Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY E90 N54 Valve Cover Gasket
      02-21-2013, 12:13 AM   #23
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Originally Posted by Tonkatruck View Post
Why do you need to insert spark plug guides before installing the valve cover?
I want to thank you for this DIY as it's helped me tremendously.
It looked as if the guides seated under the valve cover, if they don't I am mistaken lol!! Glad it helped you, everything go good?
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
      03-07-2013, 12:31 PM   #24
Googie
Irish
Googie's Avatar
35
Drives: 07 335i, 2016 X5, Jeep JKU
I just got a quote from BMW parts for $287+tax for the parts and all the bolts are special order. Does this sound correct. This is what I gave her:
7544369 bolts x 26
11127565286 gasket
11127548063 bolts x 3
11127556977 bolts x 2
Any special tools needed for this job?
      03-08-2013, 01:27 AM   #25
Hreed
Hreed's Avatar
20
Drives: 2008 328xi Monoco Blue (Sold)
2008 328xi  [0.00]
I recommend Gasket Remover. Go to your auto parts store and ask for it; In my case the real stuff was in their back room instead of the store shelves. It's great and will be handy in any future DIYs. Just a thought!
2008 E90 328xi, Monaco Blue (Sold)
1971 E10 2002, Colorado Orange, Restoration w/ Turbo
1988 E30 M3, Schwarz Metallic (Sold)
1992 E30 318i Convertible, Schwarz II
2015 F85 X5M, Silverstone 2 Metallic
      03-12-2013, 12:15 PM   #26
deezofchuck
19
Drives: OVER SLOW LEFT LANE DRIVERS!
Just did mine yesterday - although I paid someone to do it bc I wasn't comfy messing with some of this stuff related to the fuel line. After watching this DIY is VERY useful and detailed - I think I could do it now that I have this guide and watching my buddy work it. We took a different line to get the cover off but this one seems much better as putting the cover back on was a PITA. Good stuff!
2008 E92 335xi | Cobb AP Stage2+ | AR DP | ETS FMIC | ALUFELGEN SF-71 DC Blk | HANKOOK V12 | UUC SSK | H&R Coilovers | AE Exhaust |
Are YOU Ready to Buy/Sell/Rent Property In The DMV? LET ME HELP YOU!
      03-12-2013, 12:31 PM   #27
GoRomeo
GoRomeo's Avatar
1015
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Great DIY but I dont think Iam ready to do this job on my own...
      03-12-2013, 12:41 PM   #28
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Glad it helped!
      03-12-2013, 12:42 PM   #29
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
It is honestly not that bad.
      03-12-2013, 12:52 PM   #30
deezofchuck
19
Agreed - I would do this myself next time (hopefully not again for a while although I didn't replace my bolts (dont see a need to unless they were damaged) - the only thing that would have really scared me is the fuel like pressure release.
Also DO NOT open your doors when the fuel line is open! it WILL squirt fuel like a sprinkler - found this out the hard way lol
      03-12-2013, 01:03 PM   #31
GoRomeo
GoRomeo's Avatar
1015
Drives: 330i, 135i
2006 330i  [6.75]
You are probably right. I wonder what the differences are changing this gasket on N52 engines. I will look for DIY on N52 if available.
      03-12-2013, 01:24 PM   #32
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
I took the batter completely loose ;-)
      03-16-2013, 11:37 AM   #33
Googie
Irish
Googie's Avatar
35
So I had my valve cover gasket done at a shop and the guy told me after that he did the torque at 10. Is that bad? Should I be worried? I just got it done so can the torque be adjusted back to 7 - 7.5?
      03-16-2013, 12:52 PM   #34
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
you are perfectly fine!
      03-26-2013, 10:01 AM   #35
deezofchuck
19
so after I replaced my VCG I still got burning oil and took it to bmw for a diagnosis - and they said the valve cover itself is cracked and need to replace it and the crank case ventilation system is suffering because of this - would this cause burning oil? The tech said I need a new valve cover and vent pipe to the cover....I am not sure what this vent pipe is? Anyone?
      03-26-2013, 12:35 PM   #36
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Vent pipe is the "check valve" and is located on the left side of the cover.
      03-26-2013, 02:43 PM   #37
deezofchuck
19
Okay - thanks I will check this
I wonder now after reading other posts if the silicon used to keep the corners of the gasket on is causing the crank case ventilation system from breathing properly? Could that cause oil to burn off somewhere?
      03-26-2013, 04:29 PM   #38
deezofchuck
19
Rob - is this the correct vent pipe? Highlighted #3 part of the emission system - it's the only vent pipe I could find in the parts catalog.
Thanks!
      03-26-2013, 07:18 PM   #39
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
Thanks!
nope, this one:
http://www.ecstuning.com/BMW-E90-335...sions/ES19642/
      05-20-2013, 03:12 PM   #40
idriveslo2
Drives: 335i
also very interested in torque specs for fuel rail as I will be swapping mine out next week.
      05-27-2013, 05:03 PM   #41
silvermist99
11
Drives: 335i 6MT & X5D 6AT
2007 BMW 323I  [0.00]
2007 BMW 335I  [0.00]
Where did you guys buy the extra deep 10mm? I can't find it at stores and stuck can't take that out since the half inch drive 10mm don't fit in there
      05-27-2013, 09:45 PM   #42
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
No need for it, just dont put the socket on ratchet all the way and it elk reach just fine.
      05-28-2013, 11:56 AM   #43
silvermist99
11
edit again.. I finally got it all off ! thanks for the writeup
      05-29-2013, 12:22 PM   #44
robc1976
DIYER
robc1976's Avatar
614
Drives: E90 335i
awesome!
