01-07-2023, 03:49 PM | #23 |
2029
Rep 5,092
01-13-2023, 01:29 PM | #24 |
19
Rep 42
Just ordered a set of secondary here. Really hoping BMW don't flag me for any potential warranty claims in the future because of it. Has that happened to anyone with just secondary cats and a Racechip GTS?
01-13-2023, 01:33 PM | #25 |
2029
Rep 5,092
Tune is a possibility secondarys won't throw any type of code.
01-17-2023, 09:08 PM | #26 |
2029
Rep 5,092
Bump
01-30-2023, 11:54 PM | #27 |
2029
Rep 5,092
Bump
02-10-2023, 02:45 PM | #29 |
2029
Rep 5,092
Hi we do not provide any install instructions on downpipes but a customer did make one for his f90 which is the same motor to give you an idea.
02-15-2023, 10:19 PM | #31 |
2029
Rep 5,092
02-15-2023, 10:22 PM | #33 |
2029
Rep 5,092
They sure are! Our website is up to date so if it doesn't say pre-order they are ready to ship same or next day.
02-20-2023, 01:07 PM | #34 |
2029
Rep 5,092
Bump
02-26-2023, 09:19 AM | #35 |
248
Rep 327
I installed a set and they fit just fine.No upper seal was needed at the V Band clamp. Weld quality was pretty good and it's stainless mandrel bent piping. I can't see spending more than double or even triple for a brand name pipe.
The clamp bolts are actually E12 Torx, but a 10MM 12-point flex head ratchet worked just fine. These are accessed from the top quite easily. There is one mount per pipe. These are also easily accessed. Rather than take the main exhaust system down, I just pulled it back with a tiedown strap. I have a lift, which obviously made it a lot easier, and it only took a couple of hours to swap them. I also found an X Pipe upstairs at my shop that I'll be adding next.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM |
02-27-2023, 11:25 AM | #36 | |
2029
Rep 5,092
Thank you for the review! Would you mind leaving it on our site as well if you have time for others to see. https://mad-us.com/mad-bmw-x5m-f95-x...ownpipes-2019/
03-01-2023, 09:49 AM | #37 | |
65
Rep 97
Drives: 2021 X5M Competition
03-01-2023, 08:30 PM | #38 |
2029
Rep 5,092
no code needed for the month of march
03-06-2023, 01:20 PM | #39 |
2029
Rep 5,092
10% off all March!
03-08-2023, 08:36 AM | #40 |
65
Rep 97
Look forward getting these installed in.
03-08-2023, 02:40 PM | #41 |
2029
Rep 5,092
03-18-2023, 09:09 PM | #42 |
2029
Rep 5,092
Bump
03-29-2023, 07:38 PM | #43 |
2029
Rep 5,092
Last chance to save 10%
04-04-2023, 02:47 PM | #44 |
19
Rep 42
Cheap isn't always better. I bought these, my installer told me they got one side in decently. Other side they had to fight with and modify the mounting bracket to get it to fit. Seller says just cut the mounting bracket off. Took a good 5 additional hours to modify and test and fit them up correctly. Factor that into the cost of these.
