How to replace LCD on BMW Professional radio
03-10-2013, 04:11 PM | #23 |
1625
Rep 2,162
03-10-2013, 09:46 PM | #24 |
Rep 10
May be not the answer what you want to hear, but most likely yes. Because it is exact same part. I'm not sure, if Alpine did any improvements/modifications in design in replacement part. But at least it is brand new.
03-11-2013, 01:11 PM | #25 |
1625
Rep 2,162
Thanks. I guess it would at least buy me 2-3 years of decent use
03-18-2013, 04:26 PM | #26 |
Rep 11
Very Nice Instructions : I've Just finished installing my LCD Works Great.
Just a note my LCD Ribbon Cables Were Taped With Transparent Tape, Had to remove tape before ribbon cable would pull out. I got the LCD from bestpixelrepair cost $140 + Shipping, Repair time about 1 hr. |
03-19-2013, 10:01 AM | #27 | |
1625
Rep 2,162
03-19-2013, 01:26 PM | #29 |
Rep 11
Just Four Metal Pin claps to Unsolder and re-solder, not hard to do Tools needed Soldering Iron, Solder Sucker or Solder Wick ( I used Both).
03-19-2013, 03:35 PM | #30 |
1625
Rep 2,162
04-12-2013, 01:05 PM | #31 | |
52
Rep 15
The test patterns are a series of checker boards and bands of varying intensity. The only reason for mentioning the test patterns was to confirm that every pixel worked correctly. I came across this test on another forum and thought it was useful. If you are replacing the HU, it will be plug and play if it is exactly the same model, otherwise it might need coding. I believe there is also a version of the HU which includes optical output and one that accepts a microphone for voice control, but mine is just the basic CD73. |
04-13-2013, 10:14 AM | #32 |
Rep 12
I bought an LCD from germanaudiotech and took out my radio. But it is completely different than the one in the photos. Mine came from a 2011 328xi. Moreover the screws are a special star shape not philips nor allen wrench. At a standstill. I'm going to see if I can mail the radio and LCD to germanaudiotech and have them replace it, but now I'm not sure the LCD is correct. Plus getting the heater controls out came close to breaking the bezel, the instructions should be better on that part and it would help to say the antenna connections require pressing down a latch with a screwdriver and how to unplug the multipin connector.
04-16-2013, 12:35 PM | #33 |
1625
Rep 2,162
Why did you take so much care not to damage the ribbon cables for the screen you were removing and presumably throwing out?
04-16-2013, 02:20 PM | #34 |
52
Rep 15
The truth is I did, unintentionally, damage the cable on my old screen while removing it. They are very easily torn by sharp implements (pliers, tweezers, etc.).
I just wanted to make sure people are careful with the new screen. I agree though, it doesn't really matter if the old screen cable gets damaged. |
04-16-2013, 02:24 PM | #35 | |
1625
Rep 2,162
04-26-2013, 10:19 AM | #36 |
1625
Rep 2,162
1. Ugh. Gotta get those ribbon cables from the new screen back into their connectors. They just don't want to go in very far and I'm afraid to break them. Suggestions on handling?
2. IMPORTANT Edit: I figured it out. There are little black tabs on each side of the two connectors that pull out horizontally (parallel with the board surface) like a tray. Once the "tray" comes out, you can set your ribbon connectors down and slide the tray back in until it locks. I was going crazy for like 20 min trying to figure that out. Oh also, that would've made it a lot easier to remove the old one. Last edited by ellipsis212; 04-29-2013 at 04:45 PM.. |
04-29-2013, 04:36 PM | #38 |
1625
Rep 2,162
Here's a little picture showing in orange where the tabs on the connectors are, and in purple, the direction that they pull out. They only go about 3mm out.
04-30-2013, 05:24 AM | #39 |
Rep 11
Nice guide. I'm looking for another solution, looking on internet to find someone that can change the screen by another one.
05-02-2013, 08:55 PM | #40 |
327
Rep 1,002
Drives: 2016 F82 M4
Nice write up! I'm about to tackle this one myself. Just waiting for the screen to come in.
Update: Success! First time my screen has fully worked in years. Mine only had two points soldered. It took me about an hour with prep, repair, and cleanup.
2007 e92 335i 6MT | Cobb AP Stage 1+ | ETS FMIC | AFE Dual Cone Intake (Sold)
ED 8/18 - PCD 10/19 | 2016 F82 M4 6MT | Alpine White | CF Roof | CF Trim | Black Extended Leather | Executive Package | Lighting Package | Adaptive M Suspension | 19" 437M Black Wheels |
05-07-2013, 08:31 PM | #41 | |
327
Rep 1,002
Drives: 2016 F82 M4
06-25-2013, 11:11 AM | #42 |
Rep 18
I bought another head unit cheap and instead of replacing just the LCD screen by digging around and soldering do you guys think it's possible to just swap the 'faceplates' after removing the 5 screws and the one ribbon cable? It would save work if I already have another head unit with non-functioning CD-player. The only concern I have is if the car will notice that a part of the stereo has been 'frankensteined' / replaced and demand to be recoded. Any thoughts?
6MT, short shift kit, JB4, BMS Dual Core Intake, Mtech rear bumper
06-25-2013, 09:19 PM | #43 |
Rep 18
So, trying my experiment above, I can open the stereo I bought quite easily, but the one in my car is obviously a little more advanced as it has some strange fasteners on it that seriously have no depth for a tool and my knobs are silver. I'm baffled here.
06-26-2013, 01:28 PM | #44 | |
1625
Rep 2,162
Tags |
cd73, lcd replacement, pixel fade |
