:21 AM   #35
BMW86
Australia
398
Lol T always says CM10
      05-31-2011, 02:50 AM   #36
BBK
89
What would actually be the real world difference? Is it going to flow more? Or does it just have the potential to flow more for more power?
      05-31-2011, 02:54 AM   #37
MrBlonde
MrBlonde's Avatar
Australia
122
Perhaps based on what Americans buy?
      05-31-2011, 09:21 PM   #38
JB4-335
Australia
169
Here's the convenient option instead of purchasing methanol.
Go to bunnings and buy a 4 litre bottle of Methylated spirits for $12.06.
      05-31-2011, 09:30 PM   #39
JB4-335
Australia
169
The CM10 will flow more meth into your charge pipe. Most of the time resulting in more power but not always the case.
      05-31-2011, 10:05 PM   #40
adrian@vishnu
Australia
39
Drives: 135i
Just to be clear. Methylated spirits is not methanol. It has its own set of properties that are similar but different. It is primarily ethanol rather than methanol. I am not saying which is better, I am just saying that if you used methylated spirits you would be doing eth injection rather than meth injection.
My experience is that the usage of methanol is so low that you can buy a 20 Litre drum from VP or similar and it will last a long time (mixed 50:50 with water) for most users, and it is not worth the risk using substitutes that probably cost more, and are less consistent.
      05-31-2011, 10:12 PM   #41
JB4-335
Australia
169
What I mean Adrian is that methylated spirits is extremely easy to obtain, Kmart, Target, Bunnings, Woolies and Coles. I would purchase a drum of methanol from VP myself but will definitely have a few of these 4Litre methylated spirits sitting in my garage for when I don't have any methanol left.
      05-31-2011, 10:30 PM   #42
adrian@vishnu
Australia
39
Drives: 135i
You can do that, and it would be alot better than injecting nothing while keeping the tune the same as with meth, but it would provide different results and if you had fine tuned it to a consistent meth mix, you would be compromising that fine tuning, and who knows the results. Probably OK at 15psi... but I would not want to be pushing the limits and changing what I am injecting.
Don't get me wrong... I am very much a fan of ethanol. I have a WRX race car that I run on E85 (85% ethanol), and it loves the stuff. But I would not go swapping the ethanol for methanol and expect it to run the same... in fact I would expect to break something if I did that.
      05-31-2011, 10:41 PM   #43
BBK
89
What are the hazards in running out of meth, and say, just using 100% water (if any)?
      05-31-2011, 10:42 PM   #44
JB4-335
Australia
169
Nothing except really good IAT's.
1addicts
