Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > Spacers on OEM E92 only
      03-02-2015, 11:56 AM   #23
gotcha43
130i Performonster
gotcha43's Avatar
Germany
152
Drives: 2009 E82 130i Performance
2009 BMW 125i  [0.00]
That Is Stock.
Look at My First pictures on Top. There you Can See it a Little Bit.
      03-02-2015, 11:58 AM   #24
EzequielR
EzequielR's Avatar
Dominican Republic
257
Drives: E92 08 328xi
Originally Posted by gotcha43
Originally Posted by EzequielR
I am currently on a stock suspension running the exact same wheel/tire specs except my wheels are style 225M's the older 335is wheels. I put 15mm upfront and 20mm on back and rub is absolutely ZERO. I could probably run 25mm on the back but thats pushing it, especially when i get my drop on KW V1's in the next month or so, when I do, I will report back if I begin to rub, till then I say 15mm up front and 20mm on the back. Good luck.
Worthless without pictures.
E92 preLCI Has exactly The Same Space as LCI.
My apologies man, I am no profession photographer but I will try my best as soon as the snow clears... It's been pretty rough here in NYC.
Originally Posted by okusa View Post
The lack of love won't come from the fact that it's not on a race track but rather that it is on the ground and, in fact, ruined.
my 2 feets are currently on the ground, are they ruined? haha
      03-02-2015, 12:29 PM   #25
Yellow_Belly
Yellow_Belly's Avatar
26
Drives: 330D LCI
Originally Posted by gotcha43 View Post
That Is Stock.
I see i see, I didnt realise, all good
also another useful thread:
http://www.e90post.com/forums/showth...413211&page=71 but then again, camber, tyres etc are uncertain for these LCI's
Guess its trial and error, I've the ordered spacers anyway, lets see how this goes. any further input and suggestions welcome
      03-02-2015, 01:21 PM   #26
gotcha43
130i Performonster
gotcha43's Avatar
Germany
152
Allright. Give us some visual input.
Try and error is the best way at spacers.
      03-01-2016, 08:25 AM   #27
JunkyardDogg
90
Drives: 2011 BMW 335is E92
Same dilemma. Bump.
I got 225m on eibach prokits. I wanna go as wide as possible. Is measuring an accurate way?
      03-01-2016, 08:32 AM   #28
Teufel_Hunden
8355
Drives: 2013 M3 6MT LMB ZCP
I'm running 19x8.5 front with 235 tires and 12mm spacers, and 19x9.5 rear with 265 tires and 15mm spacers. LCI e92 msport with stock suspension and I only rub in the rear (slightly) if I go over a huge bump while traveling fast.
      03-01-2016, 06:50 PM   #29
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
I have the same car and wheels.
I have 12mm front and 18 mm rear, wish I went larger.
The only run I get is if I go over a speed bump too quickly, or hit a pothole at speed.
      03-01-2016, 06:56 PM   #30
DaleT
23
Drives: E92 AW LCI 335i
Originally Posted by Yellow_Belly View Post
are standard rear arches rolled already? just checked mine they're creased rather than a flat edge all the way round? what I mean is this, is it factory rolled already?
They do not. I got mine used and the previous owner had rolled them already for me
      03-02-2016, 02:15 PM   #31
Olagüe
Olagüe's Avatar
Spain
106
Drives: 333i e92
I recommend 12mm front and rear..
http://www.e90post.com/forums/showthread.php?t=1033433
      04-02-2016, 10:48 AM   #32
JunkyardDogg
90
Are you lowered? It rubs in the back or front?
      04-02-2016, 02:45 PM   #33
deathmetaldrums
34
Drives: 2008 e90
I know this doesn't really address or help with the spacer question/issue, though from a guy who's had a lot of different spacer setup I'd say your time and money would be better put towards buying wheels with the correct offsets for your application.
By the time you start hitting a 20mm spacer ideally you'd want to start looking at adapter style like H&R DRA spacers rather than bolt-through style (in my opinion), and if you're in for two pairs of those it's starting to become a significant chunk of a set of new wheels.
If the cost of new wheels isn't viable financially then figure out what offsets you want in the long run and keep an eye on the classifieds, tons of great deals on people's used wheels.
Hope that helps in some way...good luck.
      04-04-2016, 08:28 AM   #34
EB89
EB89's Avatar
Australia
541
Not lowered at all, stock m sport suspension.
Rubs in the rear when the road suddenly dips, rear fenders are rolled as mush as possible
Rubs in the front when turning the wheels and reversing
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP /
      04-04-2016, 10:08 AM   #35
JunkyardDogg
90
And you still want to go wider?
I think i've made my decision. I'm gonna go with 12 mm front and back.
      04-04-2016, 07:24 PM   #36
EB89
EB89's Avatar
Australia
541
No not anymore I dont, I want to cut the rear fenders on the inside to make some more space, when i inspect the rub area, its only just touching the rim of the tyre, and the part thats touching is on the inside of the fender
      04-04-2016, 07:26 PM   #37
EB89
EB89's Avatar
Australia
541
Mine were rolled like this as well, anmd in the exact same spot, not all the way around.
Its not an MSport thing is it?
I had a body shop try and roll them even further, they got another 1-2mm out of it, which decreased my rubbing by about 60%
I think the next step is to get someone to do some cutting, theres a lot of fatness in there
      04-14-2016, 06:59 PM   #38
JunkyardDogg
90
Installed my 12mm spacers all around today and i'm happy with them. No rubbing at all in the rear and it rubbed a bit when turning the wheel and reversing but if I go slow, no rubbing. Haven't had anyone in the backseat yet so we will see.
      04-14-2016, 10:02 PM   #39
ksspacegray07
76
Drives: 335is coupe
I run 15fr with no issues could probably run a 18
in the back i run 18 and it rubs slightly...for no rub 15 would be ideal
i drive a 335is with the 19" 313's and stock rfts 225 and 255
that should be identical to your setup
and this was ran on the sport suspension with H&R sport springs
imo an 18 and 20mm spacer would be perfect with a rear fender roll
also camber comes into play alot, but the above was ran after being aligned at bmw
      04-14-2016, 10:17 PM   #40
JunkyardDogg
90
Do you rub with a a car full of people? I have the 225M 19's and 235 and 265 regular tires. Maybe because I have slightly wider tires I rub in the front a bit. I'm lowered on Eibach Prokits. Still, i'm surprised you could go that wide. Now i'm wondering if I should have went wider
      04-15-2016, 08:32 AM   #41
ksspacegray07
76
Drives: 335is coupe
well im not familiar with the offsets of the 225's, but you also have to take into account your running wider tires so that will limit the size of the spacer as well
      04-17-2016, 08:25 AM   #42
EB89
EB89's Avatar
Australia
541
I had 3 people in my car the other day. The rubbing in the rear was extreme.
19 inch 313 wheels with 265 tyres and 18mm spacers, fenders rolled as must as possible.
      04-18-2016, 07:57 AM   #43
Socket
Socket's Avatar
4552
Drives: 335i
2008 BMW E92  [0.00]
Did someone say spacers??
5mm both front and rears on H&R sport springs and Koni yellow shockies
      04-18-2016, 08:30 AM   #44
hz_diesel
192
Drives: 2012 E92 335ix
I have 313s with 10s in the rear but I can def fit a 12mm with no issue, contemplating looking for one...
Same spec wheel and tires, I am low but not slammed and no fender work done.
