Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      04-14-2018, 09:50 PM   #23
aBMWfan
1194
Drives: 08' M3/'15 M4/ '06 M3/ '09 M3/
Originally Posted by delfunk View Post
Bem4 please make sure you have them put it on the repair order so there is a record. BMW needs to know of these issues.
Will do
      04-15-2018, 09:35 AM   #24
delfunk
32
Drives: 2016 M4 GTS
I just learned about Valvetronic. I guess I am behind on the times. BMW claims the intake valves close in .3 of a second. There is a throttle body as a fail safe. So why is the car still accelerating for 2-3 seconds? Thanks for filling me in gingerbread
This is a serious concern and it appears that this might be happening on more than a few cars. Of course no codes get stored when this happens. I'm sure this is what they will tell Bem4 as well.
      04-16-2018, 12:43 AM   #25
BMW9
53
Drives: BMW M4 / Nissan GTR
Has anyone experienced the car still accelerating once you let your foot off the gas for a couple of seconds under full acceleration? Another GTS owner has verified this with me as well. There are no fault codes and of course and they cant duplicate it. It's always when driving hard from 1-2 gear.
I'm thinking the water injection system is still shooting water and is malfunctioning or a faulty throttle body.
The BMW engineer thinks it's the turbos still spooling and air is getting into the intake. I told him impossible there is a throttle body and a blow off valve. He didn't like hearing that. Maybe the throttle body has an issue?
This has happened to me several times in two different cars, but not in any BMWs that I have had. It always happens right after lifting off from an aggressive throttle application and it's right before taking a turn. Throttle does not stay open fully but there is enough acceleration to scare the crap out of you even though you are not on the gas. I don't think water injection has anything to do with it (it happened in my C63 and my Gallardo). Despite reporting it to the dealers, No one could explain or remedy the problem for me. The floor mats were of course ruled out as the cause of the problem but that also has happened to me during full throttle acceleration. Thank god it happened in my 280 ZX which only had 180 hp.
      04-16-2018, 08:50 AM   #26
Day Laborer
Day Laborer's Avatar
1751
Drives: M5 CS / iX 50i
  [0.00]
Maybe take some WD-40 and clean under your accelerator pedal?
Could be some dirt or gunk that might be making the pedal sticky?
Just a thought
      04-16-2018, 10:48 AM   #27
delfunk
32
Drives: 2016 M4 GTS
This has only happened to me while driving straight thankfully. I will examine the throttle pedal but I believe the dealer has already done that.
I will take it in again and have BMW look into the valvetronic issues.
      04-16-2018, 06:42 PM   #28
aBMWfan
1194
In my case, it happened after giving it some gas around a turn, and the car was straightened after the turn,
My dealer appt. got pushed to Wed. I’ll be sure to ask about it
      04-24-2018, 10:56 AM   #29
delfunk
32
Drives: 2016 M4 GTS
After taking the car in four times for this BMW finally agreed to reprogram my computer. Here is what the service rep said:
"Your concern was that the Valvetronic did not function properly. We did not find any relevant faults stored. We contacted BMW, as per their request we performed programming and complete encoding. Initialized windows. Perform valvetronic test plans and ran without faults. Vehicle is operating to specs."
Bem4 maybe they can do this for you? Might help.
BMW953.00
      04-26-2018, 07:43 AM   #30
AlpineWhite_F80
AlpineWhite_F80's Avatar
82
Drives: 21 G80 M3C, 21 X6 M50
It has happened to me around 2 times in the past 1 1/2 years, and only after hard acceleration then letting go, the car just kept going for a couple seconds. I drive a F80 ZCP
      04-26-2018, 07:44 AM   #31
CanAutM3
CanAutM3's Avatar
21132
Drives: 2021 911 turbo
I just learned about Valvetronic. I guess I am behind on the times... ...Thanks for filling me in gingerbread
I had already told you so in post #6
your own thread that is
According to the video, that was back in 2001. In those days, BMW ///M assessed that this type of response was not sharp enough for the sporty characteristics of an "S" ///M engine, hence why the S54, S85 and S65 still had individual port throttle bodies. However, with the S63 and S55, the Valvetronic technology had evolved sufficiently for ///M to use it in their engines. I have to assume that modern Valvetronic has a much faster response than the 0.3 seconds referred to in the video.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      04-26-2018, 08:57 AM   #32
CanAutM3
CanAutM3's Avatar
21132
Originally Posted by gingerbread View Post
Is this with DSC on ? Does it feel like continued acceleration or no engine braking ? Ive read somewhere in the training documents that is the DSC can adjust the level of engine braking based of many factors. It does this to not unsettle the rear end of the car with excessive engine braking. Some factors are rain, outside temps, cold tires and so on. Maybe some more info on what is happening environmentally, road conditions, are you turning, etc.
