03-15-2024, 04:12 PM | #24 |
384
Rep 301
Drives: 2010 128i ZSP 6MT
I have an Induktiv in my oddments tray in front of the gearshift. If I hadn't gotten that, I probably would have gone with a RennLine E90 ExactFit.
(assuming that the RennLine would fit) I'm ordering one of their E83 phone mounts, as I think that might work better (and I want to see if it actually *will* work). Plus, it's on clearance, so it was $44 instead of $65.
2010 128i ZSP 6MT Coupe
Deep Sea Blue (Tiefseeblau) Metallic Style 264 Wheels Lemon Boston Sport Interior Last edited by Donkeyshins; 03-15-2024 at 04:36 PM.. |
03-17-2024, 09:43 PM | #25 |
1055
Rep 783
Drives: 2010 328ix E91, 2011 128i E82
I have a Scosche magnetic wireless charging mount that I have set up in the "cupholder" - which are, of course, useless for holding cups. It plugs in to the cig outlet and I coil/store the excess wire under the armrest/console cover. If you are trying to use the phone as the nav screen, it doesn't really work, but I have wireless AA on the headunit and also a standalone Garmin GPS so the phone is not needed/used as the nav screen.
K9Leader 2010 328i x-Drive, E91 - Space Gray/Black 2011 128i E82 6MT - Crimson Red/Black |
Tornado1M1225.50 |
03-18-2024, 03:39 PM | #26 |
Rep 9
Looking at getting a ProClip myself as well, debating Center Dash vs Console.
Given the Center Dash partially blocks the center vent, has anyone had phone overheating issues with the Center Dash mount? I suspect I'm overindexing on this as a concern, and I certainly like the location better - much easier peripheral sightline vs dropping my eyes to the Console every time. |
03-18-2024, 11:21 PM | #27 | |
384
Rep 301
(TBD, of course, since I'm going to be trying the E83 version in an E82)
Deep Sea Blue (Tiefseeblau) Metallic Style 264 Wheels Lemon Boston Sport Interior |
03-19-2024, 08:26 AM | #28 | |
504
Rep 324
2011 BMW 128i 6MT M Sport - Alpine White on Terracotta w/ Glacier-Silver trim - Koni Yellows w/ H&R Sport Springs, M3 Control Arms, Euro Intake, BMW Performance Exhaust, 3.73 Diff w/ RacingDiffs LSD Conversion, Black Line Taillights, M Performance Grilles, lots-o-maintenance
03-20-2024, 08:12 AM | #30 | |
504
Rep 324
https://www.bestbuy.com/site/anker-3...?skuId=6547358 ^ I think I actually have something cheaper and with less charging power. https://www.bestbuy.com/site/belkin-...?skuId=6477374 ^ That plugs into my phone, then I have a USB-C cable and a 3.5mm cable tucked underneath some interior trim and extending to the arm rest area plug ins for cigarette lighter / audio.
03-21-2024, 12:13 PM | #31 |
Rep 9
Nice! I'm lucky enough to have Bluetooth audio streaming enabled in my 2011 (no idea how lol - I don't have iDrive), but I've also had great luck with this Besign Bluetooth adapter. Plugs right into 3.5mm and takes up 1 of the USB-A ports in my charger right under the armrest. Keeps phone cabling nice and clean, just need to run the charger line.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
03-21-2024, 07:35 PM | #32 |
384
Rep 301
The Rennsport phone mount arrived today. I had to do some massaging of the mount to fit where I wanted it to in the dash, but nothing anyone can't do with just a pair of pliers.
Not bad for $45 and 15 minutes of my time.
03-21-2024, 08:53 PM | #33 | |
1226
Rep 1,066
Double sided heavy duty tape? |
03-21-2024, 10:54 PM | #34 | |
384
Rep 301
I’ll pull the trim tomorrow and take a photo of the bracket. If I were so inclined, I’d repaint it (the straightening caused the paint to flake off the bracket), but since it is under the trim, it doesn’t really bother me. |
03-24-2024, 06:32 PM | #35 | |
50
Rep 45
I have one in my e46 and love it! |
Donkeyshins384.00 |
03-25-2024, 11:19 AM | #36 |
Rep 3
Donkeyshins384.00 Tornado1M1225.50 |
03-25-2024, 05:40 PM | #37 | |
384
Rep 301
If I were to do it over again, I might try and get a flat / pre-bent bracket from Rennline and do the bends / painting myself since the bends aren't perfect and there was definitely some deformation from having to hammer some bits flat. (come to think of it, I might just reach out to them and see if they'd be willing to sell me one)
03-25-2024, 07:47 PM | #38 |
33
Rep 10
I'm just using the Kenu airframe vent thing for an iPhone, and puts the phone in good line of site, and don't need a case for phone. Get the hang of it after a while. I use my CD player! Y'all own CDs yes? Sound pretty good in a car they do. Cheers all
03-25-2024, 08:53 PM | #39 | |
50
Rep 45
03-26-2024, 02:46 PM | #40 |
384
Rep 301
Doesn't need to be heated - it's 20ga sheet metal. I hammered to flatten it out (since complex bends) and then bent using some parallel-jaw linesman pliers. What I should have done is dug up my sheet metal bender (probably what I will do if I can get a flat version with which to start from scratch).
03-27-2024, 01:56 PM | #41 |
384
Rep 301
And, unfortunately, Rennline won't sell me a blank.
03-28-2024, 10:17 PM | #42 |
50
Rep 45
03-29-2024, 10:23 AM | #43 |
384
Rep 301
It's not just how straight it is, it's how long it is to reach the screw on the dash. I might just remove it, measure it out, and see if I can get something laser cut from Send Cut Send out of slightly thicker (18ga) stainless. Then I can bend it on my bench.
duperdog49.50 |
04-25-2024, 05:18 PM | #44 |
Rep 11
I am trying out this solution from Amazon. Simple ring mag mount. I don't need all that screen space.
Tornado1M1225.50 Donkeyshins384.00 |
