      12-26-2013, 02:51 PM   #23
Iron Man
Iron Man's Avatar
189
Drives: N/A
If you really want to help minimize/prevent warping on cast iron rotors, you should freeze your rotors in liquid nitrogen. This will transform all of the retained austenite to martensite. The cryogenic treatment also involves tempering the rotor after freezing.
This will increase the life of your rotor and prevent warping.
      12-26-2013, 03:33 PM   #24
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
298
Drives: 911, 130is, E39 M5, E36 M3
Originally Posted by Blacksport View Post
Generally good advice....but listen to this; my Durango warped the rotors every 6k to 8k miles....Dodge rotors, aftermarket rotors, didn't matter. I finally put the Wilwood BBK with 16" rotors on the front...been on for over 20k, no warping, not even slightly....However, the rear rotors continue to warp every 6k miles...do I buy EXPENSIVE Dodge rotors for $190 each?? No, I buy cheap Summit drilled, slotted rotors for 50 bucks each, and throw the old ones on the WRP (warped rotor pile) in the back of the warehouse.
Dodge factory parts and BMW factory parts have little to do with each other.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      12-26-2013, 03:34 PM   #25
___whoosh___
14
Drives: 2010 135i
Originally Posted by uberschnell View Post
http://www.ecstuning.com/News/BMW_E8...ors/ES2550968/
2-piece semi floating, will help cool the rotors faster + about 8 lbs. lighter then stock
I just snagged the front and rear full service kit from ECS with these front rotors
can't wait!
      12-26-2013, 04:29 PM   #26
uberschnell
uberschnell's Avatar
No_Country
675
Drives: Wide Body 1
Wow, I wished I would have known this before swapping out my front brakes and rear rotors with non OEM parts. Even though it's been over 2 years with zero problems I feel better now knowing that they will never be as good as OEM parts
Seriously though, what do you tell all those 135i owners with cracked pistons in their OEM calipers? Let’s not kid ourselves into thinking BMW oem is not fallible or that you can't get equal or better performance from the right aftermarket parts.
People go cheap and then try and throw all aftermarket parts into the same bucket because of that experience. Being smart and doing your research can yield you good parts and saved money.
      12-26-2013, 04:58 PM   #27
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
+1. Not to mention the engineering(or lack there of) that goes into each marke.
Somehow I don't think I'd see a X5 with puny 114i rotors on it. But I see many American SUV's with tiny front rotors and rear drums. Not a recipe for "performance".
Cryogenic treating brake rotors is a good idea and it works. You see lots of racers using it.
I have also heard of the NASCAR boys putting brand new rotors outside to rust. Then a year later they machine the rust off and use the rotors. Something about the rust hardening the metal. Not sure if thats a myth or not.
      12-26-2013, 05:05 PM   #28
Blacksport
Blacksport's Avatar
54
Drives: 2013 128i
Those rotors and hats are BAD A$$...I'm grabbing a set while they're on sale...I'll sell the BMW performance rotors on ebay...and notice there's a Left and Right rotor!!!!
'13 128i 6sp, '19 Cherokee Ltd 3.2, '17 Ducati SuperSport S Gone But Not Forgotten: 74 Z28, 77 Datsun 280Z (1st 5sp in US), 92 Nissan 300ZTT, 94 MB SL600 V12, 01 M Roadster, 66 Yamaha TwinJet 100, 70 Suzuki X6 Hustler Race: GP/FP Spitfire SCCA, Merlyn FF SCCA, Mazda RX7 IMSA GTU, Yamaha FZR 400 AMA.
      12-26-2013, 05:10 PM   #29
Blacksport
Blacksport's Avatar
54
Drives: 2013 128i
Yes, that's so true...I did NOT get a letter from Dodge extending my Hemi's warranty to 100,000 miles because of rod bearing failure. I DID get a letter from BMW extending my S54's warranty to 100,000 miles because of rod bearing failure.
      12-26-2013, 07:02 PM   #30
uberschnell
No_Country
675
Drives: Wide Body 1
And lets not even get started on the "high" quality of BMW OEM water pumps
      12-26-2013, 07:51 PM   #31
Iron Man
Iron Man's Avatar
189
Drives: N/A
This is nothing but pure myth. Rust will not harden the rotors.
      12-26-2013, 08:26 PM   #32
Blacksport
Blacksport's Avatar
54
Drives: 2013 128i
Yes that's pure myth....but I know a few racers, Joe Huffaker is one, who will leave an engine block outside in the weather for a few months, believing it would relieve internal casting stress and stabilize the block's dimensions. We never did this, but we would nitrate the cranks of the Spitfires and MGs we raced in the 70s to harden the bearing surfaces. Being cast iron, they were very delicate.
      12-26-2013, 09:17 PM   #33
Iron Man
Iron Man's Avatar
189
Drives: N/A
The colder temperatures outside is what would stabilize the microstructure of the block. Cryogenic treatment is just a more robust process, since it goes to such low temps. Nitriding and carburizing are all common forms used to surface harden steel/iron alloys, especially gears and bearings. Cryo treatment transforms the entire thickness of a piece, not just the surface.
      12-27-2013, 06:30 AM   #34
Kgolf31
Kgolf31's Avatar
461
Drives: 2007 Z4MC, 2012 128i
Interesting...never heard of that.
Got a scanned letter or something I could look at?
BTW, I keep on hearing the term warped in this thread. I would like to know how that happens on a car that is daily driven.