Are you sure what you have read relates to the DSC holding engine power? Because IMO that could be very dangerous where the engine continues to provide power even when the driver lifts off. I seriously doubt they would design DSC that way.
Maybe you are confusing from your readings the DSC interaction with the DCT and e-Diff, where the DSC can command the DCT to open both clutches and/or the e-diff to lock/unlock on decel when slip is detected.
      06-06-2018, 03:54 AM   #33
Raul1428
India
Drives: 2015 M3 DCT
Any updates on this? Im having the same issue on my 2015 m3. When i go from 100% throttle in 2nd and shift to 3rd and let go of the gas pedal, it continues to accelerate at around 3k-4k rpm, I have to mash the brake for it to stop accelerating. My car is completely stock and it happens in Sport+ with MDM. Also have noticed it happen when im in traffic and trying to do short pulls.
I managed to record the incident on my go pro with M lap timer
      06-08-2018, 12:37 PM   #34
aBMWfan
1194
My dealer didn’t say anything when I brought it up.
You seem to have documented your issue well. Let us know how it goes when you mention this.
      06-10-2018, 04:49 AM   #35
BMW9
53
could be a problem with the throttle Controll module.
      08-28-2018, 12:33 AM   #36
delfunk
32
Drives: 2016 M4 GTS
That's great you recorded it. What did the dealer say?
They can't duplicate it and they tell me there are no relevant fault codes although the ZGM module failed to sync several times.
      10-08-2018, 02:06 PM   #37
delfunk
32
Drives: 2016 M4 GTS
Originally Posted by Darth One View Post
Haven't had that issue but I do have to say that the throttle is the worst thing about this car. BMW really fucked it up.
That said, it's kind of the same thing as the mole on Cindy Crawford's face
I wrote the NHTSA and they told me I am the only one to complain about this and more need to step up. Whoever is on the please go to the wendiste and file a complaint. It takes five minutes. They need your vin and a few other pieces of information.
Nhtsa.gov
      02-20-2019, 10:13 PM   #38
delfunk
32
Drives: 2016 M4 GTS
I had fault codes pop up that stated the accelerator angle was incorrect and BMW said it was normal!
      09-26-2020, 12:07 AM   #39
Schultz28
255
Drives: 2015 F80 M3
Just had the same exact thing happen to me for the first time. Full throttle in 2nd then shift into third for a short pull....
Let off the throttle and expected to decelerate but the car kept increasing in speed for about 1-2 seconds before I got on the brakes in reaction to the increasing speed which seems to have canceled the acceleration.
Luckily there were no cars around. But that’s a terrifying issue to have. Really hope to not experience it again.
Has anybody been able to find the actual cause of this?
      09-26-2020, 07:48 AM   #40
erictrainer
277
Drives: 16 F80 6MT MG on SO
Since no one ever said anything I thought that mole only bothered me
Sorry didn't mean to go off topic
      09-26-2020, 08:14 AM   #41
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
What throttle setting?
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
      09-26-2020, 10:49 AM   #42
Schultz28
255
Drives: 2015 F80 M3
Sport plus.
      09-26-2020, 11:47 AM   #43
FormulaMMM
FormulaMMM's Avatar
3663
Drives: E90 M3
Sport plus.
Reluctant to question someone's lived experiences, but have to wonder if F8X sport plus throttle setting and this issue are coincidence.
There is no deadzone at the top of the throttle in this setting, it is effectively on/off.
I would find an empty road, do the 2nd to 3rd gear pull you detail 10x. Make sure with each one you're fully off the throttle -- as in, snap your foot off the gas like it's on fire.
if you aren't able to replicate the issue, then you might consider "user error" being a potential cause of the prior experience. Again, where user error would be as small as continued slight pressure on the gas when you thought you were fully off.
      09-26-2020, 11:57 AM   #44
White340
1397
Drives: 2018 M3 Comp / 2022 X5 45e
Can you post a video of this?
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO
2016 340i xDrive : AW/CR (sold)
f80post
