eBay Bluetooth Streaming Box DIY and Reveiw
05-28-2018, 02:42 PM | #23 |
Rep 3
Please let me know if you end up testing the SD card slot and the USB. I mainly want to know if it will display track info if connected via usb. Thank you for the documentation. I really appreciate it. This looks like it is the solution for us 06 people!
05-28-2018, 03:33 PM | #24 |
1926
Rep 13,134
BMW aux is definitely the gating point on high quality audio.
Some have applied DAC's to improve it but it seems to still fall short of USB in. It would be nice if this module used aptx for streaming. |
05-28-2018, 04:15 PM | #25 |
627
Rep 2,099
I’ve actual contemplated using a power adapter to use one of these units:
https://www.crutchfield.com/p_772B1A...engine-B1.html |
05-28-2018, 04:34 PM | #26 |
198
Rep 709
Hi, Nickco43
I do have one question though, can it stream from Android and retain steering wheel previous/next functions? I don't care much for title or artis name, that's just a nice added bonus. Thanks. |
05-28-2018, 04:47 PM | #27 | ||
1491
Rep 1,917
The listing says it uses A2DP Last edited by Nickco43; 05-28-2018 at 08:27 PM.. |
05-28-2018, 05:12 PM | #28 |
1926
Rep 13,134
Playing a usb stick or sd would not be considered a2dp(bluetooth streaming) nor
would hooking your phone up via a usb cable. Add says wireless streaaming which is A2dp also you had pairing pictures up and said you were using the BMW oem phone bluetooth for phone only . So I am confused by your last statement. Plays usb with a usb stick = great play with power chord attached to usb = great wireless streaming?(which would mean no chords attached ) "I tried streaming audio on an iPhone 6 and my pixel 2 XL it would not work" I thought you said it has worked with your Pixel for streaming. "Bluetooth off my phone sounds comparable to a CD. Steering wheel controls work fine. I can stream music from Apple Music and Tune in. I can't comment on the calling function of the box since I don't need to use it. If you knew what you were doing and have a coding laptop ready to go this install should take maybe an hour. " How was it hooked up when you did the above ? On bluetooth phones have both a media and phone option when paired at the phone end they both have to be on? Last edited by ctuna; 05-28-2018 at 05:26 PM.. |
05-28-2018, 08:27 PM | #29 | |
1491
Rep 1,917
I have a pixel 2 XL that I have hooked up with Bluetooth audio streaming using the eBay box. Phone calls go through the OEM bluetooth calling box. Bluetooth audio streaming has working steering wheel controls and CD quality audio. Dip 4 on the back of the box removes the calling functionality of the eBay box. I made a demo video of this at the end of the OP. I tried playing music with my pixel through USB with the eBay box and it did not work. It is only intended to charge a phone or play music off a USB drive. |
05-28-2018, 10:18 PM | #30 |
627
Rep 2,099
probably means it can’t handle full hdds or its looking for a simple file system format like fat32.
glad that you can pick and choose which BT functions it uses as I think you made a good call there in the config. ATP-X codec via A2DP would have this thing on my Buy Now list. Otherwise, if the radio controls/display and steering wheel functions are working, it’s still a great piece that leaves the headunit DAC as the weak point, which at least is consistent. |
05-29-2018, 09:23 AM | #31 | |
Rep 110
I actually just bought this to try it out: https://www.ebay.com/itm/Bluetooth-5...D/273161931903 It supports up to aptx HD and the dac on there got good reviews on other devices. I wish these CD boxes had aptx also |
05-29-2018, 09:36 PM | #32 |
627
Rep 2,099
Well, my gripe with Firefly is the same with Tune2Air and that's the DAC and the reprocessing by way of the aux to the radio and back out.
I'm always a little weary of something that has a coax or split plug out vs the straight RCAs but that looks like it fits the bill decently. I was trying to dig, but it wasn't obvious: which DAC does it have? AK or Sabre? How do you like it? |
05-29-2018, 10:03 PM | #33 |
1491
Rep 1,917
I bought these:
https://www.ebay.com/itm/KKmoon-USB-...53.m2749.l2649 https://www.ebay.com/itm/USB-A-Male-...53.m2749.l2649 and a used OEM BMW Aux + USB port with cable to see if I can have a functional usb port in the center console. Last edited by Nickco43; 05-30-2018 at 12:04 AM.. |
05-30-2018, 10:44 AM | #35 | |
Rep 110
The DAC is PCM5102. It's used in Arcam products like I mentioned before. Here is a review: http://www.portablehifi.com/arcam-rb...rblink-review/ I guess there is quality dangers to the Chinese implementation but it costs <20% of what the rblink costs |
PORTMOODY140.50 |
05-30-2018, 11:40 AM | #36 | |
627
Rep 2,099
05-30-2018, 01:21 PM | #37 |
1491
Rep 1,917
I am going to see if I can hook up the OEM USB port to the box with that ebay cable and the adapter.
Update: There is a Navi car with the same interior is my car at the junkyard. Hopefully everything is still good so I can do the idrive swap for pennies. Last edited by Nickco43; 05-30-2018 at 06:04 PM.. |
05-31-2018, 01:33 AM | #38 |
627
Rep 2,099
While the Navi would certainly be cool and undoubtedly tons of effort, therre’s a side if me that would prefer to see your lab results with the usb experiment.
05-31-2018, 11:55 AM | #39 | |
1491
Rep 1,917
Today I raided my local pick and pull and got 95% idrive swap and a full rear folding seat retrofit for $140. It's a CCC but a damn good deal. |
PaKii948.50 |
05-31-2018, 03:38 PM | #40 |
Rep 110
05-31-2018, 06:44 PM | #42 | |
1491
Rep 1,917
Update: I am at $425 for the retrofit. My first navi was broken so I bought an replacement. If it worked I would have been at $300. Last edited by Nickco43; 06-06-2018 at 09:35 PM.. |
06-13-2018, 10:23 AM | #43 | |
Rep 110
One downside is I need to get a short flat 90 degree aux cord. It sticks out too much on the front |
06-13-2018, 11:25 AM | #44 |
Rep 9
my car is prewired for the microphone above my head with the interior lights...can the factory mic 84 31 6 938 762 be added and implemented with dip switch 4?
Am I understanding that correctly? If not can some upload some pics of how they discretely added the included mic with the box? thanks |
