**NEW** BMS JuiceBox now available in the UK - special forum offers on JB+ and JB3!!
08-27-2010, 04:31 AM | #23 |
42
Rep 822
BT tool is usful if your are running a tune, but no further mods. Running a tune can trigger a tuner code, which when detected by a dealer will invalidate your warranty (engine, drivetrain etc). This gives solid proof to your dealership that your car has been creating more torque than can be created by the stock ecu. The BT tool can read and clear these codes.
Additional to this, you have access to all ECU modules on your car. You can datalog, read and delete other codes, reset all adaptations, reset service indicators etc etc. This will be useless for many, but valuable to others - horses for courses and all that. |
08-27-2010, 06:53 AM | #24 | ||
14
Rep 454
Your more likely to CEL in higher temps as the boost targets cant be met. Thats not a problem anyone for an AMS FMIC? Last edited by neil@JuicedUpTuning; 08-27-2010 at 07:02 AM.. |
08-27-2010, 07:16 AM | #25 | |
14
Rep 454
The cheaper code readers dont have the same features list as the BT does hence the cost. Many of the other tools only show the code and not a description!!
The full features matrix can be found here... http://www.bavariantechnic.com/modelfeaturematrix.aspx Last edited by neil@JuicedUpTuning; 08-27-2010 at 07:43 AM.. |
08-30-2010, 01:53 PM | #27 |
1546
Rep 8,972
Big thanks to Neil.
My new JB3 PnP and usb lead arrived saturday morning as promised. Fitted in 30 mins today.. only had a quick blast up and down the mancunian-way this avo, plenty more fun to be had I reckon..... Mike. |
08-30-2010, 03:22 PM | #28 |
14
Rep 454
Glad to hear! Yes let the fun begin. Hook the cable to the laptop and follow this link todo some data logging. It will allow you to see boost, throttle position, IAT.
http://www.n54tech.com/forums/showthread.php?t=8035 The realtime data logging makes the jb3 awesome tuning product. Last edited by neil@JuicedUpTuning; 08-30-2010 at 03:54 PM.. |
09-22-2010, 01:53 PM | #30 |
Welly Wanger
17
Rep 67
I usually run map 4 with v-power or Tesco 99. When I'm in the mood map 6 works a treat - specially with some Torco Race Fuel Concentrate!
09-22-2010, 02:49 PM | #31 | |
1546
Rep 8,972
They really get rid of the inherent delay on boost pick up, no more power just better pick up. |
10-05-2010, 11:14 AM | #33 | |
Welly Wanger
17
Rep 67
If you change gear quick enough it's fine anyway. |
10-28-2010, 04:19 AM | #35 |
1546
Rep 8,972
I run map 5 and have no codes at all. It really shifts, from US reports I'd say at least +6070 bhp flyhweel and about 80lbft? (always use 98/99 ron)
It a proper missile with it, the effortless overtaking ability (what counts on the road) is phenomenal - in 2nd and 3rd you can pass 3 cars in a small gap where you'd have managed 1 before, and you're at the top of 3rd in a few seconds from 40 or so. You need to re-adjust your braking distances!! Map 3 is reckoned to be 100% code free, and that gives about +40/50 ish?? But as said I've got no probs at map 5. Last edited by doughboy; 10-28-2010 at 04:32 AM.. |
10-28-2010, 04:24 AM | #36 |
1546
Rep 8,972
AFAIK the 'Lagfix' function is for in-gear pickup from steady to on-throttle, rather than gear-shift boost control.
It just runs the wastegates more closed during cruise (steady rather than off throttle) this means the standard spool up delay when you apply throttle is much reduced. The 'bog-fix' function is to keep boost up during full throttle shifts by reducing throttle shut angle during shifts above 4500rpm. |
11-08-2010, 05:06 PM | #37 | |
LSD - No, you're not seeing things
72
Rep 3,302
But the downside is reduced economy. As every small press is building boost. It may make less agile drivers less smooth on the throttle too.
02-08-2011, 12:24 PM | #38 |
247
Rep 7,690
Drives: 335i SE Coupe Space Grey
Very good service from Neil!!!....all emails replied very quickly....and got some good offers!...
02-08-2011, 12:42 PM | #39 |
268
Rep 9,915
Drives: VW T5
Thought he was a forum sponsor?
02-08-2011, 12:43 PM | #40 |
247
Rep 7,690
hes not at the moment...
03-05-2011, 05:35 PM | #41 |
14
Rep 454
Hi Guys,
Back to sponsorship. We have been busy increasing the product line up. For the xenon people we have the new Arc Angel H8 bulbs to replace the oem yellowish lights. Will post Picts later http://www.juiceduptuning.co.uk/shop...duct.asp?ID=27 Added the CT Tool for those who want code reading and deleting with the high cost of the BT Cable http://www.juiceduptuning.co.uk/shop...duct.asp?ID=29 For the 335d owners we have the JBD which is like the JB+ and is adjustable for gains up to 60hp and 100tq http://www.juiceduptuning.co.uk/shop...duct.asp?ID=31 For the N55 owner the BMS Stage 1 tune offering unto 60 hp and 50 tq http://www.juiceduptuning.co.uk/shop...duct.asp?ID=30 The DCI has proved popular and recommend them. We have been asked to stock a high flow drop in filter to keep the oem look so we have http://www.juiceduptuning.co.uk/shop...duct.asp?ID=28 . Last edited by neil@JuicedUpTuning; 03-05-2011 at 05:46 PM.. Reason: Added drop in filter |
03-05-2011, 05:48 PM | #42 |
14
Rep 454
03-05-2011, 06:44 PM | #43 |
14
Rep 454
Forgot we now have the BMS Speed limiter defeat for those who track their cars and want to drive faster than the 155 limit. Unlimited cars have seen the 160-175mph.
http://www.juiceduptuning.co.uk/shop...duct.asp?ID=32 |
03-08-2011, 04:45 PM | #44 |
14
Rep 454
BWM 335d tuning JBD
Hi Guys,
quick post about the new JBD we are now stocking for "Next Day Delivery"... http://www.juiceduptuning.co.uk/shop...duct.asp?ID=31 The BMS JBD (Juice Box Diesel) quick install tune is now available for 2009+ 335D and X5D The tune can be adjusted for gains of upto 60 horsepower and upto 100 torque by simply adding the JBD Instantaneous increase in Power and Torque for your BMW Diesel! Installs in Seconds. Safe Plug & Play Application. Revert back to stock by simply removing the tune. COMES WITH THE BMS 14 DAY MONEY BACK GUARANTEE. TRY IT AND SEND IT BACK FOR A FULL REFUND IF YOU DONT LIKE IT Install guide is here... http://www.burgertuning.com/instruct...tall_Guide.pdf Hotrod182 showing using his JBD equipped 335D 13.1 at 106.1 mph 0-60 in 4.7 seconds 2nd gear launch. All stock except for JBD (Burgermotorsports) module. If your worried about codes etc then check out the Combo deals with the CT Tool for code reading and deleting Last edited by neil@JuicedUpTuning; 04-02-2011 at 01:33 PM.. |
