F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > 3D Printed Air Scoop (335i N55)
ARMA SPEED
      06-24-2023, 01:38 PM   #23
Kads_M5
11
Drives: Bmw m5 f10
That's great mate thank you. Anyone got one for the right side too?
Thanks again
      09-14-2023, 12:31 AM   #24
PiX0
Drives: BMW M135i F20
Hi everyone,
anyone has the Scoop for left side / N55 Engine?
Unfortunately i've printed the wrong side
      09-15-2023, 03:50 AM   #25
Bachu1
72
Drives: Bmw 330d m sport
Hi i love this,, is there a chance i could get the file sent to me as well please? i have a 330d but i don't know which side i would require the item to be printed as.
      09-15-2023, 08:19 AM   #26
Iyrix
Iyrix's Avatar
102
Drives: F30 330d & 335i
It's on the previous page.
F25 X3 35d -
F30 335i -
      09-15-2023, 08:43 AM   #27
Iyrix
Iyrix's Avatar
102
F25 X3 35d -
F30 335i -
      09-15-2023, 08:48 AM   #28
Bachu1
72
Thank you very much
      09-18-2023, 03:19 AM   #29
Bachu1
72
Does the 3330df have this scoop on the drivers or passengers side.
      09-18-2023, 03:20 AM   #30
Bachu1
72
Does the 330D have this scoop on the drivers or passengers side.
      09-18-2023, 08:23 AM   #31
johnung
4554
Drives: 2015 BMW 335i x-Drive Auto
I totally understand the desire to want to provide more air to the engine with grill air scoops and larger air intakes. It’s important for anyone with an N55 to know that at the other end of that airflow is a stock Turbo Inlet Pipe with a restriction and an actual opening into the turbo housing that is less than 2” in diameter.
So front airscoops and big ass intakes don’t have much effect at all unless the Turbo Inlet Pipe is also upgraded. For example, on the F30 N55 the MST Turbo Inlet Pipe V2 eliminates the stock pipe restriction and smooths out the airflow to an end fitting with about 40% more potential airflow into the stock turbo housing. See photos.
MST Turbo Inlet Pipe for F-Series N55
(Make sure to select the higher flow V2 which is labeled “for aftermarket turbos”. That doesn’t matter because turbo housing is the same.)
https://www.kiesmotorsports.com/prod...2109141?aff=22
Iyrix102.00
      10-14-2023, 11:50 AM   #32
chris-c
901
Drives: F31 340i RWD
Originally Posted by jcdub View Post
Here's the file for the scoop for the left side, when looking at the front of the car.
I can't upload the file here. Here a link to the file. Again if for the left side (When looking at the car from the front.
https://drive.google.com/file/d/1NqR...ew?usp=sharing
Thanks for this. Took about 3 hours to print and fits almost perfectly onto my wagon. The only difference is I have a larger front radiator so the scoop is pushing hard into that.
I don't suppose you've got a mirror image one just so I can put them on for symmetry?
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
      10-20-2023, 10:45 AM   #33
Iyrix
Iyrix's Avatar
102
You can just flip the image in cura.
F25 X3 35d -
F30 335i -
      10-21-2023, 04:09 PM   #34
Smajlo
Drives: BMW 320
Hi,
Could someone please advise me on the correct scale to print this scoop? I attempted to print it from the original file, "Modified-scoopF30," and it turned out to be much too large for my F31.
Thank you for your assistance.
Best regards,
Damir S.
      10-23-2023, 07:45 AM   #35
Ennoch
2264
Drives: F31 335D XDrive
Here's a theoretical point to consider with these; is it going to increase risk water ingress to the intake? On my Impreza which has a forward facing inlet like this 3d bit, there's a long snorkus that goes into the wing, has a resonator/collector 18" below the inlet, and then a 18" rise back to the airbox. That means any collected water ends up at the bottom of the collector and can drain out the small hole in it. The BMW inlet design to me looks pretty flat which might be why I've seen so many sat at the side of the road absolutely buggered when there's deep water around (or maybe it's down to the drivers!). The intention of this design is obviously to force more air in from directly in front of the car, rather than sucking from the side of the grille. In theory this would seem to make it more susceptible to pulling water in...
Jetpro0.00
      03-20-2024, 01:15 PM   #36
iN55ane
Drives: 2015 F36 435i M-Sport
Originally Posted by Iyrix View Post
I've been wanting to add the AFE air scoop to the car for ages and never really wanted to spend the money on something that probably doesn't do a great deal... However, i enjoying 3D printing and with the help of jcdub who very kindly sent me the file for the print i've now printed and installed the scoop. Quality is excellent and fitment is good too.
I'm more than happy to share the file. It's roughly a 16 hour print once you've set the right parameters.
Cheers
G.
Hi Iyrix! I know this was a while ago but is there any way you could share the File with me? I would really appreciate it!
Cheers
      03-20-2024, 03:51 PM   #37
Iyrix
Iyrix's Avatar
102
Cheers
https://f30.bimmerpost.com/forums/sh...61&postcount=9
F25 X3 35d -
F30 335i -
      05-04-2024, 11:22 AM   #38
RayPal
RayPal's Avatar
Drives: 2008 BMW E92 M3 Alpine White
Does anyone still have the STL file for this? looking for a F22 M240i ( Right Hand drive ), also just for curiosity, ?
      05-08-2024, 07:47 AM   #39
Simon89
Simon89's Avatar
98
Drives: F30 330D XDrive
Check the post above your own!
13' F30 330D XDrive
f30post
