05-24-2021, 10:05 AM | #23 |
I like Coffee & Z4s.
107
Rep 366
Drives: 2007 Z4MC
Update: Downsizing from 245/40/18 to 245/35/18 solved the issues. Michelin Pilot Sport A/S 3+.
The steering now feels lighter. With the 245/40s it felt really heavy, to the point where it wasn't enjoyable to drive at low speed. Now it's more reasonable, though it still feels heavy and I'd like it to be even lighter. Additionally turn-in feels more responsive. I wonder if these effects are due to the smaller sidewall having less flex, or a change in scrub radius due to the smaller diameter wheel. /shrug. I'm enjoying the car so much more now. I'm on 18x9 ET30 wheels, struts mounts are pushed all the way in for max negative camber. My main lesson from this is that seemingly minor wheel/tire changes can make a big difference, and you don't really know until you try it (unless you're an automotive engineer). I guess this applies to all mods really. |
cbryant5143.00 |
05-24-2021, 02:29 PM | #24 |
1167
Rep 2,882
Drives: Anything
I would not call the steering in the Z4MC heavy. It's not even close to, in terms of "heaviness" when compared to my e53 X5. With that said, I didn't feel that it had made any difference (that I had noticed) when I switched from my stock 225/45/18 to the current 245/35/19 continental extreme DW. Did you change out for an underdrive power steering pump pulley by any chance?
05-24-2021, 02:32 PM | #25 |
107
Rep 366
Drives: 2007 Z4MC
Those two tire sizes are comparable in diameter. (within 0.2") so boosts credibility to the theory that wheel diameter changes can change steering effort.
No steering system mods. My wheels are ET30 though compared to stock ET42. |
05-25-2021, 07:39 AM | #26 |
38
Rep 69
Do you think a 255/35/18 would have solved the problem? Its wider, but also shorter than the 245/40
I ask because I have the same unmounted wheels, and its about time for tires |
05-25-2021, 01:11 PM | #27 |
107
Rep 366
Drives: 2007 Z4MC
tecnicaeleven I cannot guarantee.
10-15-2021, 07:22 PM | #28 |
Rep 7
So, I'm looking for a consensus. With a properly offset 18x9 with a 255/35 in the front of a Z4M, do we experience rub during high-speed driving? Or only during parking lot (full-lock) maneuvering?
04-24-2022, 10:06 PM | #29 |
107
Rep 366
Drives: 2007 Z4MC
Back on stock suspension
245/35/18 rubs just a smidgeon on the hardest hairpin turns in autocross on the rivets. 9inch ET30. No rubbing in regular driving or parking lot maneuvers. |
wdb4762.50 |
06-20-2022, 07:27 AM | #30 |
2305
Rep 12,570
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
What was final camber settings after going back to stock suspension?
01-26-2023, 09:28 AM | #31 | |
12
Rep 14
I currently have 225/45/17 tires on 17x7 rims 40mm offset with 20mm spacers. I just ordered 15mm spacers in the hopes this will cure it. |
