BMW X5 and X6 Forum 2014-Current
      01-12-2021, 08:44 AM   #23
NikNala
NikNala's Avatar
75
Drives: 2016 BMW X5M
I loaded the stage 2 tune. A little snappier over stock. Not earth shattering but a nice improvement. The fact that I can tune the Launch Control is an awesome feature. Seems like it would be a great thing to have if you 1/4 your car. So far I think it's a nice upgrade for the money.
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts
      01-12-2021, 09:46 AM   #24
notyourdadsf86
notyourdadsf86's Avatar
165
Drives: 2016 X6M
2016 BMW X6M  [0.00]
What kind of changes to launch control can you do?
excu6me on Instagram.
OEM X6M Build
      01-12-2021, 11:02 AM   #25
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1624
Drives: ///Ⓜ️
I meant to make a post about this but I've been extremely busy... just to make things simple... DO IT you won't regret it especially for you 1/4 mile junkies like myself..😎
IM POOR..
      01-12-2021, 11:43 AM   #26
NikNala
NikNala's Avatar
75
Here's a screenshot. I haven't played around with it yet but here's what I set initially using the stage 2 map. Haven't used it so I can't comment yet.
      01-12-2021, 02:13 PM   #27
KLR X5M
223
Drives: F85 X5M
How does it launch on stage 2 with those settings?
      01-12-2021, 04:08 PM   #28
J0hnnyB0yx5m
J0hnnyB0yx5m's Avatar
176
Drives: X5M
Welp start saving up for the stuff that's bout to break or start beefing shit up before it breaks lol im all for more tho.. good luck and keep us updated
      01-12-2021, 09:02 PM   #29
notyourdadsf86
165
Drives: 2016 X6M
2016 BMW X6M  [0.00]
When RK builds there motors they don't touch transmission or differential.
So if the ECU tune keeps the torque at "reliable" numbers, shouldn't changing where it's delivered not put the car at any added risk?
OEM X6M Build
      01-12-2021, 11:07 PM   #30
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1624
Drives: ///Ⓜ️
Not 100% true but I don't know if I'll be saying too much by fully confirming anything so I'll just wait for one of the "fully built" guys to come in and finish lol
IM POOR..
      01-13-2021, 02:09 AM   #31
BadCompany
BadCompany's Avatar
85
Drives: e-tron GT, C63 507, ISF, Elise
Yep. If you follow tunedbyutku on Instagram, you'd see that they are tuning the TCU too. Since it is a public post, I'm going to assume it is ok to say outright. 😜
F85MTuNED1623.50
      01-15-2021, 01:38 PM   #32
KLR X5M
223
Drives: F85 X5M
So quick check in, flashed stage 3 a few days ago. Got some miles on it to relearn adaptations. Highly recommend it. Big bump in low end power delivery, Comfortable smooth shifts driving mildly in D1, fast hard shifts in D2,S2 , ripping fast shifts in D3/S3. Do it.
Appreciate 2
      01-15-2021, 02:44 PM   #33
KCTiger
523
Drives: 2016 X5M
KLR X5M What drive mode(s) did you drive in prior to the tune? I am typically in D2. D3 holds gears a little long for my preference, at least in daily driving.
So....is D1 your preferred mode for normal driving and then D2 or D3 when you looking for more spirited driving?
I will get the tune as well, just not sure about stage 2 or 3.
      01-15-2021, 02:47 PM   #34
notyourdadsf86
165
Drives: 2016 X6M
2016 BMW X6M  [0.00]
Did you adjust anything in the map or are these your impressions just from default values?
OEM X6M Build
      01-16-2021, 12:57 AM   #35
KLR X5M
223
Drives: F85 X5M
Nothing custom yet. Just stage 3 ots.
      01-16-2021, 12:59 AM   #36
KLR X5M
223
Drives: F85 X5M
My m1 button is setup for d2. It's what i usually drive in. D3 holds great pretty aggressively abutting more than 50% throttle. But much for daily.
      01-16-2021, 06:37 AM   #37
gman_newyork
gman_newyork's Avatar
240
Drives: 2015 M3
2020 BMW X3MC   [0.00]
2018 BMW X5M  [0.00]
2015 BMW M3 Non ZCP  [0.00]
I'm stage 3+ fully built and while RK didn't do my TCU flash it was done by their tuner using Femto. If you're pushing 800awhp+ the torque values in the the TCU need to be adjusted or the transmission attempts to preserve itself due to the increased torque and you get 10+psi boost drops between 2-3rd gear shifts at WOT.
Femto is a software tool to flash your transmission if you're beyond a stage 2 as the tuner controls the parameters not a generic OTS TCU map. You can learn more about it here. https://fscmap.com/femto/
I cannot comment on XPH as I've never used it so please don't interpret this as a negative towards their products. Their products are designed to cover 99.9% of the tuned vehicles out there. It's when you start pushing significantly more power and torque than stock the transmission will need a custom flash to compliment your DME tune.
F85MTuNED1623.50
      01-16-2021, 08:32 AM   #38
NikNala
NikNala's Avatar
75
Has anyone tried launch control mode with stage 2 or 3? Does the car still shift for you during this mode even though you're in manual mode like the factory tune does? I haven't tried it yet but I'm going to later today.
      01-16-2021, 09:42 AM   #39
F85MTuNED
IG: @88jae88
F85MTuNED's Avatar
1624
Drives: ///Ⓜ️
This..
IM POOR..
      01-20-2021, 09:21 PM   #40
MikeM6
150
Drives: M6GC, X5M, M3, X7, X5
What connection method are you guys using to flash? I'm not able to connect successfully using an ENET cable. Thanks.
      01-20-2021, 09:55 PM   #41
NikNala
NikNala's Avatar
75
I'm using the ENET cable and a Ethernet to lightning adapter into my IPhone just like I use for Bootmod3. No issues here.
MikeM6149.50
      01-21-2021, 06:57 AM   #42
pachieh
248
Drives: '17 X5M
No idea they made those! Which one do you have?
2017 X5M, Donnington Grey, Aragon Brown
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3
21" Vossen VFS-1 on Michelin PSS
      01-21-2021, 07:41 AM   #43
NikNala
NikNala's Avatar
75
I use this one in particular but I'm pretty sure just about any one would work.
Amatage RJ45 Ethernet LAN Network Adapter for Phone/Pad, Phone Ethernet Adapter, 3.3ft/1m Cable, 10/100Mbps High Speed, System Required iOS 10.0 or Up https://smile.amazon.com/dp/B07NW9HS...UTF8&psc=1
      01-21-2021, 03:53 PM   #44
MikeM6
150
Thanks NikNala. Support told me to try putting the phone into airplane mode. I'm going to give that a try. Previously I had turned off Wi-Fi and BT.
xbimmers
