06-12-2019, 12:06 AM | #24 |
Rep 26
This. I had the same issue turns out the ground was kinda crusty looking. Still under warranty so they replaced the right tail light. I guess that one looked the worst. They only replaced the board tho and re-used the other parts.
Kinda disappointed I was hoping I would get a whole new set of tail lights. |
06-12-2019, 11:52 PM | #25 |
124
Rep 277
Drives: 2018 230i MSport
Got word they replaced both tail lights on mine. I'll know for sure if it's new assemblies entirely when they drop the car off tomorrow morning. Interesting though they are doing bare minimal replacements on some and completely replacing both sides for others
09-12-2019, 09:25 AM | #26 | |
Rep 16
09-12-2019, 10:49 AM | #27 | ||
124
Rep 277
09-13-2019, 03:03 PM | #28 |
135
Rep 242
I know this is an old thread but it just happened to me.
First the turn signal says its no good, then it's fine, then its no good again. Then the brake lamp, and finally the reverse lamp. Basically every lamp in the housing. No water, no cracks, and it's just the fried harness. Fixed under warranty, and I made sure they replaced the wiring. Seth |
10-04-2019, 08:05 AM | #29 |
Rep 5
Same thing
Just bought a used 2016 M235i Vert. Having the same issue. Started off very randomly, now becoming more and more frequent.
Anyone have the part numbers for these lights? I don't think I'm under warranty. I just bought the car and had it shipped to me. Thank you, |
10-12-2019, 01:45 PM | #30 | |
Rep 76
10-14-2019, 01:09 PM | #31 |
3862
Rep 2,882
There is a known fault, I'm told up until late '16 or early '17 - inadequate ground wire that eventually burns out/melts. Multiple solutions - initially they soldered in a second ground wire harness to your original housing, then they started replacing the units with the newer, better units. If you have this done, take a good look to be sure they don't botch the install - they did on mine, pulled the weather-stripping gasket back so the upper/inner corner was obviously loose and left a 3mm hole for water to get in. They also seem to 'forget' to offer both at once, so I've made 3 trips now to finally get it all updated. The water-entry is a separate known fault/issue, but probably throw's similar codes once things start shorting out.
There is a post here about the factory 'fix' (adding the wiring harness), but try to pressure the dealership to give you two new housings, especially if you are under warranty. If you have to DIY, it is a fairly simple thing, you won't really need a new housing or harness. Info is here: https://www.newtis.info/tisv2/a/en/f...ess/1VnZ8zZX2B |
jondagger90.00 |
05-30-2020, 11:41 AM | #32 |
Rep 1
Tail light malfunction.
New to the forum. Any ideas guys? My 2 series RH side rear light cluster has gone on the blink today. Removed it and it looks like one of the 8 sections of the lighting plug has melted and the matching pin on the cluster itself is blackened. I had problems with moisture when it was new, so the dealer has looked at the lights before. LH side was replaced and still looks as good as new. It looks to be like the dealer have retro fitted some sort of extra cable on both sides, as it has a date tag of 2017. But the RH has still malfunctioned. Anyone know if it is definitely covered under an extended warranty? Mine is 11 months out of UK standard 3yrs. Thanks.
05-31-2020, 10:06 AM | #33 |
449
Rep 1,274
Who's ideas was it to put the fuse panel in trunk? The trunk can leak and fubar a bunch of electronix. I rented a small MB in Germany years ago. The fuse panel was in the passenger side floor!!! Gott im Himmel!
09-13-2020, 06:21 PM | #34 |
Rep 123
Does anyone know if this is covered under CPO?
I am getting the taillight errors. Today the brake light didn't work but the turn signal did. Yesterday was the opposite. I jiggled around the wires and I would get different effects of light bulb failures. Finally jiggled them in a way that all the bulbs came on, but don't see that lasting. |
10-18-2020, 02:16 PM | #35 |
Rep 6
10-29-2020, 02:00 PM | #36 |
373
Rep 702
Drives: 2016 M235i Convertible
So this obviously appears to be a common fault. I'm at 53K miles and I just had the Right Turn Signal Error appear. Guessing it's the same as everyone else - ground wire issue. Guess I'll need to get it to the dealer and see what they say. Hopefully since I'm still under 48 months by over on mileage, I'll get some type of dealer assistance on this "known issue". We'll let you know what happens.
16 BMW M235i Alpine White Convertible / MT (Daily Driver)
16 Audi Q5 3.0T (Wife's Daily Driver) 66 Porsche 912 (Project) 17 GMC Canyon Denali Long Bed 4x4 (Tailgatin, Haulin & Towin) various 'one design' sailboats / stinky hockey gear |
05-12-2021, 11:57 PM | #39 |
Rep 21
Happened to me as well. The dealership is only charging me $625 to replace some bulb sockets and a ground wire. I come from a electronics/computer background. $30 parts cost tops.
10-15-2021, 09:23 PM | #40 |
Rep 3
Hello,
I have a 2016 228iX with this problem and after checking with the dealership I am out of warranty. I have a friend who’s father is a retired mechanic and he said he could probably replace the light for me. However I know nothing about fixing cars and I want to make the repair as easy as possible for him. Do any of you know what parts I would need to purchase to do this repair. I have read other post about this and I thank you all for the information provided. It seems like I need to order a new light unit and a new wiring harness? Is there anything else besides those 2 items that would be needed? Do you know where I could find the part numbers to be sure I bought the correct items? Thank you for any help you can give me. Mary |
10-13-2023, 02:09 PM | #41 |
Rep 1
Sorry to bump and old thread but I just found this and it is exactly my problem. My sons 2016 M235i is showing this malfunction and I see the same burned ground pin. From the description of the TSB, it seems there is a wire harness with a new ground wire to correct this? Can anyone confirm? I'm sure the car is out of warranty and our local BMW dealer isn't very friendly and most likely not provide me any info on how to fix this myself but they'll gladly charge an arm and a leg to do it. I still haven't forgiven them for quoting $1200 for a replacement key .
