Need Advice - looking to buy a 335
08-02-2018, 09:35 AM | #23 | |
Rep 68
08-02-2018, 09:39 AM | #24 | |
Rep 68
Yes those cars were heavier but we have stability control and around 50/50 weight distribution with the 335 so i dont think ill have to worry as much |
TheMidnightNarwhal2683.00 |
08-02-2018, 09:45 AM | #25 |
2683
Rep 6,319
08-02-2018, 12:17 PM | #26 |
719
Rep 1,753
If turbo is your biggest worry than you really dont know these cars..
08-02-2018, 12:31 PM | #27 |
2683
Rep 6,319
08-02-2018, 12:59 PM | #28 | |
719
Rep 1,753
Those parts are part of maintenance, they WILL fail. The most expensive part that can fail is your dual clutch transmission. Or your engine. If you have the is version that is but any automatic can fail.. Turbos are a joke when ur transmission fails. Also turbos dont really fail that often. Looks like you have a 6 speed manual so ur safer with the transmission. But id worry more about some rod bearing fail than a turbo. |
08-02-2018, 01:02 PM | #29 | |
2683
Rep 6,319
08-02-2018, 10:42 PM | #30 |
712
Rep 971
Drives: 2018 M2
Each and every combination has its pros and cons. Get the newest car with the lowest miles and most up to date service history in the color combination you want. That's the best advice I can give you.
Nick5410.00 |
08-03-2018, 09:43 AM | #31 |
Rep 68
08-03-2018, 12:06 PM | #32 |
1909
Rep 6,968
The N54 will be easier to make 400hp than an N55.
The n55 is probably a little more reliable than an n54. i vs XI? I live in Michigan, and I have an n54 with snow tires. I don't really have a problem getting around. If the roads are bad, you aren't going anywhere, anyhow. If you get a rwd car, run snow tires on it and are not satisfied, you can always add an LSD differential to it. An LSD is better in snow. |
Nick5410.00 |
08-04-2018, 05:17 PM | #33 |
19
Rep 71
Unless u also like launching do not get the xi. Seeing as ur MT as well im assuming you wont be. In that case get the RWD, ull thank ur wallet later down in the road too cuz XI's are a pain to work on. I have a RWD in toronto i actually look forward to winter cuz its so fun on the turns. XI would not be "that kind of fun".