      12-27-2013, 07:31 AM   #35
TheSt|G
TheSt|G's Avatar
298
Are we really going to debate Dodge being the bottom end of western car makers?
      12-27-2013, 08:00 AM   #36
uberschnell
No_Country
675
Drives: Wide Body 1
No, no. Just saying that sometimes OEM is not the end-all best option for parts.
      12-27-2013, 08:07 AM   #37
TheSt|G
TheSt|G's Avatar
298
I don't think OEM is ever a good choice, which is what I've been saying this entire thread.
Also, I accept that everyone makes mistakes. Fortunately as BMW owners we are in a fairly unique position in the car community where there is a fairly high level of both technical ability and disposable income surrounding our brand. As a result, we have well made products like Stewart water pumps and Zionville radiators that provide permanent lock down solutions for our few design errors.
      12-27-2013, 08:11 AM   #38
Blacksport
Blacksport's Avatar
54
Drives: 2013 128i
Oh I have the letter, trust me...When the S54 first came out in 01, both in the M3 and the M roadster, many of the engines quickly developed rod bearing failure...BMW had spec'ed special Castrol 10w60 oil. This oil must be carefully warmed up, and also the pressure relief valve must allow for adequate bypass to keep the pressure from sky-rocketing with a cold engine and a high-revving idiot behind the wheel. These guys would unload the M3's from the boat, hitting 8500rpm before parking them. The rod bearings were shot before they hit the dealers. BMW fixed the problem with a more "appropriate" pressure relief valve and a "cold-engine" RPM limiter, to keep brain-dead, no-nothing idiots from blowing up their S54's because they were too stupid to warm them up. Very important tip: It takes 8 miles of driving to bring the oil up to temperature. Forget water temp, the water can be at running temp, and the oil still cold....
Kgolf, if you're still with me, here's a tip on rotor warping: everybody knows that a "floating" rotor is much less prone to warping than a 1-piece rotor. So if you have 1-piece rotors, how do you keep them from warping? You probably can't in the long run, as I've found out with my Durango's rear discs. Stopping a 2.5 ton vehicle is hell on brakes. My Viper warped the rear discs, too. But here's what you can do to reduce warping: if you just had a fairly hard stop, maybe a traffic light quickly changed when you were racing an old Camaro, while you're sitting at the light, DO NOT have your foot on the brake...the rotor will cool down evenly except where the pads are clamping it...that un-even cooling will warp the rotor over time.
      12-27-2013, 08:45 AM   #39
Kgolf31
Kgolf31's Avatar
461
@Blacksport, I own a Z4M...and have 30 liters for 10w60 sitting in my garage to do oil changes every 3k miles or after track events for the reason of avoid rod bearing wear.
I wanted to see the letter because I want to have documentation in case I ever have to replace my rod bearings, I can get BMW to compensate me.
About the warped rotors, I've never had warped rotors during autocrossing or track events....only pad deposits that can be mistaken as a warped rotor. That is what I was trying to say. Yes, you can warp a rotor...but it is very hard to do so.
      12-27-2013, 08:57 AM   #40
Blacksport
Blacksport's Avatar
54
Drives: 2013 128i
The letter doesn't pertain to your S54, only 01's and maybe 02's...they had the problem fixed by then...but I'll dig out the letter and email it to you, if you want....PM me your email...BTW, I turned down that Z4M I was looking at...I'm still looking, but have too many projects going already...
Changing the oil after an event is good...but the most important thing you can do to protect your rod bearings is warm the oil completely before your event....
      12-27-2013, 09:24 AM   #41
Kgolf31
Kgolf31's Avatar
461
Yea, it is nice to have an oil temp gauge to know where you're at.
No need to send the letter, I thought it was across the board for all S54s.
Keep on looking at the Z4Ms, you'll find a steal sometime sooner or later.
      12-27-2013, 10:31 AM   #42
TheSt|G
TheSt|G's Avatar
298
Rod bearing recall was due to the bearings themselves not being made to spec for early S54 engines, not a spree of lead foot cold start dock workers. After attempting to blame it on the owners, and then oil pump software, BMW initiated a recall in 2004 for E46 M3s with the model year of '01 to '03. The '03.5+ E46 M3 already had had the issue fixed at the factory(and in reality, all '03s were fine), as well as all Z4M coupes as they were produced long after the issue. The S54 Z3M coupes were never included in the recall despite all being built with the faulty bearings.
      12-27-2013, 10:51 AM   #43
Iron Man
Iron Man's Avatar
189
Drives: N/A
Cast iron rotors can warp from a microstructure change within the rotor. Some rotors will have retained austenite in the structure, which is relatively soft, and it will transform to martensite under stress or severe temperature change. This transformation also involves a change in volume, which causes the rotor to warp, since the volume change is not uniform. That is why a proper controlled freezing/cryo treatment, followed by tempering, of the rotor will help prevent warping.
      12-27-2013, 11:14 AM   #44
Blacksport
Blacksport's Avatar
54
Drives: 2013 128i
Yes and no. The bearings were "upgraded", but so was the pressure relief and the cold RPM limiter. My 01 had the "faulty" bearings as you say, but I never had a problem with them...Blackstone labs analyzed every one of my oil changes and all reports came back as close to perfect as you could get...it was entirely possible to have an early S54 and have the rod bearings enjoy a long and healthy life...if you took the time to properly warm the engine before putting any stress on it....However, the general consensus among experts is: the bearing width is too small, and when BMW "upgraded" the bearings, all they did was add a little clearance.
1addicts
